Check for fan operation by turning the fan control at the thermostat to "on". If the fan blows, it works. If not, check a circuit breaker or fuse.
If the fan blows when forcing it on with the thermostat but not in automatic, check the fan control circuit in the air handler. Danger: high voltage, beware! There should be a system wiring diagram inside the air handler somewhere.
jbrown - Hot air rises, Cold air falls. If you have ceiling fans upstairs, turn them on to run counterclockwise at highest speed you can stand. Make sure all the windows are closed upstairs. The ceiling fans will help to keep the cool air upstairs and pull some from downstairs.
If you don't have ceiling fans, invest in a box type fan that you can place at the head of the stairs (that's the top of the stairs) run it on HIGH and it will act like an exhaust fan, by pulling cool air upstairs. It may take a while, but it will help cool the upstairs to some degree.
Turn off power to machine and have a 5/16" or 1/4" nut driver handy take off front door of machine. Take a rubber coated Screw driver and place across the terminals of the Capacitor to discharge any stored electricity. Cut wires for blower Black, Red, white, two browns one with white lines on it probably. Look inside machine and locate where bracket holds squirrel cage to air handler and there you will find either 5/16" or 3/8" screw remove pull bracket out. Then you will need a 1/2" socket and a crescent wrench. Remove screws for motor bracket that is attached to squirrel cage. Also you need to loosen the set screw that attaches blower wheel to motor. Apply wd-40 if needed to remove blower wheel from motor. Then install new motor on the flat part of the shaft comes through wheel attach set screw to motor shaft at that position. Install new cap that goes with motor. place entire housing of motor back into air handler and then follow wires that where previously cut back to either relays, sequencers, or fan timer board located in top section of air handler. Tighten everything up and turn power on and make sure air is coming out of vents. Then your good to go.
This is one of those topics that I have seen both ways.
1. The 2004 was the only MY to include an airfilter. 2. The late build 2004 to 2008 could have a dealer installed cabin air filter kit installed.
So don't be shocked if you go fishing for it, and it is not there. On to the directions :
Open the passenger-side glove compartment box. Remove all of the items currently stored in the glove box
Notice two screws on the inside ceiling of the glove box securing the glove box to the dashboard. Use a flat-head screwdriver to remove these screws. The glove box will now be loose. Wiggle the box off the dashboard and allow it to hang.
Locate the rectangular plastic housing; this is where the cabin air filter is stored. Remove the housing cover by pulling it out of place. Remove the dirty cabin air filter by sliding it out of the clips securing it in place. Discard the dirty filter.
Slide the replacement cabin air filter into the retainer clips. Push the filter housing cover back into place until you hear it lock. Place the glove compartment back into place. Replace the two screws that secure the glove box in place and tighten with the screwdriver. Place the items back into the glove box and close the box.
Auxiliary heat is electric heat that is put into the air handler on the inside of the house. Its used when your heat pump doesn't provide enough heat, but heat strips are not always used. To see if you have auxiliary heat, look inside and see if you have breakers on the front panel of the air handler or anywhere close. No breakers, no electric heat. Hope this helps!
Hi, if this is a central system that is split up with the condenser outdoors and the air handler indoors it can be in the indoor unit it self or also it may be in the ceiling or wall near the unit behind a grill for the return air to flow back. Walk around and look for this grill. It is either up high near the air handler close to it, or low on a wall near it. If not out in the home, you will find it in the indoor unit only, nothing outdoors. If you remove a panel you should find it. Please keep me posted and please don't forget to rate me as I no you will be kind. I will check in on you a little later to see if you have found it. Shastalaker7 A/C, Heating Contractor
You need 24 volts going to the coil of the contactor. If you do not have 24 volts, you will need to trace the wiring back to see where you are losing it from. Try placing your voltmeter at C & Y coming from your air handler. If not, go to your air handler and test for 24 volts ac at C & Y coming from your thermostat. If you do not have 24 volts coming from your thermostat, there is either a problem with the thermostat or there is a problem with the wiring between the thermostat and the air handler. If you have 24 volts at the air handler coming from the thermostat but you do not have 24 volts at the outdoor unit coming from the air handler, then you have a problem with the wires between the air handler and the outdoor unit.
I hope you find this information to be very helpful to you moving forward. Please leave a rating. :-)
The Air filter should be located under a grid in the ceiling somewhere in the house. That is where the air in taken and returned after it passes thru the air handler in the attic. There has to be an access to the attic in order to service the air handler if needed. That is Code. Your system, I presume, is a "split system" with the condensing unit outside and he air handler in the attic...
1. often there is a central return in the house. This is the place where the air gets pulled back to the unit and is likely very close to your thermostat. Check for a filtered louvered grill there and see if your filter is located here. If so, you can access the filter by opening the filter frame with a screwdriver or even a coin.
2. Otherwise I would expect that your filter is on the return-air side of your air handler (where the blower is) Older models have the filter actually inside the air handler in the blower compartment. Newer models may have a small separate filter door. I'd look in these areas.
Check to make sure the filter inside the air handler is clean and that no vents are closed or blocked by furnature or rugs. Check the air handler to see if the blower is operating. You could have a belt off, the door switch could be in the open position or something simple like that. If this checks out OK., you will need to have a technician check the charge
