Question about KitchenAid KGYS850LT Gas Dryer
Kitchenaid Gas Dryer will not heat. Model KGYS850GQ1.
    President:
  • 512 Answers
Sound like the therm switch under back cover. They are small round and silver with wire on each side, also one is white around 2 inches long with wire attached to each side. check with a tester to see if good, if not jump from one side of wire to other, plug dryer back in and turn on, if it works change switch, this should solve your problem, cheap easy fix.
Posted on Jul 03, 2009
Kitchenaid gas dryer won't ignite and heat. Everything else seems to work fine -- drum rotates, timer works, just no heat. Model# KGYL517BWH1.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Sep 10, 2011 | KitchenAid Dryers
Replaced hi limit thermostat, thermal cutoff and heater, still not getting any heat. motor runs ok. model keys977e elec dryer.
heatman101
Aug 20, 2011 | KitchenAid Dryers
Kitchenaid Superba whisper quiet gas dryer Model # ykgys777eq1 will not heat could be igniter, glow rod or coil help?
heatman101
Jul 31, 2011 | Dryers
Kitchenaid gas dryer model # kgye800swh1 starts, but does not heatup
heatman101
Jul 04, 2011 | KitchenAid Dryers
The drum turns and the dyer blows air. It does not light, when I took it apart the ignitor does not come on. We replaced our gas coils about a year ago. what do you think might be causing the...
heatman101
Apr 26, 2011 | KitchenAid KGYS850LT Gas Dryer
I have a kitchenaid dryer that worked fine all day and then my last load to be dryed no heat not at all
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Nov 23, 2010 | KitchenAid KGYS750LQ Gas Dryer
Dryer continues to heat when door is open
The model number you put up is for a gas dryer, but you said element, so I'm assuming it is actually electric.
If this is in fact an electric dryer, you most likely have a heating element that has shorted to the case. There is a small chance that something else in that circuit has shorted to ground but I doubt it.
If this actually is a gas dryer, please discontinue use immediately and get a licensed tech over there to look at it.
Good Luck
May 16, 2010 | KitchenAid KGYS850LT Gas Dryer
When the dryer is cold the heater flame will
The heating circuit is working perfectly except for the solenoid coils as indicated by the occasional glowing of the igniter but no gas is ignited. A gas valve closes as the solenoid coil weakens as it gets hot and does not open until it has cooled down. Replace both gas valve solenoid coils to get the dryer back into proper operation. The solenoid coils are part numbers 694539 and 694540 but also can be purchased as a kit here.
Apr 27, 2010 | KitchenAid KGYS850LT Gas Dryer
KitchenAid Gas Dryer wont heat everything else
Does the dryer heat at all? turn you dryer on for about 1 minute then open the door, any heat? yes= check to be sure you venting is good and clear. if good then you have 2 common issues i would check first. the thermal fuse could be blown or the gas valve coils could be bad. give me you model number and i can give you more suggestions of what to check and how
Mar 22, 2010 | KitchenAid Dryers
Dryer spins but does not get hot
The problem could be a faulty component such as the timer, heating glow bar, gas coils, safety or operating thermostats. First thing to do is to check the venting to make sure it is not plugged. I cover that more in detail if you wanna check it out.
http://tclaundryrepair.com/dryer
Feb 26, 2009 | KitchenAid Dryers
KitchenAid KGYS850LT Gas Dryer Logo
1,166 people viewed this question
Top KitchenAid Dryers Experts
Tim Whalen
Oloyede Monsuru
Virgil Watts
Are you a KitchenAid Dryer Expert? Answer questions, earn points and help others
