Lands Phones Logo
H
Harjit Posted on Sep 16, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi I have Panasonic camcorder hoc-hs700 when turn on camra after few second later message on screen hdd error occurred please turn off unit and on again I have done that several time .but not luck pl
Hdd error occurred please turn unit off and on again done that several time
Nikhow
Level 3:
Dedicated:
Visited the website for 20 consecutive days.
  • Master 436 Answers
  • Posted on Sep 16, 2014
Nikhow
Master
Level 3:
Dedicated:
Answers
436
Questions
0
Helped
129865
Points
1221
Hello there .
Well according to a manual,
Sounds like the Hard Drive is faulty.
"ERROR OCCURRED. PLEASE TURN UNIT OFF, THEN TURN ON AGAIN." is displayed.
The unit has automatically detected an error. Restart
the unit by turning the power off and on.
The power will be turned off in about 1 minute if the
power is not turned off and on.
Repair is needed if it is repeatedly displayed even if it is restarted. Detach the power connected, contact consumer support. ( Do not attempt to repair the unit by yourself
So......why not try a FORMAT of the Hard disk drive which seems to be at fault....nothing to lose friend Worth a try !!!!
Page 142 of this manual http://service.us.panasonic.com/OPERMANPDF/HDCHS700-MUL.PDF
tip
Convert/Edit Panasonic HDC-SD9/HS700/TM700 to Mac, iMovie, FCP. FCE
Panasonic HDC camcorder family has a great number of High-Definition Camcorders that satisfy different people who want to record their interesting daily life, now, You can check the list of popular Panasonic HDC series camcorder as follows:
Panasonic HDC-SD Series: Panasonic HDC-SD9, HDC-SD10, HDC-SD60, HDC-SD100, HDC-SD200, HDC-SD700, etc.
Panasonic HDC-HS Series: Panasonic HDC-HS250, HDC-HS300, HDC-SD60, HDC-HS200, HDC HS100, HDC-HS700, etc.
Panasonic HDC-TM Series: Panasonic HDC-TM10, HDC-TM20, HDC-TM60, HDC-TM50, HDC-TM30, HDC-TM200, HDC-TM300, HDC-TM700, etc.
Most of Panasonic HDC Series Camcorders record video in AVCHD MTS/M2TS files, for example, Panasonic HDC-SD9 records 1080i 17Mbps video in M2TS files; Panasonic HDC-SD700, Panasonic HDC-HS700,
Panasonic HDC-TM700, these three types store videos in MTS format and all offer Full HD 1,920x1,080-pixel resolution at 50 frames per second. For Mac users, if you cannot import Panasonic HDC video to Mac to enjoy, or cannot directly edit Panasonic AVCHD MTS/M2TS files in iMovie, FCP, FCE, you need to convert Panasonic HDC videos to MOV, MP4, 3GP, M4V, H.264 for Mac and then you can edit converted AVCHD MTS/M2TS video with iMovie, iTunes, FCP, FCE, etc.
Mac Panasonic HDC Video Converter, a professional AVCHD Converter, is designed for converting videos collected from Camcorder Panasonic, Canon, Sony, etc to MP4, MOV, MPEG, 3GP, M4V, AVI, etc to Mac, then you can play AVCHD MTS/M2TS, videos on Mac, iPad, iPod, iPhone, PSP, Blackberry, and any other mobile phones.
How to convert and edit Panasonic HDC video to Mac?
Step1: Import Panasonic HDC Video to AVCHD Converter for Mac
Click "Add File" to upload your Panasonic HDC video to Mac AVCHD Converter after you launched it.
Step2: Set Output Video Format for Mac, iMovie, FCP
Click "Profile" to open the Profile drop-up list to select MOV, or MP4 as output video format for Mac OS, iMovie, iTunes, iDVD, FCP, FCE, etc.
Step3: Convert Panasonic HDC Video to Mac, iMovie
Click "Start" button to convert Panasonic AVCHD MTS/M2TS files for Mac. After conversion finished, you can enjoy converted MTS/M2TS files on Mac or edit these converted AVCHD video with iMovie, FCP, FCE, iDVD, etc as you like.
on Oct 19, 2010 • Computers & Internet
Dmc g2 lumix message on screen lense not attached correctly
Try another lens,or set the camera to shoot without lens.This could help you narrow down if it's the lens or the camera.
Receiving this message: HDD error occurred. Turn unit off, then back on again.
Most likely this means your hard drive is having access problems and needs to be replaced.
6helpful
2answers
Panasonic hdc mdh1
My camera mdh1 Error occurred Problum Solution
Panasonic DMR-E80H "u99" error message?
It sounds like the HDD is finished, it could not recover, you could see if a computer repair store can help, they have the tools and the software to take it further, but I would consider cost for the attempt.
My Panasonic strata nvd905u is going into hardware error at the boot screen
Thank you for allowing me to help you.
I'm providing user manuals for quick reference and WE are going to thoroughly cover/troubleshoot the problem. First, we are going to provide the Manuals. PLEASE do not forget to award your best answer.
- Manual for STRATA NVD905U http://service.us.panasonic.com/OPERMANPDF/CNNVD905U.pdf
Here are the steps We are going to start with
1. Cover all Warning steps pages 2-6
2. If your seeing the below error look at the SOLUTION below
ERROR MESSAGE
Hardware error.
Reboot or press reset
switch.
SOLUTION
There was a malfunction in the amp.
 Press the reset switch on the system.RESET SWITCH IS LOCATED ON THE LOWER RIGHT HAND CORNER OF YOUR SYSTEM
IMPORTANT
Push the switch only when the unit fails to operate
with any buttons. (Stored settings and adjustments
are cleared.) If the unit fails to return to normal,
contact the nearest Panasonic Servicenter and have it
repaired.
Note:
 If the ID code has been already set, you will be asked
to enter the ID code right after the unit is restarted.
 A noise may occur when the reset switch is pressed,
but that does not indicate a malfunction.
ERROR MESSAGE 2
HDD cannot be
read due to low
temperature.
CAUSE
The system could not start up due to abnormal HDD temperature.
HDD cannot be 
SOLUTION
Turn off the power and wait for a while before turning the power back on
TROUBLESHOOTING COMPLETE**************
Please do not forget to AWARD YOUR ACCEPTED RESPONSE
THANK YOU KINDLY
Top Lands Phones Experts
k24674
Are you a Lands Phone Expert? Answer questions, earn points and help others
