Question about Lowrance Boating
Bought a 1995 Four Winns boat inthe dash it has a lowrance dept finder. under dash i see a 6pin male round connector & 2 pin round male hareness is there a harness i need to connect the 2 or what would i need
I own a 1995 Four Winns and what you need is a Lowrance LSM-1 depth finder unit. It accepts the two pin lead from the transducer and send the depth reading to the dashboard display via the 6-pin connector. There is also a three wire harness (red/blk/wht) that connects to a power supply.
The reason I know all this is my depth finder fried a couple years ago so I removed the Lowrance LSM-1 from the boat in order to find a replacement. Unfortunately, this was an OEM part that is not available from Four Winns or any aftermarket source. Probably your best bet is to look in a boat salvage yard or purchase an aftermarket depth finder.
Posted on Sep 19, 2009
    Problem Solver:
Hi- I have a 1996 Four winns boat with the same problem. I believe we are missing an adapter cable which goes from the depth cable to the instrument panel. I have not been able to locate this cable yet. If I find it I will let you know and can you do the same for me if you locate one?
Posted on Jul 28, 2009
I bought a used boat with a lowrance Elite-4x HDI in May. It worked fine until just the other day it won't power up. I have 12V of power through the power cord to the connector.
Press & hold the + & - key while powering unit on, continue to hold the +/- keys until the unit boots up to warning screen. This don't do it, call support 800-628-4487 and talk to a tech as an "experienced technician". Best luck & good fishin!
Oct 29, 2016 | Lowrance Boating
The depth finder on my elite 5 Lowrance blinks if I go over 14 mph. And the screen gets very hot after a few minutes of run time?
Hey Robert,
the blinking is usually the result of the transducer losing contact with the water..
As far as the screen getting hot.. that is not good.. do you have this unit mounted in dash? It needs some ~cooling.. just some airflow..
http://www.lowrance.com/Root/Lowrance-Documents/US/ELITE-5-7_HDI_OM_EN_988-10647-001_w.pdf
Aug 28, 2016 | Lowrance Elite 5 Color SonarGPS Combo
Pin out for HP Q3110-60009
This is a simple cable, connector for 2 pin power supply, connector for USB 2.0, and male six pin round cable (same as PS/2 Keyboard/Mouse.) I have the scanner and power supply.
tia
Mar 30, 2012 | HP ScanJet 4600 Flatbed Scanner
I cannot find the turnsignal flasher on my 1995 eagle summit wagon.
it is usually under the dash, look for round cylinder about 2" long or a square one about the same size,it will have a connector plug on the top just pull the plug off & replace the flasher unit & replace the plug.....hope this helps.....cheers
Jul 17, 2010 | 1995 Eagle Summit
I have a 1995 four winns,with a volvo 4 cyl.motor3.0
You have a timing problem. Check the timing first. If a simple adjustment doesn't fix the problem, check the plug wires. Make sure they are on the right plugs. If they are, your timing chain or belt jumped.
Aug 30, 2009 | Boating
Lowrance depth finder missing adapter cable
Jul 28, 2009 | Boating
Service and product manuals for the model x85
Here ya' go...all 51 pages of it for the x75 and x85:
http://www.lowrance.com/upload/Lowrance/Documents/Manuals/X7585_91201.pdf
Good unit...I use to sell them when I had my flats boat dealership.
Good luck.....
Apr 06, 2009 | Boating
I need a manual!!
you can find the manual here,
www.lowrance.com/upload/Lowrance/Documents/Manuals/LMS339cDF_iGPS_0152-011_011206.pdf
Hope my info solves your problem,
Thanx for using fixya.....
Oct 02, 2008 | Lowrance LMS-332C GPS Receiver
Installing an old used lowrance fish finder
I don't think your old fish finder is the LMS-332C GPS Receiver listed above in the description. You don't need the speed wheel for the fish finder to function just the transducer and transducer mount. You should mount that on the back of the boat towards the center but not too close to the motor and not too close to the side of the board. Don't let it hand below the level of the boat. That should keep it from getting hit by the trailer or dragging on the bottom. Try to make it as level as possible. The green and white wires may be for the speed wheel but i'd need a model number for clarification. Hope this helps.
Apr 26, 2008 | Lowrance LMS-332C GPS Receiver
Boating Logo
1,028 people viewed this question
Top Lowrance Boating Experts
dduncan54
dduncan54
Level 1 Expert
Phil Walker
Phil Walker
Are you a Lowrance Boating Expert? Answer questions, earn points and help others
