Question about Standard Oregon Chainsaw Chain For Stihl Chainsaw 24" Bar Length 84 Drive Links 3/8 0.05 Gauge Chiesel Chain
Stihl ms-250 won,t start , and gas leaking from under the exhaust manifold , also plug seems not to be spaking even when dry . every time i try to start engine it floods . ?? the saw is only 3 mths old . nb.. always found hard to start even from new..
  • 40 Answers
You may need a carb rebuild kit. they are thin rubber diaphrams and will harden up and warp if not used regularly or if the fuel is improperly mixed.
These are easy to flood if you pull them too many times on choke. Pull it on HALF choke until it pops. then turn the choke off, into the run (I) position and pull it until it starts.
If it's flooded, remove teh plug under the cover, blow off the sparking end and pull the engine a few times without the plug. this will empy the cylinder. WATCH YOUR EYES!
Posted on Sep 17, 2009
I had same problem and symptoms. I was overchoking it. Started fine when I quit choking it. Do as suggested above. Do not use full choke.
Posted on Apr 02, 2010
    Problem Solver:
  • 11 Answers
Check for scoring on your piston. To do this remove your exhaust by removing the retaining bolts then carefully dismantle the exhaust. Be carefull to remember which part came from where! When the exhaust is off slowly pull the saw over looking for any visable marks on the piston(making sure the on/off switch is off). Scoring on the piston can cause all these problems. If there is scoring i'm affraid the saw is knackered.
Posted on Sep 21, 2009
Saw would not start so I bought a new carb and it still won't start. Fresh gas, new plug, etc. How do I determine if I am getting spark to the plug and is it difficult to check the magneto or device that...
I would suggest finding an inline checker so you can visualize the spark without getting shocked for damaging the plug boot.
If your carb is working then when you take out your spark plug it should be covered with fuel. This could be a sign of no spark or it might be a sign of a dirty air filter causing an extreme rich condition. Try starting the saw with a clean plug and no air filter in place to rule this out. If it is dry you either have a fuel line issue or a blocked exhaust. Chain saws have spark arresting screens on them that can load up with unburnt fuel and oil *(from a bad carb or blocked air filter) be safe and good luck!
Mar 07, 2015 | Stihl Genuine Ms 210, 230, & 250 Chainsaw...
Stihl ms 210. Starts ok revs fast then cuts out. Have to re start on full choke then run fast again on 1/2 choke and again stops after 2-3 seconds.
you have an air leak causing the unit to run to fast. The air leak is also over powering the flow of fuel causing it to die. Hopefully you have not tried running it repeatedly like this or you may have done severe internal damage due to running it to lean
If you need further help, I’m available over the phone at https://www.6ya.com/expert/kelly_69a0cf1b13789df1
Nov 19, 2014 | Stihl Genuine Ms 210, 230, & 250 Chainsaw...
Hard pull stihl ms 250
UH OH.......may be engine damage, from over heating or not enough oil in gas.
Dec 22, 2013 | Stihl 16" Chainsaw Bar Chain Saw 018 025...
Stihl ms 250 diagrams
All manuals available at www.stihlusa.com
Mar 01, 2012 | Stihl Garden
Can not start the ms180 chain saw, tried new plug, new gas, starting fluid etc. suggestions ran this morning, and now will not start. only been used twice
Remove the plug and then plug into plug wire. With the spark plug laying on top of engine pull the recoil a couple times and you should see spark at the plug. If all is good and there is the proper mixture of gas/oil ratio in saw then >>With trigger depressed fully and choke on, pull until it fires and then shove the choke in. /////If no spark and the saw is new, I would return to retailer.
Sep 25, 2010 | Stihl 16" Chainsaw Bar Chain Saw 018 025...
How to start stihl ms 180 c
pull choke full on pump petrol 5 to10 times it should try to start take throtle of full to next button and try again
Jul 17, 2010 | Stihl 16" Chainsaw Bar Chain Saw 018 025...
Stihl ms 250 chain saw won't start, doesn't seem to catch spark.
dry the plug asmall squirt of aerostart in the top of carbywith air cleaner off full throttle pull the rope and she should fire up make sure the on/off switch is in the correct position. no don`t laugh ican remember nearly completely stripping amotor years ago before ichecked it put it all back together and it started first go try the aerostart and switch
Aug 03, 2009 | Garden
Code 301, random or cylinder 1 misfire
Spake pluge could have gone bad, or the Spark Plug wire. Try changing all your plugs and wire and inspect the old one's. The wire could be bad do to time or may have been against the exhaust manifold and brunt. Good luck
Apr 08, 2009 | 1997 Dodge Caravan
Stihl chainsaw
I have a stihl ms 180 that leaks bar oil all the time
Aug 31, 2008 | Makita DCS6401 20 20",64cc Chainsaw 2...
Standard Oregon Chainsaw Chain For Stihl Chainsaw 24" Bar Length 84 Drive Links 3/8  0.05 Gauge Chiesel Chain Logo
2,125 people viewed this question
Top Standard Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Standard Measuring Tool and Sensor Expert? Answer questions, earn points and help others
