Question about Acer TravelMate 2300 Notebook
Acer Extensa 2300 wont switch on but lights are flashing on/off.
My Acer extensa 2300 has a similar problem. I plug the charger into the back and press the on switch. This lights up normally (green). But I get nothing come up on the screen. The lights on the front (charge and power lights flash amber and green until I turn the laptop off. I have also tried this without the charger plugged in but getting the same response. I dont know if I need a new charger adaptor, battery or something else. Any help would be really appreciated. Thanks!
  • Anonymous Mar 28, 2014
    .Green light on adaptor stable but no dc current at DCjack.Tried another adaptor but with3.16A output nothing happened.Replaced Dcjack with cable nada.There is a visible (melted plastic)next to c104 I think.Do I need a replacement mb or do you think it can be fixed?If it does I can break it apartand get back with details.Best regards and many thanks.
My acer laptop extensa 5620 will not turn on,it is totally dead with no lights showing and no sound coming from the laptop, i have taken the battery out and plugged in the power cord and still nothing
My Laptop wont turn on [Solved] - CCM
ccm.net > Forum > Hardware > Laptop
Nov 13, 2015 - Hello,i need help.my acer extensa 5630ez wont turn on.i tried charging it for hours.it still wont turn on.when its plugged in, the battery led light ... My acer laptop wont start up!!! [Solved] - CCM
Jan 10, 2015
Connecting an external monitor to my Acer [Solved] - CCM
May 3, 2013
Mass storge controller acer extensa 5620 [Solved] - CCM.net
Apr 27, 2011
More results from ccm.net
Acer extensa won't boot. FIXED !! - YouTube
? 0:28
https://www.youtube.com/watch?v=Tb8hzSqWnjs
Apr 1, 2011 - Uploaded by Gen
Watch the fix i used here http://adf.ly/Pnk8u Acer extensa 5420won't boot. ... MADE THE LAPTOP HOT AND TURNED IT ON AND IT WORKED!
Acer Laptop Stops Powering Up- Wont Turn ON - Tech Support Forums ...
www.techimo.com > Forum > PC Hardware and Tech > Technical Support
Jun 5, 2010 - 11 posts - ‎3 authors
Dec 21, 2015 | Acer Extensa 5620 Notebook PC
Acer Extensa 5235 wil not power on
The solution to your problem lies in one of the following three areas:
1.) Your charger is faulty and is therefore not able to pass power to your laptops battery.
2.) The charging connector on the laptop has come loose from the contacts. Therefore a bad connection.
3.) Your battery is faulty.
I think possibility 2 is the most likely, although you will have to test possibility 3 by removing the battery and plugging in your charger and seeing if the laptop powers on.If it does power on then that rules out possibility 1 and 2 leaving a faulty battery.
Replacement Acer Extensa 5235 AC Adapter 65Watt 19V 3.42A
Nov 19, 2012 | Acer Extensa 5420-5687 Notebook
My Acer extensa 5620Z laptop will not turn on
it seems your charger is not working, try to check it with another power adapter
Oct 23, 2011 | Acer Extensa 5620 Notebook PC
I need a registration code for driver whiz ?? or i need a graphics card for my acer extensa 2300 so i can play the sims 2
What is the message when you start the Sim2 game? The setting required to play Sim2 (resolutions). Your Acer Extensa 2300 is a notebook, you can't get a graphic card for it. You need to check that is your inbuilt display adapter has correct driver for that. Go to here http://support.acer-euro.com/drivers/notebook/ex_3000.html and find out what driver you need for your acer.
Hope this help. Thanks for reading
Jul 11, 2011 | Computers & Internet
Acer extensa 4630z was working with broken monitor but when i try to chang it it wont work anymore just when i press power on power led get light but nothing else happin pleas i need help
If you've changed the screen then it's possible it's not plugged in right or is faulty. You could always try and plug in another monitor and see if it works on that.
Sep 06, 2010 | Acer Extensa 4620 Notebook
Laptop Dead, Wont power up
its power button doe not work please change it as soon as possible
Apr 14, 2009 | Acer Extensa 5420-5687 Notebook
I have acer extensa 2300 realtake sound drive i have in internet
Hey,
acer extensa 2300 / 3000 drivers are available at
Let me know if you need anything else.
Thanks,
Ekse
Jul 15, 2008 | Acer TravelMate 2300 Notebook
Reboot
I need more information about the condition as we may not have to totally delete and reinstall software. Have you tried to safe boot and then do a restore under accessories-system-tools-restore?
What have you installed lately?
Jul 12, 2008 | Acer Extensa 503T Notebook
Computers & Internet Logo
341 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
