Why am I hearing a low pinging sound in the rear/left suspension in my 92 Chrysler Lebaron when I turn?
My car also seems to be sitting lower on the drivers side intermittently when I am parked and look at it from behind. The suspension seems good when I rock or push my car up and down.
Re: Why am I hearing a low pinging sound in the rear/left...
Its probably the shock/ strut.. i never worked on one of them cars but usually you can take rear shock/strut out through back seat or trunk. You have buy or rent special tool to keep the spring compressed when taking the strut apart.
This vehicle has a air ride suspension option which can read the height of the vehicle, when weight is added the suspension will compensate by appling air to the front and rear shocks. When weight reduced it will lower by venting air from the shocks. If the entire vehicle sits low there is a problem with the air compressor circuit (quite often water in the system and freezes causing damage to the compressor). In your case if only one side is low, check the front and rear shocks, the lowest wheel probably has a leaking shock and can't rise.
sorry but get a proper mechanic to check it out iam not telling you anything because this could cause an accident.Your friend should not have undertaken this work without supervision from a qualified mechanic .
For 1994 Chrysler LeBaron Car Radio Stereo Wiring Diagram check...
Car Radio Battery Constant 12v+ Wire: Red
Car Radio Accessory Switched 12v+ Wire: Red/White
Car Radio Ground Wire: Black
Car Radio Illumination Wire: N/A
Car Stereo Dimmer Wire: Orange/White
Car Stereo Antenna Trigger: Yellow
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Green
Left Front Speaker Negative Wire (-): Green/Yellow
Right Front Speaker Positive Wire (+): Violet
Right Front Speaker Negative Wire (-): Violet/Yellow
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Brown/Yellow
Right Rear Speaker Positive Wire (+): Blue/Red
Right Rear Speaker Negative Wire (-): Blue/White
Before replacing or installing the old belt you need to check all of the pulley's that the belt rides on for play. Pay special attention to the spring loaded tensioner pulley. They can sieze and cause the belt to come off.
I found this picture it is a bit large for the screen.
the owner probably rerouted the fuel line because like my 92 chrysler lebaron v6 3.0 the fuel lines keep seeming to come off and the clamps always break. I have replaced the clamps 5 times in a month and replaced filters 2 times in 2 months. The only thing i could think of is that your fuel is being cut off possibly because there is no filter to clean all the junk out. Try putting a fuel filter on and see if that will work
most likelly you might have an electronis suspension make sure if you do and have it check, sometimes you might see some big black bags and that means you have electronis suspension
