Question about Arris Wireless G Broadband Router (wr850g)
I need to change the channel on the router
I need to change the channel a motorola router wr850g. It worked fine until the neighbors installed a wifi network. now it does not work.
    Sergeant:
  • 285 Answers
Go to 192.168.1.1, or 192.168.1.2, or 192.168.2.2 to get to your configuration, and change the channal. Also, try changing the SSID.
Posted on Jul 03, 2009
Reset password
The Motorola WR850G is a wireless router that attaches to a cable or DSL modem. The WR850G has two reset options.
Users can reset the router and retain the settings or reset it back to factory specifications to clear all settings.
Resetting the router can help with network issues such as dropped connections.
It can also resolve situations where the user has made changes to the router's settings and can no longer connect to the router.
Look at the back of the Motorola WR850G router and locate the reset button. It is a red button located to the left of the Ethernet ports.
Press the reset button on the Motorola WR850G router, and release it immediately to reset the router without changing the settings.
Press the button on the Motorola WR850G router and hold it for longer than five seconds to reset the router to factory specifications.
This setting resets the router's IP address and subnet mask along with the user ID and password you use to log in to the router.
http://broadband.motorola.com/consumers/products/WR850g/downloads/WR850G_userguide.pdf
May 15, 2013 | Arris WR850G Router (DHWR850G)
Forget my wifi password,and need help,already tryed compgrl
There is a reset option in the back. Press it till reboots and resets all settings. You may need a pen.
Default settings.
Web 192.168.10.1
admin
motorola
Manual:
http://www.motorola.com/mdirect/manuals/WR850G_User_Manual_E.pdf
Oct 10, 2012 | Arris Wireless G Broadband Router (wr850g)
I installed a motorola wr850g and messed up. I cann't reach it using 192.168.10.1 and I can't remember the network authentication information. I reset the router using pushing the reset for 30...
This thread might help you:
http://marasingha.blogspot.com/2006/07/how-to-log-in-to-your-motorola-wr850g.html
If the reset button doesn't work and you can't reach the Router GUI through the address it has given then it could be a faulty router.
The number is listed on that thread and I do think you have the same problem.
This other link is for the router's manual incase you need it: http://broadband.motorola.com/consumers/products/WR850g/downloads/WR850G_6.1.4_Rel_Notes.pdf
hope this helps!
Aug 29, 2011 | Arris WR850G Router (DHWR850G)
I have a Motorola WR850G router which works just fine for broadband internet access for our laptop and our desktop. We are trying to connect xBox Live and we are getting an error message that Maximum...
Starting on page 3-3 of the WR850G user manual, there is a setting for "PPP MTU".
Whether or not this will change the overall MTU of the router is not clear. Apparently the default setting is "0", which I would guess is automatic. I would try changing the setting to 1500 and work your way down from there until xbox live is hopefully satisfied.
Good luck...
Dec 29, 2010 | Arris Wireless G Broadband Router (wr850g)
Wont pick up wifi to my iphone
change the wireless security to WEP or WPA-PSK tkip. Turn on your iphone wireless to pick up the signal
Sep 15, 2009 | Arris Wireless G Broadband Router (wr850g)
Laptop sees the wireless network and connects, but then indicates that there is little or no connectivity. Help
this mostly happens when the router has been configured to block certain devices. take a look at the wifi config, look for IP-filtering or MAC filtering. you should see tables containing letters and numbers. make sure this table is empty
Jun 24, 2009 | Arris WR850G Router (DHWR850G)
I need to get rid of the password protection on my wireless route
Usually there is a little button that you have to use a paper clip to get at that will nuke all the settings and take it back to Default Settings... Just to let you know there are setups now that can easily receive a wifi signal over 2-10 miles and the furthest recorded wifi connection was over 125 miles so you might want to keep those security settings...
Dec 18, 2008 | Arris WR850G Router (DHWR850G)
Router not working as well with D620 as with my older D610
If your router has the external antenna the signal will increase when you point the antenna in the direction where the computer is used the most. It always helps to locate the router in a central area and on the upper floors of a house because the broadcast signal falls like rain. Another trick to try is to change your broadcast channel in the router, the normal default is channel 6. Each channel broadcasts at a slightly different frequency. Hope this helps...Tennis123
Nov 05, 2008 | Arris Wireless G Broadband Router (wr850g)
MTU settings
All of the documentation and firmware updates for Motorola's discontinued products are available in their Discontinued Products section which is here:
http://broadband.motorola.com/consumers/support/default.asp?supportSection=DiscontinuedProducts
Hope this helps. Otherwise repost with specifics and I will activate my second brain cell for your service:) Steve Medley
Jun 24, 2008 | Arris WR850G Router (DHWR850G)
Wirelees lost
If the wireles led is turned OFF, either the wireless is turned OFF in the router's settings or the wireless portion is not working anymore. You may contact contact motorolla for this or your ISP (if the ISP has provided the router) good luck
Mar 16, 2007 | Arris WR850G Router (DHWR850G)
Arris Wireless G Broadband Router (wr850g) Logo
198 people viewed this question
Top Arris Computers & Internet Experts
jimmy Leo
Jerry
Jerry
Greg Ulan
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
