Question about Emerson Fans Emerson 1052466 1000 Watts Microwave Oven
Microwave oven will not turn on. no light, no display.
Will nit turn on. no light, no display.
    President:
  • 512 Answers
First check breaker at breaker panel. Then if you remove the front vent and key pad you will find a paper with breakdown of unit. Look for fuse, check with a tester, if bad replace, if not check all cavity switches, approx 3 or 4, test these. One of these three checks should solve your problem.
Posted on Jul 03, 2009
The light is dim with the door open or closed running.whats wrong?
Lights lowering in the kitchen when turning on microwave ...
diy.stackexchange.com/.../lights-lowering-in-the-kitchen-when-turning-o...
Nov 4, 2012 - Lights lowering in the kitchen when turning on microwave oven: symptom of an ... In the best case, this may be normal if the dimming is minor.
Possible causes of dim Microwave Oven display ' All About Circuits
forum.allaboutcircuits.com > ... > Electronics > General Electronics Chat
Jun 13, 2013 - I've seen some Microwave ovens that will not display a backlight anymore. They still work, but the display is so dim, you have to be inches away to. ...Monitoring the output of a light-dependent resistor, or photoresistor, allows ...
What Is Causing My House Lights To Dim?
blog.1000bulbs.com/what-is-causing-my-house-lights-to-dim/
Dec 21, 2015 | Microwave Ovens
My microwaves display doesnt work. Light inside works and table turns when i open the door. Other than that nothing is working?
The keypad has a circuit board mounted on the inside of the microwave, above that is the display which is tied into the processor ic module. The only way to fix the problem is replace the whole keypad assembly which would cost more than the microwave oven is worth. The only option is to replace the oven at a much cheaper price.
Jan 16, 2011 | Microwave Ovens
Only display on, no cooking power
faulty components i would repolace it if it were mine
Jun 21, 2009 | Kenmore 62462 / 62464 / 62469 1200 Watts...
Microwave lights and display work but microwave
Sounds like the magnetron has failed. There are some high voltage circuits that feed the magnetron and you can potentially get hurt if you don't know what you are doing. Would recommend you have it serviced by a professional if you want it fixed, otherwise look for a new one since the cost of repair can come close to the price of a new microwave oven.
Jun 07, 2009 | GE Advantium 120 Convection/Microwave Oven
No display on microwave touchpad for ge Model JKP62G
The GE JKP62G Microwave / Oven combination has an internal fuse behind the control panel for the microwave. The oven will operate but the microwave will be totally dead (no light, no clock). Turn off the breaker for the oven at the fuse box (30 Amp double breaker). In order to replace the fuse you will have to open the door to the microwave, remove the two screws (Torx) from the front control panel (located on the left edge of the control panel), wiggle the panel to the left (there are two metal tabs that stick into the metal frame of the microwave on the right of the panel) and then tilt the panel down from the top. There is a metal bracket that holds the control panel to the microwave at the bottom (don't remove it). Look towards the top of the microwave inside the area behind the control panel and you will see a 15 Amp screw in fuse. Replace the fuse and that should fix your problem.
Apr 15, 2009 | Microwave Ovens
UNIT CONTINUES TO OPERATE AFTER OPENING THE DOOR
if nit continues to operate whilst the door is open.
then bin it straight away also damage it so that no one else can use it. microwave energy is being transmitted and can cause medical problems
Feb 21, 2009 | Kenmore 63762 Microwave Oven
Siemens HF 87960 GB Microwave/Combo Oven
Please, Can somebody tell me where can I get one of this oven??? Thanks Andy
Dec 08, 2007 | Siemens HF87950GB Convection Microwave...
Emerson Fans Emerson 1052466 1000 Watts Microwave Oven Logo
100 people viewed this question
Top Emerson Fans Microwave Ovens Experts
William Miller
William Miller
Are you an Emerson Fans Microwave Oven Expert? Answer questions, earn points and help others
