Question about Radio Communications
GMR1035-2 Cannot get the rx symbol and static noise to stop on the radio. Followed instructions from manual and still doesn't work. Is there a way to reset the radio or a different way to get it to go off of the rx mode???
    Brigadier General:
  • 6,966 Answers
The RX symbol and static noise would only appear if the squelch is down or if you are receiving something from a transmitter.
Receiving something could mean either an intelligent radio transmission from another comparable unit or this could also be spillover signals from adjacent radio transmitters strong enough to override the squelch settings normally called "splatter". At times, electronic devices could cause this effect such as RFI (radio frequency interference) from units such as a personal computer.
It is also possible that your Monitor Mode is "ON", turning it OFF would possibly resolve the issue To turn OFF monitor mode:Press the vol/mon UP or DOWN key. The RX icon will stop blinking and disappears.
In some cases, a component failure would cause this problem. Your GMR1035-2 uses an Automatic Squelch Feature, this would mean the use of a FM Discriminator Chip for Squelch Control. Most manufacturers uses an MC3357P IC chip for this purpose. This of course would require opening the unit, desoldering the suspected component and solder in a replacement. This would further require that you be familiar with electronic components, circuitry, DVM and a low wattage soldering iron. Should you not be comfortable doing this, perhaps your best bet would be to seek the services of a qualified technician.
Hope this be of some help/idea. Post back how things turned up or should you need additional information.
Good luck and kind regards.
Posted on Nov 10, 2007
Rx symbol is displayed all the time and will not switch off.
It sounds like you have CTCSS (tone squelch) or DCS (Digital coded squelch) turned on, but the normal squelch setting is set too low. This will stop scanning, and as the radio thinks there is a valid signal, it will not transmit. I have no idea what radio you are using, but this is a common situation with modern radio's.
Mar 04, 2015 | Radio Communications
One walkie talkie has static on every channel
It sounds like your monitor button is stuck and you are hearing the white noise. Try pressing the monitor button on your other radio and see if the noise is the same. If so, your button is stuck. If not...
Sometimes a lot of static can be an indication of a bad or poorly charged battery. To check for this trade batteries with your known good radio and see if it solves the problem.
Dec 27, 2013 | Motorola Walkie Talkie 2-Way Radio
Static noise rx
Check your batteries. Static can be a sign of a bad or low battery. Swap batteries between the units to see if the problem moves to another radio.
Also, check your antenna and antenna connection.
Best regards.
May 13, 2013 | Uniden GMR-325/2 2-Way Radio Walkie Talkie...
How to get rid of static
Your radio allows you to listen for weak signals on
the current channel at the press of a key.
To turn ON the Monitor Mode:
• For brief listening, press MON button. The RX
icon blinks.
• Press and hold MON button for 2 seconds until
two beeps sound for continuous listening. The
receiver circuit stays open, letting both the noise
and weak signals to be heard.
To turn OFF Monitor Mode:
Press MON button to return to "Normal" mode,
and the RX icon stops blinking and disappears.
Dec 28, 2011 | Uniden GMR22382CK Two Way Radio
Uniden uh064sx-2 2-Way RX Stuck On
Didyou have any luck resolving this issue? We currently have exactly the same problem
Aug 05, 2009 | Uniden GMR1038-2 (7 Channels) 2-Way Radio
Constant RX mode on cobra microtalk PR3850WX
Sounds like the radio was subjected to electrostatic discharge. If you have your manual, and it describes a way to do a "master reset" on the radio, follow the instructions. This usually involves pushing down on one key while turning the radio on. Otherwise you have to find a licensed dealer for factory service, as there is no way to repair the radio yourself. The use of surface mount technology still confuses many Techs unless they have been to a company's two or three week seminars.
Jul 23, 2009 | Cobra Radio Communications
If the antenna for the other properly operating radio is used with the radio with the noise and you are getting the static then we can assume it is the radio. If you hear signals with the static, that is, it does receive communications at the same time, there may be a problem with the noise reduction circuitry, or a defective component(s) in the receiver. Without knowing your experience I would suggest taking to a radio shop.
Oct 10, 2008 | Galaxy Radios DX- 88HL Base CB Radio
I get static after someone else talks
One of the main causes of static can be a bad battery. If you are using rechargeable batteries you need to replace them every 14-18 months. If you are using alkaline batteries, they have been known not to fully power the radio once your cross the 10 hour mark. Your radio would then be operating in somewhat of a brown out. This would lead to static.
Another cause of static is simply being nearly out of range of the other radio(s).
The burst of white noise at the end of Rx on some radios can be rather annoying. On the basic talkabout radios there is nothing which can be done to solve the problem, other than replacing the radio.
Jul 26, 2008 | Motorola Talkabout T5700 AA (22 Channels)...
Radio Communications Logo
1,097 people viewed this question
Top Radio Communications Experts
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
