A washing machine vibrates and jumps if it is off balance. Have the transporting pins/locks/bolts been removed when it was installed? If so, then try running it without a wash load (completely empty). If it still has the same problem check that the machine is level and all the feet are on the floor if it is free standing, or properly installed in the cabinet if it is a built in unit. If all is as it should be then I would start to suspect there is a manufacturing fault and contact the supplier.
If it's new... call your store where you bought it. It sounds to me like they gave you a defective one.
SOURCE: samsung washer
please chk out this link
http://www.acmehowto.com/howto/appliance/washer/diagwasher.php
please rate my suggestion...
SOURCE: Sir, Drum of front loading washing machine making banging noise
Mine did that and had to have the washer re-balanced.
First check that the "shipping" bolts have been removed...
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems Washer noise when spinning
heatman101
When
bad...
Washer Problems
Washer
noise
when spinning
heatman101
When
bad...
Washer Problems
Washer
noise
when spinning
heatman101
When
bad...
Washer Problems
Washer
noise
when spinning
heatman101
When
bad...
Washer Problems
Washer
noise
when spinning
heatman101
