Question about KitchenAid KPTT890 Pro Line 4-Slice Toaster
Left two slot elements don't work. this is the second one with the same problem. both times the left side stopped working after 3 or 4 uses.
  • 145 Answers
Kitchenaid Pro Line appliances do carry a 2-Year Hassle Free warranty with them. While I cannot provide an accurate description of why this problem occurred, there is a good chance they will be able to exchange it for you under the Pro Line Warranty. Please contact Kitchenaid Customer Service.
Their toll-free phone number is 1-800-541-6390.
Posted on Jul 08, 2009
Why do the elements of my stove top work at random?
I would contact the MFG. as this sounds like a bigger problem than you need .
Jan 08, 2015 | Stoves Kitchen Ranges
Our Chef Sapphire Clock & Oven stopped working suddenly after a power failure overnight. Are there any fuses to be found inside, or any other suggestions please. The stove top is fine and all 4...
This oven needs the time set after a power failure. The LED display will read HELPME and there is a small knob on the left side you need to turn it to set to change the time and use the second knob from left side to + and once done leave the knob on manual. The oven can be timed to turn off but it the time is not set on it the oven and stove do not work.dux_training.jpg
Aug 29, 2010 | Ovens
Micro sd card is locked how can i unlock this ?
For the microSD card you'll need the large adapter (picture left side)
to unlock.
Insert the microSD card into the Adapter with the arrow upwards:
put the microSD card directly into the Adapter on the left.
(The Adapter on the right below is miniSD, used for other size cardreader slots)
1. Slide the switch up and down. Repeat this 3 times.
2. Let it stay on the Lock position for 30 seconds.
3. Slide the switch up to unlock the card.
4. Try to put data onto the SD card (Adapter) with the microSD card in,
on the SD card reader slot of your computer
or
Pull out the microSD card and put it in your previous used device, to
see if transferring files will work.
Jul 15, 2010 | SanDisk 2GB microSD Memory Card
I have a lap top Dell Precision M20 and replaced the old ram from the slot below the keyboard with 512 MB by a new with 1GB. It worked fine! Since I bought two times 1GB, I inserted also the second in the...
these different ram slots have different bus speed so they really don't work if you are using them both at once.
Please check your laptop's documentation about the speeds of these ram slots.
Dec 27, 2009 | Dell Precision M20 Notebook
The heating element doesn't work in two of the slots.
If its a Dualit model then you should be able to get it repaired. Generally replacing parts on a Dualit is not easy but spares are usually available thanks to the fact that its one of the most well known commercial toasters on the market. Google and see if there's a repairer in your area.
Apr 05, 2009 | Dualit CTS4E 4-Slice Toaster
Dualit 4-slot toaster - is this how it's supposed to work?
your toaster is working correctly if both are off you are in BAGEL/BUN mode ( did i spell that wrong ? ) in that mode it will only toast the cut side .... Please if this answer helped , please rate this 3 or 4 stars . and keep me in the paid answer department . A 1 or 2 may knock me down into the unpaid ranks. Thanks Cactus Bob
Mar 02, 2009 | Dualit Vario Combi 2x2 65-Slice Toaster
Bake element split and oven will not heat.
thats an eazy one by a new element from one off our links at fixya and install it with the power off and no theres no reason why this happened it just wore out God bless,tom
Jan 01, 2009 | GE Spectra JBP78 Electric Kitchen Range
Video Stops Early
http://www.microsoft.com/hardware/digitalcommunication/productdetails.aspx?pid=007.Everything you need is here.this is a solution.when you vote if this worked vote blue ty.RICHARDM69
Dec 15, 2008 | Microsoft LifeCam VX-3000 Web Camera
KitchenAid KPTT890 Pro Line 4-Slice Toaster Logo
224 people viewed this question
Top KitchenAid Kitchen Appliances - Others Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Appliances - Other Expert? Answer questions, earn points and help others
