Tried different rates of flow, nozzle angles, and different gas stations
SOURCE: Gas pump nozzle shuts off off repeatedly when refilling fuel tank
Try and see if the vent hose from the filler neck to the tank is kinked or plugged, if those are ok there must be a gas tank vent solenoid stuck closed.
Replace the filler neck that goes to the tank.
SOURCE: 2004 hyundai accent. trouble filling gas tank
I have a 2005 Hyundai Accent, It is not possible to fill the tank if you are letting the petrol pump run at full speed.Trying to fill up quickly it will only build up pressure and cut off. Next time you fill up just pull the petrol pump handle half way, it will take longer to fill but you wont get the blow back. Modern petrol pumps are getting quicker all the time.Hope this helps you.
SOURCE: 2001 hyundai sonata 4 cl can't pump fuel into tank @ normal rate
The sending unit in your tank is going bad replace it.
SOURCE: Problem with fuel tank filling. Pump nozzle shuts off
get the filler hose checked out as it may have a spring inside it to hold its shape or something has been dropped inside restricting it!
