Question about Eclipse CD2000 CD Player
I am trying to connect an I-Pod through RCA inputs located at the back of the unit. I can hear the songs from the I-POD playing, but it is extrememly weak. The manual directs us press the "DISC" button to toggle through sources, however when we hit the "Disc" button nothing happens. Any suggestions?
  • 73 Answers
Turning the Ipod's volume up may help. I had the same issue with a Sony deck in my truck and it was as simple as that! :^ )
Posted on Jul 03, 2009
How can I connect my I pod Touch to my Denon AVR 1803 reveiver?
Connect the 3.5mm cable to the iPod headphone output and the two RCA plugs into any unused analogue audio input on the Denon AVR 1803. Then choose the appropriate input on the Denon, press play and enjoy the music. Be careful about volume. Start with the volume on the iPad low and adjust to suit.
Cheers, Don.
Aug 07, 2014 | Denon AVR-1803 Receiver
I would like to add my i-pod to the receiver so i could listen to the music what kind off cable would i need
An i-pod provides a standard headphone level output. The AVR-1803 has nine RCA stereo inputs that will accept the signal from the i-pod. You need a 3.5mm stereo TRS plug on one end and two RCA plugs on the other end to connect your i-pod to your amplifier. Note: Be careful to select a 3.5 mm plug that has a slim enough plastic moulding to fit into the i-pod headphone output. On your amplifier you simply select the analogue input that you have chosen to use. Be careful of levels when you are setting up. Set the volume of your i-pod to about 50% and set the input sensitivity to zero, press play on your i-pod and gradually increase the gain on your amplifier input. Hope this helps, Don.
Dec 08, 2013 | Denon AVR-1803 Receiver
I have an Optimus STA-3500 Digital Synthesized AM/FM Stereo Receiver. If I buy an i-pod is there a place on the back of the receiver that it can be plugged into? If so, what kind of i-pod wire/cable...
It won't have "iPod" functionality but it can be played through the receiver.
Any audio device that has a headphone output can be adapted to feed an RCA cable pair for standard stereo to any audio device with a standard RCA input (except one labeled "PHONO"). Get a cable like the one described here: http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10218&cs_id=1021804&p_id=665&seq=1&format=2
and connect it into any available analog input EXCEPT one labeled "Phono".
Jul 25, 2011 | Optimus STA-3500 Receiver
I have a bose radio which is 8 yrs old..what i am trying to do is connect my mini I Pod to my bose...I have audio in and outon back of my bose...I tryed a cable which just has to male ends 91.CM AUDIO...
hi,
You need a STEREO to RCA cable for connecting you I pod to the audio input of you boss. you Can connect the stereo jack in the one end of the cable to the I pod and the RCA end to the boss's audio input L/R.
i have added the picture of the cable for you reference.
ok
Apr 04, 2011 | Bose & Wave& Music System
My i pod plays a few seconds of a song and stops!
Your I-pod is in "shuffle mode". To remove it out of shuffle mode, turn the shuffle mode switch to "off" This switch is located on the bottom right side of unit.
Apr 15, 2010 | Apple iPod shuffle Second Gen. Silver (1...
Do you have to have a router to connect your ipod to internet
No you do not require a router to connect your I pod to the internet.
If you wish to load the songs on the I Pod, you can first look for songs on the internet and save them to your computer.
Then you can connect the I POD to the compuet via the USB cable which you would have received with the I pod.
Please connect the usb cable one end on the I pod and the other to the
the computer. The moment you connect the I POD to the computer, the system will detect the IPOD player. You can then save the copy of songs you have downladed on your I POD player.
You can select the sond saved on your compuet by doing a CTRL+C key and then go to MY COMPUTER> and under the drives section it will show your I POD PLAYER. CLICK ON THE PHILIPS PLAYER TO GO INSIDE SO THAT YOU CAN DO A CTRL+V and copy the songs on the I POD player.
That should do the trick and you shoudl be able to listen to your favourite songs on the move.
Please rate me if you are happy with the support provided.
Sep 14, 2009 | Apple iPod touch
Will the Kenwood KDC 1032 RCA outputs work with an ipod adapter similar to an aux output? If so, how?
Hi, if you are trying to get your I-pod to play through your car stereo, then you would need to have the RCA inputs, not outputs. If you connect your i-pod to the stereo outputs it won't work because both things are trying to push sound out of their outputs. If you connect the adapter to the stereo's inputs then it would work.
Aug 11, 2009 | Kenwood KDC-1032 CD Player
I-Pod hook up
I think the red/white RCA plugs on the back of the CDE-7858 are outputs for the sub-woofer -- they won't work for aux inputs like iPod.  According to Alpine dealers, the 7858 will not accept an aux input -- bummer, I had the same desire. R, Jim
Jul 01, 2008 | Alpine CDE-7858 CD Player
Down loading playlists from computer to i pod.
it means the files are lost or need converting
download the latest version of itunes...
connect your ipod, when it appears in the left columb, click on it.
then click autofill at the bottom of of the page.
Dec 09, 2007 | Apple iPod shuffle Second Gen. Silver (1...
Linking an i pod to a Sony CDX-MP40 using the bus input terminal
Some Sony head units let you use the Bus audio inputs as an auxiliary source input, but yours is not among them. To play your iPod through the head unit, you'll either need an iPod interface module: http://www.xplodsony.com/xplod/accessories/XA-110IP or an auxiliary input module: http://www.xplodsony.com/xplod/accessories/XA-300 The iPod interface will allow you to control and display the iPod directly through the head unit, while an auxiliary input adapter will allow the iPod to play through the head unit using the iPod's controls and display.
Jun 01, 2007 | Sony CDX-MP40 CD Player
Eclipse CD2000 CD Player Logo
166 people viewed this question
Top Eclipse Car Audio & Video Experts
xxxxxx xxx
Are you an Eclipse Car Audio and Video Expert? Answer questions, earn points and help others
