Hi I have an 08 vw jetta 125 tsi the turbo doesn\'t seem to be building pressure properly and gives a wierd rattle at the front of the engine when you take your foot off the accelerator any one have any ideas checked what hoses I could and they seem to be fine the rattle is coming from here may sound **** but what is this hard to find accurate diagrams thanks
I would check the pressure blow off valve to see if it is stuck partially open. check hoses for holes or leaks where clamped. Also if you have a inter cooler for this turbo check it for cracks or leaks a pressure check of air to the cooler then spray with soapy solution to look for bubbles no bubbles after cooler good.
SOURCE: engine rattles at acceleration and hesitates
This sounds like your ignition timing is awry. You'll need a timing light to verify if this is correct. If that's OK the your valve clearances may be a little loose.
SOURCE: code po234 overboost condition 2002 jetta tdi
Don't know much about VW but if it's fine, and it doesn't happen again I wouldn't worry about it. If it does try resetting the ECU by removing the battery terminals and touching the positive lead(red wire) to the negative battery post. It might spark a little, this is just the capacitors discharging, resetting your ECU and starting over. It's like restarting your personal computer
SOURCE: 03 VW Jetta 1.8 Turbo- Check Engine Light- Diagnostic test: 2181
get a new coolant temperature sensor.
the orginal black ones are faulty.
make sure it is the green topped one.
also do a normal tune up with spark plugs, clean the maf, maybe replace coils packs.
