Question about Eljer Toilet Onepiece Canterbury 081162047
Having trouble getting a good power flush.Would you look at the venting situation ? I adjusted the flaaper but still not the best of performance .Thanks Brian
  • 744 Answers
Check the flush regulator - some are adjustable, but if not, they come in 20# and 30# flavors for different water supply pressures. They are located in the tank so you will have to remove the power flush mechanism/assembly to see.
Posted on Jul 03, 2009
Water filter gets water but does not feed ice maker or water outlet.
Good Morning Joseph,
I see that you are having trouble with water dispensing and ice being produced on your Frigidaire refrigerator, even after replacing water filter, model# ULTRAWF, twice. I would suggest to reset your refrigerator, by either unplugging it, or shutting the power off at the circuit breaker for at least 2-3 minutes. Once power is restored try to get water out of the dispenser. If you are still having trouble with the water dispenser, remove the water filter and replace it, making sure you hear two clicks and the filter is flush with the filter housing. If these suggestions do not work, I suggest contacting your local authorized technician for further assistance.
-Best Regards-
WP
Mar 26, 2014 | Frigidaire ULTRAWF Frigidaire PureSource...
Have a pantec cell phone doesn't have good service. Call people and they can't hear me I ready to cancel this contract with att if I don't get help
Venting here is of no value. If you are having trouble with AT&T or any other carrier, you can get help from them. No one here has any power or pull with your cell telephone provider.
Cancel if you want. Many contracts have steep penalties for early termination. Best to try to resolve the trouble than to pay the fine.
Please be mindful, I have no idea where you are writing from and please don't say. I say this to say laws differ from country to country. Still, your best bet it to work a deal with your carrier.
Thank you for your question.
Sep 10, 2011 | AT&T Lands Phones
Model MSD2454GR ice in bottom of freezer. Every day pretty good amount. Small vent on side wall has ice in it also . What"s the problem? Tom
the ice is due to your unit having a defrost issue click this link for more information on this problem http://www.applianceoutletservice.com/appliance-care-tips/refrigerator-tips/refrigerator-defrost-system-information.htm you can also use a hair dyer to defrost your freezer and performing tests on the defrost thermostat and defrost timer and the defrost heater will lead you to which is faulty by performing continuity tests on all. If you have any further questions message me back and please remember to rank how this opinion has helped in your appliance situation it allows me to help others in similar situations thanks Rick
Mar 20, 2011 | Maytag Refrigerators
I've just fitted a Nabis breeze and am having flushing problems.
Well many toilets flush very high before flushing, they appear to almost overflow, but if that doesn't seem like your problem, I would recommend adjusting the float on the Fluid-master fill valve so that there is less water in the tank when it flushes.
Apr 16, 2010 | Hansgrohe E & S Accessories 40526000...
I am having trouble getting the top of the cistern of an Omnia Pro suite. Does the flush button unscrew or clip off.
The flush button should unscrew from the top of the lid. to replace the flush mec. and to remove the lid.
Good luck
Nov 09, 2009 | Villeroy & Boch Home
Troy built tiller starts chugs along and then kills full size mod
I'm sorry you are having trouble with your Troy-Bilt Tiller. I have a genuine Troy-Bilt and I miss the original manufacturer and the help they provided me with my 30 year old machine.
I believe your trouble is in the needle valve adjustment. If you check the bottom of the carb, you will find the needle valve. It should be open about 1 1/2 turns and then fine tuned open or closed a bit to get the best speed. There is the possibility that your carb is dirty inside and could benefit from some carb or injector cleaner. You may also benefit from installing a new spark plug as well. Sometimes, in older engines, you can benefit from using a spark plug one or two heat ranges higher. You will have to experiment with these options to find the best for your situation.
I hope you find these suggestions to be of some benefit.
Thank you for posting your question on FixYa.com
a
Nov 07, 2009 | Troy-Bilt Pony Garden Tiller
BSOD
I found this on the web. pls read below
If you find this information, helpful, pls rate
me. Good Luck.
In most cases, the build up of junk files in your registry is the main culprit of this trouble; this is due to the fact that area in your computer is very crucial because it is the central database of important files where most vital information and programs are stored. The accumulation of redundant items can significantly affect vital data because the build up can dislodge some of them from its proper location and cause others to be corrupted. The moment this scenario takes place, problems start to emerge and the dreaded blue screen of death appear which you need to immediately repair to prevent worsening the case.Consequently, one of the best solutions in managing the situation is to use registry cleaning tools http://make-computer-run-smoothly.com with great power and capacity to completely flush out all junk files and fix all errors found. By effectively keeping this area clean from all trashes, you can also effectively solve the problem and even optimize your computer's performance.
Nov 05, 2009 | Toshiba M200 Tablet PC
Having trouble with the computer....
Found this on the web. If you find this information helpful, pls rate me.
Good Luck
Oct 21, 2009 | RCA L32HD31 32 in. LCD HDTV
I BELIEVE IAM HAVING SOME TYPE OF VACUME ISSUE WITH TOILET
The water in the tank is not filling to the water line, thereby not providing enough water to flush properly. Adjust the float so that the tank fills to the water line
Apr 27, 2009 | American Standard Colony 2388.012.222...
Having problems with consistant flushing. Plumber
The problem is the flapper closing too soon or too late to get the best flush. There are several brands out there that are adjustable. I agree about finding another plumber if he can't fix this, but you should consider buying a new low flow toilet. There are a few brands that have a "Power Flush" tank which uses a pressurized bladder inside the tank to flush the toilet consistently and completely every time. Another upside is the water savings (1.6 gallons versus 4-6 gallons).
Apr 02, 2009 | Eljer Toilet Onepiece Canterbury ...
Eljer Toilet  Onepiece  Canterbury  081162047 Logo
167 people viewed this question
Top Eljer Home Experts
john h
Mike
Charles T Nevin
Charles T Nevin
Are you an Eljer Home Expert? Answer questions, earn points and help others
