Question about Maytag PYE4558A Electric Dryer
VERY HOT I replaced our thermal fuses four months ago. Now the same problem again, it does nt work. Before this happened the temperatur of the dryer seeemed excessive.
    Sergeant:
  • 340 Answers
CLEAN OUT YOUR DRYER VENTING SYSTEM. it has to have good air flow.good luck Tom
Posted on Jul 03, 2009
  • 744 Answers
Check the dryer exhaust piping for any obstructions or kinks
Check the exhaust blower
Make sure the lint screen is clean
Make sure the dryer isn't overloaded
Thermal cutoff switch fails 2x in a year. Heating coil ohms out ok.
Whirlpool Thin Twin, dryer thermal cutoff failed twice - Appliance ...
forum.appliancepartspros.com > Appliance Repair Help > Dryer Repair
Oct 12, 2011 - 6 posts - ‎2 authors
Friends Whirlpool Thin Twin came with purchase of condo half a year ago. A month ago it stopped heating. I checked continuity and found the ... Whirlpool Dryer Thermal Cutoff
Jan 9, 2013
Thermal cutoff blew again (Whrpl Elect Dryer)
1 post
Jan 5, 2013
More results from forum.appliancepartspros.com
Why does the thermal fuse keep blowing in my dryer ...
www.shopyourway.com > Manage My Life > Questions
Dec 28, 2015 | Dryers
Lg dryer is overheating blowing the thermal fuse
you have an airflow problem. Check the vent hose all the way out and the outdoor vent hood.
a simple verification can be performed by disconnecting the vent hose from the dryer and see if this solves the problem.
Mar 03, 2014 | LG DLE5977 Electric Dryer
Electric dryer getting way too hot
3-5 ACCESS TO THE BLOWER WHEEL OR THERMOSTATS
To get to the blower wheel, remove the back of the dryer.
The blower wheel is under the bottom of the lint screen duct to your left, as you look at the back of the dryer.
The operating thermostats are at the blower wheel outlet.
In electric models, the hi-temperature cutout thermostat is mounted to the heat riser.
3-6 TEMPERATURE CONTROLS AND HI-TEMP SAFETIES
These clothes dryer machines use operating thermostats to control the temperature inside the drum, and hi-limit thermostats to prevent overheating of the dryer drum.. Many machines also have extra temperature controls, such as bias thermostats and heaters, hi-temperature cutoffs, and thermal fuses.
Bias thermostats are just like regular operating thermostats, except that they are mounted inside a bias heater. When the bias heater is energized, it generates a small amount of heat, which causes the operating thermostat to open sooner, keeping the dryer drum cooler inside. Thus a bias heater allows a single operating thermostat to act like both a hi-temp and a lo-temp operating thermostat.
A thermal fuse is found on the blower outlet, right next to the operating thermostat(s.) This fuse will blow when too high a temperature is sensed at the outlet; usually when one of the operating thermostats has failed. If it blows, the motor may not start, or you may get no heat (no voltage to the burner.)
A thermal cut-off is mounted on the clothes dryer heater box. It is a back-up for the hi-limit thermostat. Whenever you replace it, you should replace the hi-limit thermostat, too. A high-temperature condition causes it to open, an overheated grounded heat element may also cause it to open.
Dec 01, 2013 | Kenmore Elite HE4 Electric Dryer
I have a kenmore electric dryer that wont start..model 110.64642400
the thermal fuse blew for a reason and by bypassing it you most likely damaged the dryer even if it did work temporarily.
Nov 03, 2012 | Cars & Trucks
Replaced thermal fuse 2 weeks ago, went out again, what could cause this?
Look at a couple of things. First and easiest is the air flow through the system. If you do not have any air flow from the dryer vent outlet that is your problem. If you have flow but it is restricted the thermal unit will heat up and "blow out" also. The other item is the thermostat or temperature setting controller. If It is not releasing when it reaches its set temperature the dryer gets too hot and the thermal fuse will blow.
Mar 18, 2012 | Whirlpool Dryers
Difference between thermal fuse and thermal switch
A thermal fuse blows (opens) when the temperature is above the set value. When is blows it will have to be replaced before the circuit is operational again.
A thermal switch deactivates the circuit until the preset temperature is reached or deactivates a circuit that is too hot.
Dec 14, 2011 | Amana NDE2335AY Electric Dryer
THERMAL FUSE BLEW
A blown thermal fuse is an indication of a failed operating (cycling) thermostat. The thermal fuse and the operating thermostat are located on the blower outlet duct to regulate the temperature of the air inside the dryer by monitoring the temperature of the air going out. The cycling thermostat cycles off when the air gets too hot and cycles on when it gets colder than normal. Therefore when it fails to cycle off, the temperature gets too hot and when it reaches the temperature limit of the thermal fuse, the thermal fuse blows.
Apr 18, 2010 | Dryers
Dryer is not heating
i replace the thermal fuse kit 2 month ago and my dryer was working good but 2 days ago stop heating again so i did replaced the thermal fuse again and i did some lint cleaning but this time it only last about 20 min. and stop heating again.what could be the problem?
Mar 01, 2010 | Whirlpool Inglis IP8200 Dryer
Roper dryer stopped working during cycle REX6634RQO
replace your t-fuse again but also chekc to see if the vent going outside is restricted. if hte vent is smashed or clogged the heat has nowhere to go. i would say that is your issue. clean your vent before you change he t-fuse.
Jul 27, 2009 | Roper REX4634KQ Electric Dryer
Dryer fuse and thermistor continue to burn out
how about bypassing the thermistor,you really only need the heater box fuse and high temp. cut out thermostat-mike
Jul 16, 2009 | Kenmore Dryers
Maytag PYE4558A Electric Dryer Logo
90 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Marvin
Marvin
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
