Monitor Turns Black
I have been facing this problem since the very first day i made my computer.
I have a old CRT Monitor and a brand new CPU.
When i plug in the VGA cable and thighten the screws my mouse stops working even the light in the mouse turns off.
So i have to just push the VGA cable in the socket a bit(just that much that it gets the power and signal) and my mouse starts working and everything is fine.
Yesterday when i tried to switch on my system, my CPU turned on , the CPU light is on and fan is running, but the monitor is black.
if i unplug the VGA cable it turns on and i just see light blue light on the screen which i belive is due to no data being provided to the monitor.
I'm very much confused what is causing this and frustrated because i have some urgent work to do but my monitor is black.
I have tried help from other people but nobody was able to help me, depending on you.
    Scholar:
  • 84 Answers
This is nothing to do with CPU but maybe your GPU (Video card) It sounds like you built the machine your self & from what you've said it could be an earthing issue if your screen turns off when you tighten the screws or it might mean that your video card is not properly seated. Try pulling out the video card a re-seating it. Also make sure no cables are touching each other inside the case. It has nothing to do with you CPU of that much I am certain.
Posted on Jul 03, 2009
  • 790 Answers
Hi
you have cold solder to PCB and you have to resolder the Cold solder to PCB
Thanks!
I'm having a problem with my monitor, when i turn it on it goes from a green light to an orange light. If i leave it alone for half a day or a full day (night included) it will turn on and work, for about...
the 3rd CRT this year, you are using relic screens.
why use CRT ever,,
overheating is always a problem with PCs why not fix that first.
the buy real good LED LCD monitor....2010 or newer, never CCFL back lamped LCD, ever.
$39 bucks
https://www.walmart.com/search/?cat_id=0&page=1&query=monitors+&sort=price_low#searchProductResult
Nov 25, 2017 | HP Pavilion MX50 15" CRT Monitor
Screen turns on 1 second then turns black
With a known working monitor try it on the computer. If the monitor stays on then you know the original monitor is bad. If the monitor goes off after 1 second again, then you know that the video card is bad.
Aug 19, 2009 | Samsung Computers & Internet
I have a HPw1907 monitor and it will turn on for about 2 seconds, and it turns off. The CPU is fine, just a problem with the monitor. Any way to fix this?
We have the same model of monitor and had the same problem few days ago. The monitor just goes black/turns off. I noticed that the power button has a yellow blinking light and cannot be turn on/off again using the power button. The CPU is working fine also. When I turn off the avr, the power button's light turns blue for a few second and you can hear a click sound from the back of the lcd before it totally turns off. My lcd monitor is over a year old now and is 110v or 220v capable. Mine was originally in a 220v, i just put it in 110v and the monitor was fixed.. Hope this can somehow fix your problem.
Aug 02, 2009 | HP w1907 LCD Monitor
No Display on IBM G42 CRT Monitor's screen
if u change monitor . you came to know fault of monitor or cpu., if monitor works cpu is not woking properly..some itime we face same problem to creat by changining highgraphic. we can reduce graohic by using f8. re instiling xp we can solve that type of some problem.
Jun 15, 2009 | HP LP2065 (Silver) 20.1 inch LCD Monitor
Switching ON problem for Samsung (SAMTRON 55V 15 in. CRT)
Hi
You just replace the IC 7805 (transistor type ) near microprocessor IC It will solve the problem
- Suhas
Jan 26, 2009 | SAMTRON 55V 15" CRT Monitor
Color problem
There are three Cathod Ray guns responsible for the millions of colors.All colors are produced by mixing the three basic colors namely Red Green and Blue (RGB) at suitable proportion. If any one of the three guns fail firing then we get improper colors. This can be rectified by
(1) hitting the monitor at the back by keeping it on a pillow the screen facing down - it will reolve the problem if the failure is due to the loosening of the Head due to repeated thermal expansion and contaction.
(2) check the signal cable for loose connection, twisting etc on both ends - at the back of the CPU and Monitor (it is fixed)
TRY YOUR LUCK
ProfSweetlin
danielswweetlin@gmail.com
Jul 15, 2008 | Samtron 76df 17" CRT Monitor
Monitor turns off suddenly
I HAVE ONE SAME PROBLEM THE CHIP BOARD IS WORN OUT I RANG SAMSUNG AND IF YOU HAVE WARRANTY THEY WILL REPLACE IT IF NOT I GUESS YOUR STUCK WITH IT LIKE ME AND MINE WAS BRAND NEW 7 DAYS OLD BUT I DIDN'T GET A WARRANTY WITH MINE
Jul 02, 2008 | Samsung SyncMaster 740N 17" LCD Monitor
Monitor is busted!
If your pc works on another monitor. I would recommend you buy a new LCD monitor or a used CRT.
The best solution if your computer works is to buy a LCD screen, I've thrown out my 17" crt screens they aren't worth anything these days. You can get a used crt from ebay
Over here where I live I bought a used crt for 25usd thats was over a year ago.
Theres really no point in trying to repair the screen if its broken, buy a working one or a brand new lcd.
Good luck.
May 21, 2008 | Gateway FPD2275W LCD Monitor
Samsung 793df turned off
did your monitor have a red light on?
just check your CPU in other monitor if ok,
then maybe your monitor is busted.
Mar 12, 2008 | Samsung 793DF 17" CRT Monitor
Computers & Internet Logo
56 people viewed this question
Alun Cox
David Payne
David Payne
