Unlock region codes philips dvp 2850/79
It is not possible to unlock region codes. Most DVD (blue ray players) allow you to change the region code you can play, once. You can't even switch back to the original code it was set when you bought it.
If you really want to play disks, the only way to get around this, to rip the disc on a computer, and burn it on the computer, region free. For that you need special program m's, but in some countries you can get these programs for free.
Or buy several players, each set to a different region.
SOURCE: DVD PLayer Region Unlock
hello mushkil
you could try the following
1. Turn on the unit
2. Open the loading tray
3. Press the "Setup" button on the remote
4. Navigate to the "Preferences" page using the right arrow key
5. Enter 138931
6. You will now see the current region code displayed
7. Use the Up/Down arrow keys to select the region required or "0" for all
regions
8. Press the "Play" button on the remote
this should unlock it to all regions .
riz.
SOURCE: Philips DVD Player DVP 3026 set for Region 5 - Unlock code
1) Open the tray
2) Press SETUP on the remote.
3) Navigate to PREFERENCE menu
4) Go to PBC
5) Get in inside PBC menu so that ON is highlighted with yellow color
6) Key in 138931 and a menu will appear asking you to select region code.
7) Select REGION 0.
SOURCE: Unlock regional code for Sony DVP-NS575P
1) Turn your DVD off. 2) Use the remote control and press:
- Display
- Top Menu
- Clear
- Power
This should power the device into Service Mode.
3) Choose option 2 and then choose option 4.
4) There should be two fields: Input Code and Current Code, each one with 5 chars long.
Type: 12450
Then push zero on all the 5 places of the first and the second field.
Push ENTER.
5) There should be a zero on the device display, meaning that all regions are free.
6) Press POWER to turn it off and you're done.
Let me know if it works!
SOURCE: Unlock region code for Philips DVP 3256
Region code hack for PHILIPS 3256 x/94
1. Go to Setup.
[from remote]
2. Select the Preference Page.
3. Press 1, 3, 8, 9, 3, 1 on the Philips DVD Player remote.
--> It will show current region code [ for example 5 ]
4. Now Press the up/down key to select "0" which makes it region free.
5. Press ok and exit setup.
Probably the same would be applicable for 3258, 3268, 3986.
Good Luck!
