Question about Polaroid TLX-01511C LCD TV
Lost audio on channels 25 and 40
All other channels work perfectly. Comcast cable service.
  • 73 Answers
Check your sound settings. It's possible that you have settings set to something those 2 channels can't handle. Interference on those 2 channels could also kill the sound.
Posted on Jul 03, 2009
When connected to cable box will not let cable box change channels with tv on but with tv off cable box works fine
Cable box not changing channels on VIZIO TV - Comcast Help and ...
forums.xfinity.com/.../Cable-box-not-changing-channels...TV/.../164607...
Apr 3, 2013 - I was able to connect my cable box and activate it without an issue. ... My problem lies in that the cable box will not change channels. Channel 8 comes in ..... I just unplugged the DTA ( you already did) and I let it sit for a while. No Audio with cable tv
Nov 15, 2012
remote not working cable box
Oct 13, 2012
Cable box not responding to remote (sporadic)
May 29, 2012
Remote doesn't want to work for the cable box
Oct 19, 2011
More results from forums.xfinity.com
Connecting Cable Service, Satellite Service, or Antenna ...
vizhdtv.com/connecting-cable-service-satellite-service-or-antenna-chann...
Mar 10, 2015 - If you are connecting your cable or satellite box using an HDMI cordyou will ... You just need to change the input of your TV then scan for channels. ... Except the Vizio TV will not receive a channel that all the other TVs get.
Jan 11, 2016 | Televison & Video
No sound on channel 3
Maybe the cable signal is defective not your tv.the other channel is ok.if you tv has a defect all channel has affected.
Jul 02, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
RCA STB7766G1 Converter Box not working with Comcast cables
The RCA STB7766G1 does not support any cable or satellite connections.
Jul 22, 2009 | RCA Analog (RCA) to Digital (USB)...
Poor picture quality on certain channels only
You could try moving it to the other room to see if the connection is bad. Better than taking to the store just yet. If the picture is still bad at both connections I would just bite the bullet and take it back and exchange it while its free.
Hope this helps and let me know if you need more ideas.
Mar 31, 2009 | Televison & Video
Product DMR-EH50, UNABLE TO DOWNLOAD TV GUIDE ON SCREEN SYSTEM.
I think I may have the "answer".
I am in Atlanta and have a Panasonic DVR that was working fine and sometime during the past month or so we lost the channel listings. I've tried many resets as well with negative results.
I called Comcast tonight. The agent helping me took a long time to research the issue and gave me this answer (which sounds reasonable). By the way, this is for the Atlanta area and may not be applicable to other areas of the country.
Due to delays in the conversion to broadcast digital and the fact that Comcast is experiencing bandwidth issues, they have digitized the "channel listing" signal. By mid-June Comcast's signal will be all digital and you won't be able to watch a TV connected directly to Comcast cable - regardless of whether it has digital or analog tuner (or both). This is contrary to what I'd heard before.
After mid-June, you'll either need to use a cable box OR what she called a "Digital Transmitter Adapter" (let's call it a DTA). Prior to being converted to "full" digital, you'll get notification from Comcast. She said I'd be able to get 2 DTAs at no charge (I currently have one Comcast HD DVR box). Additional DTAs would be $1.99 a month. DTAs will only provide access to the "basic" cable channels, but the good news is that the Panasonic DVR should be able to obtain its channel lineup through this DTA box.
If you have any questions, please feel free to contact me directly at richard_gladney@yahoo.com
Good Luck!
Mar 30, 2009 | Panasonic DMR-EH50 DVD Recorder
SETUP ADVICE NEEDED TO INTERFACE WITH MOTOROLA DCH 70 CABLE TUNER
Take a splitter from the wall and plug it in using a seperate line. You wont get all the digital channels but you can get channels up to 150 to record. Depending on how many av outputs you have on the back of your digital tuner you might be able to take one of those those and plug it into the av input of your DVD recorder. You can get a better picture that way when you record from the cable box vs using coax.
Make sure the splitter is approved for digital cable use. The Radio Shack ones work the best and they are usually the same version of the ones Comcast sells to customers. If you get a brand like they carry at drug stores you will lose picture quality and probably end up with a service call bill as well.
Aug 04, 2008 | RCA DRC8320 DVD Recorder/VCR
No sound on NON HD channels
I had the exact same problem on a brand new Insignia 26 " LCD with DVD. Comcast tech was able to fix it by changing the Comcast box diagnostics. Here is what he did. Using the Comcast remote with the TV on - press power, cable, menu in that order. A comcast diagnostic srceen will appear. Select Additional HDMI options, then audio options. Change the audio options to L-PCM. Press power again to exit the diagnostics. That will fix it and you get to use the HDMI cable.
Jun 26, 2008 | Insignia LCDTV26 26 in. Television
No Non-Hd sound
Jun 19, 2008 | Insignia 26 in. LCD Flat-Panel HDTV
No Image on Screen
Since you have a comcast info on screen your system is fine.Call comcast to fix your box.
Mar 02, 2008 | Televison & Video
Polaroid TLX-01511C LCD TV Logo
102 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
