Question about Intex Automatic Salt Water System for Above Ground Saltwater Pool
After going thru the Start up set up our Intex
After going thru the Start up/Set up our Intex Salt (Model 8110 ) water chlorinator will not engage once the time is set for operation - thus the time keeps flashing and no green light. Any ideas on how to solve this?
Thank you!
  • 10 Answers
After setting the time did you remember to re-lock the keypad by pressing and holding the "down arrow" for 5-seconds until you hear a long beep and then the "up arrow" for 5-seconds until you hear a long beep? Several minutes later the Green LED should come on indicating the cycle has started.
Posted on Jul 03, 2009
Salt Water System Model 8110 will not generate Chlorine
6000 gallon pool initial salt 129 lbs for count of 3000 ppm
Mar 05, 2017 | Intex Automatic Salt Water System for ...
Code 88 stays on it hasnt gone off since i plugged it in
This is normal... From here, you must set your cycle time.....Follow these steps... Note: on the 8110 model, you must start your pump and set your pump timer first, then wait 15 minutes to sync your chlorinator to between the pump hrs. If the pump turns off before the chlorinator, you will get a low flow alarm...
If you can't read this, it's from your manual.. If you need help setting the timer, post asking for help setting timer... Good luck...
Aug 08, 2011 | Intex Automatic Salt Water System for ...
I turn on salt water system and stays on 88. I cannot find my owners manual. My water is turning green. Model 8110
Here's the link for the manual... Code 88 is the start up mode.. You set your cycle from here...
If you need further assistance after you find your manual, reply and I will help sync your pump and chlorinator...
Good luck!! and hoped this helps you...
Please vote and rate...
http://www.intexcorp.com.hk/proifv/proifv_dl_client.jsp?hid_windowname=null&lst_docsea=2011&source=intexstore&gid=2&lid=14313&hid_windowname=null
Jul 29, 2011 | Intex Automatic Salt Water System for ...
Have no owners manual and can't figure out how to set the timer!
code 88
Is the Setup/Start up Code. it is displayed until you set the timer. which you do so by holding down the down arrow till you hear a beep, then hold down the up arrow till you here a beep. from there you can set the time and then to lock it in repeat the process
If you need the manual you can email Intex at www.email.intexstore.com
Or you can buy the manual on this link below.
http://home-and-garden.become.com/intex-krystal-clear-deluxe-saltwater-system-salt-in-pool-model-8110-owners-manual--compare-prices--sc906782580
Good Luck and please rate 4 thumbs up for the free answer.
Jul 05, 2010 | Intex Automatic Salt Water System for ...
Do I have to drain my 24 ft round above ground pool to install an intex salt-chlorine generating system? I have just opened he pool and the ph and chlorine levels are where they should be.
no need to drain go to the intex web site and look up your pool size for the starting amount of salt you need.
After ading it run your filter for at least 24 hours before trying to generate use this web site and click on the english version for pump 8110 once it downloads go to page 13 14 15
to find the salt amount you need
chlorinehttp://www.intexcorp.com.hk/proifv/proifv_dl_client.jsp?source=intexstore
Jun 06, 2010 | Intex Automatic Salt Water System for ...
This is my 3rd year using intex 8110 sytem. I
That code means the unit is in standby. It should start working if you set the opperational hours that you want in the program. Use the program guide in the manual.
Please Vote !!
Jun 01, 2010 | Intex Automatic Salt Water System for ...
Intex salt water chlorinator not producting chlorine
You can test if the 8110 is generating any chlorine by taking a water sample directly at the pool return. You can invert your container so it stays filled with air until you have it positioned in front of your return. Make sure your test chemicals are not expired and test the sample. You should get a high reading if the 8110 is producing any chlorine. If it is producing chlorine, you may want to make sure you have the correct level of Cyanuric Acid. In my pool, if the Cyanuric Acid level is low, the chlorine level drops to zero quite quickly.
If the sample indicated your 8110 is not producing any chlorine, I would check to see if you have approx. 24V DC between B+ and Gnd on the screw terminal strip on the main circuit board. The transformer supplies two voltages to the 8110. One voltage powers the electronics and the other powers the electrolytic circuit. So it is possible for part of the unit to work if one voltage has failed.
Jul 03, 2009 | Intex Automatic Salt Water System for ...
No chlorine reading
Salt is sodium chloride, you can only measure salt levels now as your CL (cloride) is bound to a NA (sodium). Table salt =NACL, Your Intex system will tell you if your salt level is too high or too low but your old test equipment for free chlorine will continue to tell you no chlorine as it can't react with the chloride any longer as it is bound to the salt. That is why they tell you you never have to add more because the salt stabilizes it. Your chlorine is there it's bound to the salt. Use the pool it's fine and it makes your water feel really soft! Just keep the salt level right and your fine> It's confusing as they call the unit a chlorine generator! I had the same issue, called Intex and they told me the above.
Jun 01, 2009 | Intex Automatic Salt Water System for ...
Intex Automatic Salt Water System for  Above Ground Saltwater Pool Logo
322 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
