Cant find air conditioning valve to regas - Heating & Cooling
  • 306 Answers
Is this on a window unit a car a split system a portable unit?
Posted on Jul 03, 2009
Air conditioning ports -to add air conditioning fluid
What you are wanting to add is R134a Freon. The port that you are talking about looks like the same connection that is on your tires. It is called a Schrader valve. They have a cap on them like a tire valve stem. They are located on the air conditioner lines that lead to and from the compressor to the cabin. They are different sizes and if you are not familiar with them, find someone that is because you can get hurt or damage your a/c if you make a mistake.
Mar 11, 2015 | Cars & Trucks
Where is the a/c orifice on a 2003 windstar? where can i find pictures or video of changing a/c orifice?
the orifice is in the TX valve and cannot be changed unless you change the valve unit. That means letting all the gas out and then having to regas the system when finished. This is a job for a auto air conditioner specialist . The TX valve is on the inlet to the evaporator core up under the dash
Mar 23, 2014 | Ford Windstar Cars & Trucks
How do i know if the ac needs to be recharged or replaced in my 1990 toyota celica gts.blows hot air.
Normally, if when you turn on your AC the compressor will activate and you can visually see the pump turning if you look. If it turns, then you can attempt a recharge. If it doesn't turn, then first check the fuse for the AC and if that is good then your compressor might not be any good.
While this is just a quick check, and you system will probably take further diagnosis, it is a general guideline that should get you into the ballpark.
Jun 09, 2011 | 1990 Toyota Celica
Air condition is not cold and air is not strong as before
regas AC and clean or replace the pollen filter
Nov 06, 2010 | 1998 Lexus LX470
Would like to know how to intall an air condition compressor
Firstly de gas the a/c system then remove a/c belt then remove the 2 a/ c pipes to the compressor then disconnect the ac clutch wiring remove the bolts holding the compressor to the cyl block fit new compressor replace the ac pipe orings Then refit the ac pipes reconnect ac clutch wiring refit belt. Then regas the system addind uv dye and comressor oil
Oct 04, 2010 | 2001 Pontiac Grand Am SE
Dear good day i have kia mohave 2009 whene i run the rear A/C it gives me hot air and i cant change it to cold
There might be a simple problem with the cabling or linkage to change from hot to cold or the whole system may need a simple regas to the correct cc's for your vehicle.
I take it the compressor and other components are in tolerance.
Oct 02, 2010 | Kia Amanti Cars & Trucks
My bottom freezer has stopped producing cold air, fan still works, any thoughts ideas, Daniel
if the compressor keeps switching on and off in short bursts, its your gas thats finished. it may need a regas. gas being finished may be from either standing a long time, it being an old freezer, or a gas leak. you'll need a repairman to regas it and also for checking for leaks.
Oct 29, 2009 | Sub-Zero 611 / O Bottom Freezer...
AC trouble
You are low on freon, it needs to be topped up.
Jul 18, 2009 | 1998 GMC Jimmy
Ac woes
When you open car in morning is there a strange smell in it? You can check ac pressure with a tyre gauge should have a filler looks like a tyre valve near ac unit under bonnet check if it has pressure if not you have a leak and need to find and fix that befor regas. If leak suspected (you got not preasure in unit) get ac regasser out and tell him/her you think it maybe leaking and if passenger floor wet and your system still uses freon good chance you have a leak, they should dye the gas and the leak will become very obvious very fast once car started and ac turned on. But if you use freon you may not be able to regas depending on the laws in your neck of the woods. Here in australia if your useing freon and you need to regas you have to change a fair bit to use a legal gas which depends on type of refrigerant unit installed.
Jul 26, 2008 | 1997 Dodge Ram 1500 Club Cab
Heating & Cooling Logo
229 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
