Question about Maytag NMPEB08F2A Air Conditioner
Occasionally get a flashing a red light below a warning symbol (and beeping sound). I assumed I needed to empty water from the drain tube. But, after pulling the plug and even tipping the unit backwards, no water comes out. Don't know if there is anything I can do.
  • donnie young May 11, 2010
  • 86 Answers
Clean the drain pipe n drain tray.
Posted on Mar 17, 2008
Machine is set to drain out, but Drain Light wont stop flashing
sounds like the drain is plugged and wont drain all the way check the drain line and see if it is clogeed with something
Nov 20, 2014 | EuroTech EDC158 Electric Dryer
Flashing and beeping red spin light. won't spin
Have you emptied the filter recently. If it's clogged, the machine can't drain or spin.
Nov 15, 2013 | Washing Machines
Symbols on fridge freezer- i have a flashing symbol that looks like a test tube with a rounded end on hotpoint fridge freezer- what does it mean?
Is the water draining from the unit? It sounds to me like that symbol is telling you the water that has accumulated from removing the moisture in the conditioned air is full and needs to be drained.
Aug 03, 2011 | Danby Portable Air Conditioner
The washer will not drain after the rinse cycle
Three main causes for water not draining are listed below:
  1. Clogged drain tube - exhaust or relief tube the hose empties into (does not apply if hose empties into a sink)
  2. Clogged drain hose - occasionally, debris from the wash will find it's way into the hose and clog, backing water up into the machine
  3. Clogged drain pump - like the drain hose, debris gets jammed into the pump. It may take a while for the pump to accumulate enough debris before it clogs. Disconnecting the hose under the washer will occasionally leave enough room to dig out any clogs in the pump. If not, the pump may need to be removed to clear the obstruction.
Jul 24, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
Model 2461 - "check
Power light indicators on flashing red as warning that battery is almost depleted of functionality. ascertain that devices with extension cables deriving power from elsewhere are plugged in to reattain power to acheive regular functionality. For example, devices with red light indication as power warning would also flash yellow or green when in full power charge from another source. refer with devices user guide or manual for refering, diagnostics.
Jul 20, 2011 | Vtech VT 2461 Cordless Phone
After one year of usage my portable A/C drains on the floor approximately 3pint / hr. Unit was raised so that the water can drain into a container without weting the carpet . This situation needs to be...
This is what the manual says:
When the internal water container is full, the back light on the LCD display flashes. The unit will shut off automatically, beep 15 times, and must be drained before it will restart.
To Drain the Unit: switch off the unit and remove the plug from the wall socket.
• DO NOT MOVE THE UNIT. Doing this can result in water
leakage, damaging your floor or carpet.
• Place the drain pan on the floor under the drain cap.
• Remove the drain cap and the rubber stopper from the
drain, and let the water run out. Partially fill the drain pan,
replace the rubber stopper, and empty the drain pan.
This procedure must be repeated until the unit is empty.
• Replace the rubber stopper and drain cap.
Put plug into the wall socket, and switch the unit on.
The warning signal should be off.
For Continuous Drainage: • Switch off the unit and remove the plug from the electrical outlet.
• Remove the Drain Cap and Rubber Stopper. Drain if necessary.
• Connect a Drain Tube (not included) (20mm / 3/4" inner dimension) on to the water outlet.
• Place the other end in a drain. Make sure the tube is free from twists and bends.
The tube must decline over its entire length.
Jun 06, 2011 | Amcor PLM12000E Portable Air Conditioner
Red light flashing on far right symbol/battery or charger going ?
this happiness when you've used the laptop off power for some time. it indicts your battery levels. when the battery level is low to a certain %ge then it warns you before its totally empty. always power up your laptop whenever it lights or save your work in order not to lose unsaved data.
May 26, 2009 | Dell Latitude D600 Notebook
Don;t know what warning light means
hiya susand from what you are describing i assume your engine is diesel ? if so ? the symbol that is on is informing you that the diesel fuel filter is part fullof water do not panic? this is normal and there is a drain **** on the bottom of filter to facilitate drainage of water HOWEVER may i suggest you renew the fuel filter at this stage instead of just draining as winter is nigh and if filter has not been renewed for some time?? now would be good ? it is not expensive and if you know someone with mech knowledge /a friend? male or partner will save £££s on garage charge ? hope this helps and inspires you ?
Aug 11, 2008 | 2000 Hyundai Accent
A/c wont turn on, flashes red light.
I have the same warning light (and beeping) on my M6P09D2A. However, I could not get any water to come out of the drain tube. How did you get the water out??
May 29, 2007 | Maytag NMPEB08F2A Air Conditioner
Maytag NMPEB08F2A Air Conditioner Logo
569 people viewed this question
Top Maytag Heating & Cooling Experts
Bill Long
Are you a Maytag Heating and Cooling Expert? Answer questions, earn points and help others
