Question about Saws
I juat bought a craftsman table saw model # 113.19063, would like to locate a owners manual and a miter gage, pluse a place to get replacement parts
    President:
  • 1,996 Answers
The sears online store is at www.managemyhome.com and you can get manuals and parts for some current models there. For older machines, try this website.
Most miter guages are relatively interchangeable, so it's possible a current Craftsman model will work in your miter slots. Just check the depth and whether or not there's a slot in the bottom sides for a key to lock it in place, then compare the depth to the new one you find. There are also aftermarket and specialty miter guages available from the standard woodworking tool catalogs and online. Replacement parts could be an issue.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on Jul 08, 2009
The motor brake on my pro tech miter saw doesn't function. Is there a doable fix ? Also need an owner's manual
The brake on saws like yours are controlled by the switch. They do go bad and are easily replaced if the parts are still available. Your heading says you have a Makita tool but you didn't give the model number. If you go to the Makita home site at:
www.makitatools.com/en-us/Modules/Home/Default.aspx
you can put your model number in the search box and get a parts breakdown and owner's manual if they are still available. Parts are available online at sites like www.ereplacementparts.com where you can also get a parts breakdown but not manuals.
Jun 06, 2012 | Makita 10" Dual Bevel Sliding Compound...
How do you square a miter gauage on a 10" sears
I just turn it upside down and put it in the slot so that the gage rests against the edge of the table. Then tighten the locking knob. This should give you an instant accurate setting as long as the slot in the table is very close to dead-on square with the slot - which it should be. But to verify that it is, just turn the square back right side up and hold a flashlight under it as you hold it very close to the table edge. If the table edge is out of square with the table slot, you will easily see this because the error will be doubled by turning the gage over. By the way, if the rails for your rip fence are in the way, the rails may be parallel enough to the edge of the table to be of no concern. Or you can put a piece of wood with parallel sides on top of the rail between the edge of the table and the upside-down gage. Another easy confirmation is to use a square to draw a line (with a sharp pencil) on a piece of plywood that has a good edge. Flip that square over to confirm that your square is square. Then you can put your miter gage upside down on the plywood to check it against the line. Good luck. Al K
Mar 02, 2011 | Craftsman 10" Table Saw
Looking for Craftsman Table saw Owners manual for model 137.271340
I found a very similar model number on the sears site, on the chance that you misread (or mistyped) the model number. I found the 137271140. Follow the link below, click on the "Search by part description" tab and type in "manual"
http://www.searspartsdirect.com/partsdirect/part-model/Craftsman-Parts/Saw-Parts/Model-137271140/0247/0744600?blt=05
Please vote if you found this helpful. Good luck, Al K
Feb 16, 2011 | Craftsman 10" Table Saw
Have an older Sears Craftsman 10" Table Saw, model
you should be able to order one from sears. another place to look is ebay. the round plastic thing is to mark with pencil the cut of the blade. put in your sliding miter Gage set at 90 deg. put a piece of wood on it, push forward and cut the wood then slide back and mark the wood position on the plastic. that's the point where your blade cuts
Dec 30, 2010 | Craftsman Saws
I am trying to find the parts # for the Miter bar & fence for a craftsmen table saw model#137.248830 could you please help me find these . Thank you, my e-mail address is: beverlysetters@yahoo.com.
The link is the IPL (exploded parts list) for your saw. Part numbers are inclusive.
http://www.searspartsdirect.com/partsdirect/part-model/Craftsman-Parts/Saw-Parts/Model-137.248830/0247/0744600?pathTaken=
We are prohibited from comntacting you directly Beverly.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Sep 01, 2010 | Craftsman 10" Table Saw
I have a craftsman professional model 10" cabinet saw, 3 yrs old. Been working great, just noticed blade is not square to miter guides. Where is adjustment Clfavia@yahoo.com
you can try going to managemyhome.com with your model number for an owners manual for the adjustments that you need. Let me know if you still need assistance.
Aug 08, 2010 | Craftsman 10" Table Saw
I have a Craftsman 10" table saw model number: 137.248830. The saw doesn't make square cuts, it is more of a problem when using the miter. I have followed the alignment procedure so that the right...
I assume that your alignment procedure is about adjusting your miter gage. But you should first verify if the blade is parallel to the miter slot (the slot the miter gage slides in). This is adjustable underneath the saw, and sometimes comes crooked from the factory or comes loose later on. To check if the blade is parallel to the miter slot you can do this.....1. unplug the saw. 2. Raise the blade as far as it will go. 3. Clamp a piece of wood to your miter gage so that it just touches the blade as close to the front of the saw as possible. 4. Use a marker and mark that spot on the blade. 5. Now slide the miter toward the back of the saw, and rotate the blade by hand so that your piece of wood hits the same spot as where you checked in the front. You can see a large misalignment by eye. But you can get a little precise by using a piece of paper between the wood and the blade as a feeler gage. Or better yet, use a drop indicator instead of the piece of wood and you can measure the difference. If this isn't as close to parallel as you are able to measure it, you need to turn the saw over and find the bolts that attach the whole assembly under there to the table top. Once you have this in alignment, you should be able to set your miter to be square against any good square. If you don't have a high quality square, you can go to a tool store (Sears or whoever) with your miter gage in hand, and set it to be square against their most expensive square. If the square is square, and the blade is parallel to the slot and it still won't cut square you either have a bad blade or there is too much play in the saw's arbor. Try to wiggle the blade side-to-side - any wiggle at all is too much.
Jan 20, 2010 | Craftsman 10" Table Saw
The saw blade is 1/16" out of parallel with the miter groove in the table. How do I adjust the blade/motor? Thanks
To be that far out of alignment, there must be something loose. Unplug it, turn it over and look for what it is. If you have a drop-indicator gage, and you can clamp it to your sliding miter gage, it will help you get the alignment dead-on. Slide the miter gage toward the front and back in the slot with the tip of the indicator in contact with the blade. Have the the blade at fully elevated postion. If you don't have such a gage, you can clamp a piece of wood to the miter gage to get pretty close. You will probably have to do this with the saw laying on it's backside so that the top and the bottom are accessible at the same time.
Here's the owner's manual
http://www.hitachipowertools.com/product/files/saws/table_saws/C10RA3_OM.pdf
Here's the parts list with an exploded view
http://www.hitachipowertools.com/product/files/saws/table_saws/C10RA3_Breakdown.pdf
Jan 15, 2010 | Hitachi C10RA3 Electric Table Saws
Have craftsman 12 inch combination miter saw and need owners manu
I found a copy by going to the Sears Parts Direct website, then select the link on the right that says "View Manual". It will take you to the Manage My Home website, where you will find a button for "View Manual".
I would upload to Fixya, but I cannot get the Manual upload link to work.
Dec 14, 2009 | Craftsman Saws
Saws Logo
267 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
