Question about Hitachi UltraVision CineForm 55VG825 55" HDTV
Hitatchi Ultravision LCD Widescreen acts like it doesn't want to power up
I have a Hitachi Ultravision LCD Widescreen. This morning I had sound but a white screen with two blue lines at the top and the power light turned blue and the temp light and the lamp lights started blinking. Later the tv worked fined. This evening it acts like it don't want to power up. No picture no sound can change input, it's like the tv is dead. Same blinking lights and when I turn off the tv the lamp light stays red. Help! Give me some advice so when I do have it serviced and it comes back I'll know they did the right thing.
  • Anonymous Mar 30, 2014
    it will turn on for about 15 seconds, then the screen goes dead and the power light alternates between blinking fast and slow, like its caught in a loop.
    President:
  • 4,402 Answers
KIT10 $29.50
Repair Kit for Hitachi convergence Chassis DP-14G
KIT10 Includes 2 pcs STK392-150 , 1 each of the following 1W axial lead fusible resistors:
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Posted on Dec 05, 2007
Hitachi 51F710A won't turn on
sounds like you may have had a power surge it may have fried the motherboard...have a tech take a look at it to be sure but i think it got hit by electricity
Jan 04, 2009 | Hitachi UltraVision CineForm 55VG825 55"...
Hitatchi - Ultravision Digital 52" - Pink screen
Good Day,
TRY THIS:
Before you attempt any repairs, it is necessary to make a test. The results of this test will determine which part may need replacing. Please follow the directions.
In short, you will be doing the following:
  1. Perform Memory Initialization. NOTE: You must write down some data values before performing initialize. (See Below for Procedure).
  2. Check this status of the picture. (See Status after Initialization)
  3. The status will determine what part need replacement.
FOLLOW THE ORDER BELOW:
(01)
BE SURE TO COPY DOWN DATA SETTINGS BEFORE INITIALIZING I2C SETTINGS: (See Below)
Select a non-used or blank Video input or tuner to get into I2C menu, also make sure the Power LED on the Front of the set is not blinking at all.
  1. Enter the I2C Service Menu, be sure the power is OFF.
  2. On the front control panel, press and hold the INPUT button.
  3. Then press the POWER button for two seconds.
    • You may keep the INPUT button depressed until you see the OSD with the Service Menu displayed.
    • If you don't see the service menu, please repeat Process making sure you wait until the Power blinking LED stops.
(02)
COPY DOWN THESE SETTINGS:
IMPORTANT: The following are Service Adjustments. These Data Values are lost when Memory Initialization is preformed. It's important to write the values down before proceeding.
H Position: ________
V Position: ________
LCD ADJUST (NOT LCD DRIVE) (Arrow right)
GHOST (Arrow right)> LCD ADJUST =SHP: _______
(Press Select) LCD ADJUST GHOST=R: _______
(Press Select) LCD ADJUST GHOST=G: _______
(Press Select) LCD ADJUST GHOST=B: _______
(Press Select, then Exit)
V COM (Arrow right)> V COM-R: Set For Minimum Flicker
(Press Select) V COM-G: Set For Minimum Flicker
(Press Select) V COM-B: Set For Minimum Flicker
NRSH (Arrow right)> VS-DAT 1 through 9: _______, _______, _______, _______, _______, _______, _______, _______, _______ (Press exit twice) .
I hope this was helpful, big IRISH.
Jul 26, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
50V500A
if the lamp has dies alot of the time to can look inside the lamp and see if it exploded (not always) do you get blinking lights?
Feb 01, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
57t600 wont power up
Both of these problems sound like the 2 convergence ic's. Not something the owner is really able to repair. You'll need to call a svc co.
Jan 27, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
No Red in the picture
Could be faulty red socket along w/ ballast. You need tech to see this.
Dec 15, 2007 | Hitachi UltraVision CineForm 55VG825 55"...
Can't get widescreen back
Model # off the back is......?
Signal source is.........?
HD or otherwise....?
Do any format sizes change......?
Talk to me..........T.
Dec 13, 2007 | Hitachi UltraVision CineForm 55VG825 55"...
Hitachi ultravision digital widescreen
my tv has a magenta pink and green stripe accross the top of screen...is this a bulb problem
Nov 01, 2007 | Hitachi UltraVision CineForm 55VG825 55"...
Hitatchi Ultravision rear projection **NO POWER ***
Usually, when there is no sound, it is because something is not set right in the menu. The fact that the set has shut off completely is quite common in that set. There is a little blue capacitor next to the horizontal output transistor that burns up and blows the small main B+ fuse. Those parts should be replaced by a qualified tech experienced in the Hitachi projection sets who will also check the settings in the menu to get the sound back.
Aug 14, 2007 | Hitachi 50UX57B 50" Rear Projection...
Hitachi UltraVision CineForm 55VG825 55" HDTV Logo
470 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
