Question about Hampton Bay 52 In. Indoor/Outdoor Tahiti Breeze Ceiling Fan
Same problem Found capacitor blown under lighting assembly. took it with receipt to lowes...they said they no longer carry themtoo bad.....
    Genius:
  • 1,550 Answers
Check on Radio Shack
Posted on Jul 03, 2009
Dryer does not turn on
It sounds like your motor has gone bad....it will buzz really bad when it is tring to start and cannot...
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
heatman101
Apr 08, 2010 | Fisher and Paykel DG05 Gas Dryer
Magnavox 50ML8105D/17. We moved and the tv worked fine and now nothing. Just 2 red lights. Temp and Bulb. I replaced the bulb about 6 months ago. all I did was move.I carried it myself. I have checked and...
My magnavox died due to cheap capacitors on power supply board, a common problem for magnavox tv's from wot i found on net!
I replaced a 2200uf 10v electrolytic capacitor and it works now:)
My tv would take a few atempts to turn on and finally would not turn on,light stayed red!
i recommend visually checking for bulging or blown capacitors on power board, if it all looks good, try warming the board with a hair dryer, this might be just enough to get it to fire up, so at least u know the prob is in that area.
I looked for a 2200uf capacitor near the low voltage output from board n replaced it, got lucky first one, I was expecting to replace all the low voltage electrolytic capacitors.
Justin
Feb 02, 2010 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
I have a samsung tv m/n LN52A650A1F. there is power to the back of the tv but it will not turn on. No red light. Tv will not do anything. Thanks Ed
Most likely the power supply board need to be look at. It maybe something simple like a blown fuse. If the fuse check out OK, the next thing to look for is bad capacitors on the board. Most times a bad cap would be swollen and deformed. Should stick out like a sore thumb. Radio Shack or an electronic supply store would carry replacement parts.
Whole replacement board can be found at Shopjimmy.com: http://www.shopjimmy.com/catalogsearch/result/?q=LN52A650A1F
Nov 09, 2009 | Televison & Video
Acer al1711: two monitors with same problem
The most likely cause is blown capacitors on the power supply/inverter board. Go to our web site at: www.ccl-la.com/badcaps.htm we have pictures of what the capacitors look like when the blow out. We also have some dis-assembly guides that may help you. Just open the back of he monitor and look at the board, replace all the blown capacitors that look like the ones in the pictures and you should be back going. The values hat you will need are going to be marked on the sides of the bad caps. Be sure to use a low ESR and high temp replacement or you will have to do this again in a month or two. We carry the proper caps in stock if you want us to supply you with them. The caps at Radio Shack will not do. When you replace the bad ones be sure to install the new ones with the polarity stripe on the side going the same direction as the old ones come out. If you have any additional questions just let me know.
I hope this helps, if you please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
tech@ccl-la.com
Sep 18, 2009 | Acer AL1711 17" LCD Monitor
My Sanyo dp50747 will not turn on
Most likely the TV has a power supply related problem. It's possible that it maybe a bad capacitor or transformer on the power supply board. Or, it maybe something simple like a blown fuse inside the TV.
But, I can't say it's 100% the problem because I can't actually look at the tv over the internet.
If by chance the TV is still under warranty, go that route.
If not under warranty and If you have some electronic experience, if you can find and purchase a Service Manual over the internet; It will help you diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, test points, and part# lists. Usually, cost under $20. And most cases the new part cost less than $15.
I hope I shed some light on the subject for you.
Jul 07, 2009 | Sanyo Televison & Video
Blue light goes to Orange blinking no sound no picture Screen on
Hi!
Okay, if the screen is white! First, take apart and check the ribbon like cable that goes from your signal board (where you inputs are plugged in) to the lcd controller (under a small metal plate feed the lcd screen), see if loose and or reset! Secondly you either have a bad signal board or lcd controller!
Feb 28, 2009 | Westinghouse LTV-30W2 Television
Walmart DVD player freezes images
well i think you got scammed,but since it was inexpensive,cut your losses and buy a new one.remember there must be a reason they no longer carry it.
Dec 05, 2008 | Durabrand Televison & Video
My saw wont run only buzz
Sounds like teh capacitor has blown. These machines use normally use induction motors so they need the capacitor to take a charge and give the motor a kick in the right direction. You could CAREFULLY turn the machine on and spin the blade by hand. If it runs now then you will need a new capacitor.
Oct 14, 2008 | Saws
TV does not not turn on
These flat panel tv's all have a problem with bad leaky capacitors. look for any capacitors ( round cylinder shape with a metal top) that have the top rounded over (bulged up) that part would be bad.
Jan 02, 2008 | Sylvania 6632LG 32 in. LCD HDTV
Hampton Bay 52 In. Indoor/Outdoor Tahiti Breeze Ceiling Fan Logo
168 people viewed this question
Top Hampton Bay Dryers Experts
Steve
Craig Butler
Craig Butler
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
