Bad ribbon in your printer or ink cartridge needs to be replace. Also cleaning your printer always helps. Don't forget to check your manual for cleaning guide line.
Do you have any filter or lens protection on? is there any plastic film like those that come with new phone to protect the glass? if so that could be the reason.
Without knowing anything about your Tv make or model this is hard; but there should be a reset button in your menues to restore all settings to factory default. Find and use that. However I am suspicious and think the set needs reapir.
A model number would help here but if it is older and uses 3 picture tubes carefully with the back off and set on does the red one come up and produce a red image?
It indicates a short at the Red picture tube--set has three picture tubes and each has a socket which processes signal to each tube--each has a single IC chip---in your case either the chip on the red board or the red tube.
If a bright red screen the set will detect something is pulling way too much current and shut the set down for protection---called a shutdown circuit.......
60PL9200D/37 When I unplug it for a while and turn it back on, the
picture starts to come on, but it turns dark. And the red lights on the
left and right side of the power button blink. Sound but no picture.
red screen is due to problem in red video circuit.
please check
1 supply to red video ckt.
2 crt base loose.
3 components in red video ckt.
4 loose contact in red cathode ckt in crt base.
5 red video transistor.
6 signal coming to red video from signal processor.
7 signal processor ic.
as per schematic check web site
www.serviceinfo.com
good luck.
if picture is red & DARK PLEASE componemts of red cathode ckt
1 red video supply
2 ckt & loose contact near red ckt
3 red signal is coming to red video from signal processor
4 crt base loose
5 red signal processor ic.
schematic
www.serviceinfo.com
good luck
Sounds like you have two differant problems. A red drive or red picture tube is bad and the conbvergence IC's are bad. To test the red drive disconnect the green picture tube socket BUT MAKE SURE THE SET IS UNPLUGGED!!Then remove the red socket and move over to the green tube. Then turn on the set. If you get the same out of the green then you have a drive problem that needs to be trouble shot for a bad componet. If you do get a picture with the red connected to the green then the red tube is shot. If you know how to read a schematic, get one and then you should have no problem troubleshooting the red drive and the convergence problem. If you dont then there is no easy or quick fix as this is a solid state set and there are no user replaceable parts inside this.,. Your going to need, for safetys sake, call in a trained tech to assist you with this repair
