Question about Concord Camera Eye-Q 3341z Digital Camera
Unusable camera I didn't drop my camera. I was taking pictures. They started turning a bluish pixelated color sometimes. Then all of a sudden, it just stopped working. The lens is partially out. and It wont turn on.
All you have to do is take the batteries out for a moment, and then put them back+ turn the camera on and off. This clears the glitch and normal operation will resume. . .
Posted on Jan 28, 2008
JPEG storage reduced
Don't confuse bytes with pixels. A pixel is point of color. A byte is a unit of computer storage. A picture with 10 million pixels may or may not require 10 million bytes of storage.
As an exercise, take a picture outside your window, properly exposed and focused. Now put your camera into manual mode, select a fast shutter speed (1/1000 will do), put the lens cap on, and take a picture. Compare the two file sizes. The first file should have a lot of detail in it and will be quite a bit larger. The second file should be all black. The two pictures will have the same number of pixels, but require different amounts of storage.
In the worst case, each pixel will require three bytes to specify its color. JPEG files will be compressed so it's not quite this bad. At the other extreme, it doesn't take many bytes to say "3872x2592 pixels, every one of them absolutely black."
Oct 31, 2012 | Nikon D80 Digital Camera
Color quality on my Sanyo digital camera 8.1 mega pixel, vpc-t850 is not very good. Its rather bluish. what and how can it be fixed. Thanks.
You may have accidentally changed the white balance. Go into the menu and change it to auto white balance.
Dec 22, 2009 | Sanyo VPC-S880 Digital Camera
Sony Cybershot DSC-S500 bad photo resolution problem
Electronic shutter in lens mechanism got bad and you need to replace complete lens assembly of DSC-S500 camera.
Of course new lens assembly would cost more then camera worth so best option is to buy new camera.
Jul 23, 2009 | Sony Cyber-Shot DSC-S500 Digital Camera
Screen is black, takes picture but no image
Mybe it's the memory card problem. my memory card became unusable, then i had to get a new one and then the pictrues were taken again.
May 09, 2009 | Kodak EasyShare M883 Digital Camera
Pink discoloration and vertical lines in light areas
Possibly a form of flare caused by including the light source in the image.
Jun 25, 2017 | Olympus FE-280 Digital Camera
Pixels instea of clear picture
The problem is with the tape...Never rewind tape in the play mode for some reason it will screw it up.
And only use good tape such as...
Panasonic - MiniDV Digital Video Cassettes Model: AY-DVM80XJ
Dec 01, 2008 | Canon XL1S Mini DV Digital Camcorder
Is my Camera broken?????
u need to set ur cam in the factory defaults^^
Aug 13, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Nikon D200 / photos coming out magenta somtimes blue
Set it to a manual white balance colour temperature, 5200K being an average one to start testing at. Does this make a difference? If not, then the sensor, RGB lightmetering sensor or exposure board may be at fault. The peripheral area of most sensors is used for white balance metering, which denotes a sensor issue, although if the exposure board isn't reading this information correctly, then it will give varying results. However, Nikon's 420 pixel RGB sensor on the D200 may also be taking WB readings. I'll be talking to Nikon soon, but try manual settings first.
Jun 30, 2008 | Nikon D200 Body Only Digital Camera
Night shots using flash giving a bluish color effect.
try reset the camera back to camera defaults by putting dial on p, menu, custom reset
May 16, 2008 | Olympus EVOLT E-500 Digital Camera
Dropped camera, took awful pictures for a while
Possibly who can tell - probably a connector came loose and you smacked it back Lucky old you.
Sep 07, 2007 | Sony Cyber-Shot DSC-P73 Digital Camera
Concord Camera Eye-Q 3341z Digital Camera Logo
52 people viewed this question
Top Concord Cameras Experts
Michael Galve
Michael Galve
Are you a Concord Camera Expert? Answer questions, earn points and help others
