Dell E173FP 17" LCD Monitor
Problem for Dell E173FP 17" LCD Monitor
I have a 1704FPT monitor
By wjmccrthy on Jul 03, 2009
I have a 1704FPT monitor that flickers a little bit then dark. Green light is still on. When I turn the power button on and off, the screen shows briefly, but then dark again. I used a flashlight, I don't see an image.
Best Solution
posted on Jul 03, 2009
Very Helpful)
buddymc
Rank: Guru  Dell Computer Hardware  Expert
Rating: 94%, 350 votes
You have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of he monitor. If you are good at electronics repair/soldering you can usually fix he problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts,replace any that look like the pictues and your monitor should work fine. The capacitors do need to be installed with the correct + and -connections, note the stripe on the old one and insert the new one the same way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping. If your problem is not the capacitors then it would be the backlights and that is much more difficult to replace.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
Was this helpful?
Yes
No
2 people thought this was helpful
Popular Solutions for Dell E173FP 17" LCD Monitor
Questions and Unsolved Problems for Dell E173FP 17" LCD Monitor
Do you recommend Dell E173FP 17" LCD Monitor?
Answer
Answer
power goes out--black screen --in power save mode
Answer
following a Dell E173FP sign popping up inthe middle of my screen it then produces a picture of a... (More)
Answer
how do you eliminate the dell e173fp pop up that reads main menue
Answer
The Dell Dimension XPS 8300 system is automatically disabling the nVidia GeForce FX 5200 driver... (More)
Describe your Monitors problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Monitor Experts
Top Computer & Laptop Repairmen
in Newport, KY
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
