Question about Samsung HT-TX72 Theater System
Samsung HT X715 player - while trying to play -stuck on "loading"
Sometimes I insert a dvd and it says NO FILE
5 Suggested Answers
  • 3 Answers
SOURCE: samsung ht-x20 unlock codes
http://www.videohelp.com/dvdhacks/samsung-ht-x20/8981
This should solve it :) I had similar problem. Swapnil
Posted on Nov 04, 2008
SOURCE: regional code for dvd player
Follow the steps below:
1. go to standby mode
2. press stop button for 5 secs
3. blink light noted
4. press "enter", "84269" then "enter"
5. shut down unit and restart
Posted on Feb 16, 2009
SOURCE: My DVD Player (Samsung HT-Z210) displays ?no file?
I have the same problem :S
Posted on Oct 10, 2009
SOURCE: Samsung HT-Z310 tries to load disc, but never does
I've had a similar problem where the disc continues spinning in the "loading" mode and then finally goes to "disc error." So, I opened the cover of the player, and noticed that the disc was not spinning as fast as I expected, and there was an extra unpleasant sound when the disc was spinning. Thus, I suspected there was an issue in the drive motor system: either the motor drive board, the motor itself, or the contact to the disc. I saw that there was dust accumulated on the rubber contacts to the disc, so I cleaned them with a q-tip. I then resetted the system, and the disc was the spinning normally again, and everything worked like before! (Other things I have tried in the past were cleaning the lens and updating the firmware, none of which worked) I hope this helps!
Posted on Nov 23, 2009
My Samsung HT-Z210 Home Theatre System is crazy. Sometimes it plays the disks but most of the times it would sound as if it is trying to load a few times and then displays disk error and if it does play...
Check for fingerprints or dirt on your DVD. Wipe it clean and try again. Also check for scratches. Try another DVD and see if your system reads it. If it does not try cleaning the drive laser lens with a CD lens cleaner available at places such as KMart or WalMart in the electronic section. If that still does not work chances are you laser on your drive is bad and needs replaced. It will need servicing.
Dec 03, 2010 | Samsung HT-Z210 Theater System
DVD not loading/automatically playing. I've cleaned the disc and tried inserting other discs and it doesn't play/load any of them. HELP!!!!
Geek Squad at best buy could figure this out, Cd players are cheap and replacing just that part would be easy.
Feb 15, 2010 | Samsung HT-X710T Theater System
Why won't the samsung blu ray players play all blu
Software on blu-ray players need to be updated occasionally. You may need to visit Samsung's website for instructions on updating the software on your player. This may be as simple as downloading a file or requesting an update disc.
Nov 08, 2009 | Samsung HT-Z310T Theater System
Dvd player reads no disc and than shows loading
Have you tried other DVD's...you might have a bad one.
If so,,,you may need to clean the laser diode. You'll need cottonless swabs (no lint swabs) and Isopropyl alcohol 99%.
Might be hard to get to, depending on the model, but gently swab the diode lens. Don't saturate it tho.
good luck
Apr 07, 2009 | Samsung HT-X810T Theater System
Regional code for dvd player
Reagrding unlock of samsun ht-x715.
Found this
http://www.amazon.com/review/R2FMHKVOZYF6HX/ref=cm_cd_NOREF?%5Fencoding=UTF8&cdPage=&cdERR=noPurchase#CustomerDiscussionsPost
Worked for me with a small change
1. Remove disc from tray.
2. Switch off player and unplug from mains.
3. Wait 30 seconds, then reconnect mains.
4. Turn on player with remote. press the 'Repeat' on the remote for 10 sec'.
5. Press enter on remote. (There will be no on-screen response.)
6. Press 8, 4, 2, 6, 9 on the remote. (There will be no on-screen response.)
7. Press enter on the remote. Player will automatically shut off.
8. Turn player on.
9. Turn off.
10. Turn player on then off again.
11. Player is now region-free.
Dec 30, 2008 | Samsung HT-X715T Theater System
Ht-x30 samsung cinema system display unknown disc
TThe player does not play this type of dvd disk! only pre-recorded movies and CDs Try hooking Up a player that plays DVD+ and DVD- disks!Hope I was of help!
(please use The ratings to keep this site free!)
Dec 14, 2008 | Samsung HT-X40 System
Cannot play DVD's or CD's at all!
Wow, doesnt sound good. My only thought is that on new devices they often have tape and cardboard inserts to protect the device for shipping. Make sure there isnt any tape or packing material stuck somewhere in the device. Otherwise it must just be a bad player. They shouldnt have any problems exchanging it since you just got it. Good luck!
Dec 26, 2007 | Samsung HT-X40 System
Samsung HT-TX72 Theater System Logo
269 people viewed this question
Top Samsung Audio Players & Recorders Experts
Marvin
Marvin
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
