Question about Electrolux Kenmore 24 in. Built-In Dishwasher with 5-level Precision Direct Water Delivery System Dishwasher
Why would my dishwasher not fill? - Electrolux Kenmore 24 in. Built-In Dishwasher with 5-level Precision Direct Water Delivery System Dishwasher
  • 744 Answers
Check the following:
Make sure the water is turned on to the dishwasher
When you press the start switch, you should hear a "click" which is the water valve opening - if no click, you should check the water fill valve. Remove the lower front cover and find the valve with a water line connected to it. It should be about 3/8" flex or copper line. These valves can malfunction over time and they can also get clogged. You can check for clogging by turning off the water and removing the line to the valve. Check for debris. Use a shallow pan to catch the water so you don't get it all over the floor.
If you don't hear a click when you start the machine, it could also be the control board, although the water valve is more likely to be the issue.
Posted on Jul 03, 2009
My dishwasher won't fill with water. and keeps running even when the door is open.
A defective switch may interfere with your dishwasher's filling ability. Yourdishwasher may not be filling with water simply because the water valve's filter screens are dirty and debris-filled. Gain access to your water inlet valve and try cleaning it out. This might be enough to solve the problem.
Dishwasher Repair Guide - Dishwasher won't fill with water..
or try this link..
dishwasher won fill with water Google Search
Oct 27, 2017 | Dishwashers
Boscsh shu3322uc dishwasher won't fill. If I put
Here is a tip that will help you to find out why water will not come into thedishwasher...
Dishwasher Trouble No Water entering Dishwasher
heatman101
Sep 09, 2011 | Bosch SHU3306UC Built-in Dishwasher
Switch dishwasher on and starts up ok but when it comes to pumping water in it stops and does not do anything else.
Hello
Investigate these five areas if your dishwasher won't fill with water:
As water is filling your dishwasher, a float rises along with it. When the float reaches a predetermined level, it shuts off the flow of water, thereby preventing a leak. Sometimes the float can get stuck in the wrong position in your dishwasher, and it can prevent your dishwasher from filling. Check your float assembly. Replace it if you need to.
The water that fills your dishwasher lifts the float, and when it reaches a certain level, it acts as a trigger for the float switch. The float triggers the float switch to shut off, thereby shutting off the flow of water into the dishwasher. A defective switch may interfere with your dishwasher's filling ability.
Your dishwasher may not be filling with water simply because the water valve's filter screens are dirty and debris-filled. Gain access to your water inlet valve and try cleaning it out. This might be enough to solve the problem. You can learn how to access your water inlet valve in the replace a dishwasher water inlet valve section.
Alternatively, your water inlet valve could be defective altogether. That could be the reason your dishwasher is not filling. Test it for continuity. If it is not functioning as it should, replace it.
Your dishwasher's drain valve is regulated by a drain solenoid. If the solenoid is malfunctioning, it may not allow the drain valve to funtion properly, which in turn could be the reason your dishwasher is not filling with water. Investigate your drain valve and test the solenoid. If the solenoid is faulty, replace it.
Aug 22, 2011 | Dishwashers
Here is a tip the will elaborate on your problem more, but the bottom line is that you need to replace that fill valve...
http://www.fixya.com/support/r4021363-dishwasher_trouble_no_water_entering
heatman101
Aug 02, 2010 | Maytag PDB3600A Built-in Dishwasher
Dishwasher does not fill replaced fill valve still no water
Before fill valve, check the strainer. If blocked with sediments clean it and try.
May 17, 2010 | Dishwashers
No water coming into dishwasher
dishwasher will not fill with water: This is often the fill valve. You can test the fill valve coil for continuity with a ohm meter, no needle movement = bad fill valve. You can also test the fill valve for 120 volts at the fill valve with a volt meter, power there and no fill = bad fill valve. No 120 volts there, you will have to trace power back to find the trouble maker. Test things like the float and float switch, wires and timer. Fill valves are very bad for working once or twice and then quitting, if your dishwasher fills the first and second fill cycles and then no more water through the rest of the cycle, replace the fill valve. You will need to remove the access panels to get at the fill valve. Dishwasher fill valves also have a screen built into the valve entrance, this can also get all clogged up and need to be cleaned. ----- There's no water entering the machine If there's no water entering your dishwasher, check these: Water-inlet valve Float switch Water-inlet valve The water-inlet valve lets water enter the machine. If this valve is defective, you need to completely replace it. It's usually located behind the lower access panel on the left or right side. It's the device with the main water line (usually copper) from the house, a rubber tube to the dishwasher, and two wires attached to it. Float switch The float switch is a small electrical switch that's located right below the dishwasher "floor." Above the switch, on the inside of the dishwasher, is a plastic cylinder that floats up as water fills the dishwasher. If this switch is defective, or if the plastic float gets caught or trapped in the raised position, the water can't enter the dishwasher. If the float switch is defective, you need to replace it.
Nov 03, 2009 | Kenmore Elite 21086
I have a whirlpool dishwasher (gu2500xtpq6) wont fill up
water level should be approx 1/4--1/2 inch below the heating coil.. this is normal fill level
Apr 28, 2009 | Whirlpool 24 in. GU2500 XTP Built-in...
No water in unit
My dishwasher will not fill with water: This is often the fill valve. You can test the fill valve coil for continuity with a ohm meter, no needle movement = bad fill valve. You can also test the fill valve for 120 volts at the fill valve with a volt meter, power there and no fill = bad fill valve. No 120 volts there, you will have to trace power back to find the trouble maker. Test things like the float and float switch, wires and timer. Fill valves are very bad for working once or twice and then quitting, if your dishwasher fills the first and second fill cycles and then no more water through the rest of the cycle, replace the fill valve. You will need to remove the access panels to get at the fill valve. Dishwasher fill valves also have a screen built into the valve entrance, this can also get all clogged up and need to be cleaned.
Dec 14, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
My bosch dishwasher does not fill with water (although it drains)
most bosch have the inlet valve at the end of the fill pipe and it has an anti-flood device.
try turning off the water, take off the fill pipe then reconnect it and see if this works.
taking off the fill pipe resets the anti-flood device
Nov 26, 2008 | Bosch 24 in. SHU53 Built-in Dishwasher
Dishwasher fills and drains at the same time
your water is syphoning out make sure your drin hose is up
Nov 14, 2006 | GE 25 in. Nautilus GSC3400J Free-standing...
Electrolux Kenmore 24 in. Built-In Dishwasher with 5-level Precision Direct Water Delivery System Dishwasher Logo
237 people viewed this question
Top Electrolux Dishwashers Experts
Mike
Starnley Johnwells
Starnley Johnwells
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
