Question about Lasonic PDL-305 Portable DVD Player
PDL-305 Battery I cannot figure out how to charge the battery for my Lasonic PDL-305. I have an ac adapter, which the player works when plugged in. It does not seem to be charging the battery.
2 Suggested Answers
Sparky2012
  • 102 Answers
SOURCE: I have a lasonic portable dvd player. When I plug
look for a switch to select DVD or Monitor or IN OUT
Posted on Dec 04, 2009
Nc6000 multibay battery does not recharge
Perhaps remove the multi-bay battery, and let main battery charge all the way. Then reattach multi-bay battery, and see if it's recognized.
(Will charge)
That is AC adapter (Charger) removed, then remove multi-bay battery.
Plug AC adapter back into laptop, THEN plug AC adapter into power.
[You do Not want to unplug an AC adapter from a laptop, with the AC adapter plugged into power. Could be a power surge/voltage spike. Unplug AC adapter from power, when plugging into laptop, or unplugging from laptop ]
Main battery charged, unplug power to AC adapter, unplug AC adapter from laptop. Plug multi-bay battery in, then AC adapter.
(Then plug AC adapter into power)
Post back in a Comment.
Regards,
joecoolvette
Feb 28, 2013 | HP Computers & Internet
I plug the DVD player in and then the screen flickers then nothing
I have found that sometimes the wiring harness comes loose from the main board. The player must be dis-assembled in order to access the main board and display board, you may find the plugs have not been properly seated from manufacture and just need to be inserted to hopefully get your system working.
Jan 19, 2011 | Lasonic PDL-305 Portable DVD Player
Laptop battery is not charging
Hi, this information represents a basic troubleshooting guideline. Refer to your user guide for specific charging and connection instructions. Manuals may be available online in the Support Web site of HP.
Remove the battery from the computer.
Confirm the battery contacts are free of any foreign material that may prevent charging.
Reinsert the battery into the computer.
Verify that the AC adapter cord is properly connected and plugged directly into a known working AC power outlet.
NOTE: If the battery charges correctly when the AC adapter is plugged directly into an AC power outlet, but not when plugged into a power strip or surge protector, the problem is with the power strip or surge protector and not the computer battery or AC adapter.
Verify the correct AC adapter is being used.
Ensure the AC adapter box power light is on. This will be an illuminated green light.
If the AC adapter power light is not on, the AC adapter and power cord will need to be replaced.
Verify the charging indicator is illuminated on the computer.
If the issue still exists, install a different compatible HP battery, if available.
NOTE: If a replacement battery charges and operates correctly, the problem is with the first battery.
If neither the original nor a replacement battery charges, service may be required for the computer.
Dec 21, 2010 | HP 417035-001 - HP Pavilion dv2000 Series...
How do I recharge the battery? This is a portable DVD player with a battery pack and the instructions say recharge battery before useing, so I put the battery in place and plug in the power cord and left...
Hello, You are doing it right! the battery should be charged with in the 24 hour period. There are two things to consider : One, is the possibility that the rechargeable battery has dried(due to wear and tear)and is not accepting the charge or The second possibility is that the power supply isn't working properly, therefore, not charging the battery.
It is possible to know at least if one of the two is working just by operating the DVD player while connected with the AC adapter. Turn the DVD on and play a disc, if the unit operates, this eliminates a defective power supply and only leaves a defective battery pack, if it doesn't work than consider the power supply defective and repairs are due. As to where to buy a replacement part is for someone else to answer. Good luck!
Oct 13, 2010 | Lasonic Televison & Video
Batt will not charge, i bought a new one and it not charge up either. plays dvd just fine what is going on?
That simply shows the fault is not from the battery.
Have you checked if the charger is working fine?, first check if the charger is working fine by testing it on another lasonic pdl305 portable dvd player to see if it is working.
If it does not work then you have to replace the charger.
The next thing to check is the charging port, to test this, try to use a tested ok charger on it to see if it works.
If it does not, then you can tell it is the charging port that has a problem. All you have to do is replace the charging port.
That is How you detect the fault and fix it.
Take care
Jun 15, 2010 | Lasonic PDL-305 Portable DVD Player
Battery icon dont show.
Make sure that the battery makes firm contact with the charging connector. I had the same problem, but after cleaning the contacts and pressing the battery towards the contacts, it started working again. It may be necessary to put a thin piece of material between the back of the battery to increase the contact pressure of the battery and the charging connector
Jul 26, 2009 | Creative Labs Nomad Jukebox Zen Xtra MP3...
Dvd player turns disk slowly and gives wrong disk message..won't play
Are there any scratches on the cd? If there aren't. then you might want to bring in your dvd player to the service that you recieved it from and get it fixed.
Jul 01, 2009 | Lasonic PDL-305 Portable DVD Player
How do I charge battery
Simply hook the battery up to the player, plug in the adapter (house AC outlet, car adapter will not recharge batter), and turn the unit off.
The charging light should come on and when it goes out it's fully charged.
Jan 18, 2008 | Durabrand Portable DVD
Supersonic SC-299TDVD
Battery back needs to be connected to the DVD player when charging. connect the batter pack to player. Run the DC/out from the battery pack to the DC/in in the player. plug the charger into the wall.
if that does not work, you have a bad battery
Dec 27, 2007 | Supersonic SC-299TDVD
Lasonic PDL-305 Portable DVD Player Logo
47 people viewed this question
Top Lasonic Televison & Video Experts
JOHN TOPLISS
NOEL
NOEL
Joe Ball
Joe Ball
Are you a Lasonic Televison and Video Expert? Answer questions, earn points and help others
