Home | Copiers | I have sc542 on ric...
Copiers
Problem for Ricoh Copiers
Generic problem for all Ricoh Copiers
I have sc542 on ricoh mpc2000. How can i f...
By rwilcox on Jul 03, 2009
i have sc542 on ricoh mpc2000. How can i fix locally quick!?
Best Solution
posted on Jul 03, 2009
Very Helpful)
tino84
Rank: Master
Rating: 90%, 12 votes
This error code is related to the fusing unit within the machine so if you are unable to clear it by what I'm about to tell you or if it persists to appear then you will have to contact someone to come out and look at it for you.
press your yellow clear all key,
press 1 0 7
then press and hold the red/orange stop/cancel key for about 5seconds.
once you have done this successfully you will get a change in the display, you will have a box with COPY SP in it. Once you have this box switch the machine off at the wall and leave it off for a few seconds then switch it back on, all should be ok now.
If the code comes back straight away you have a problem and need to contact an engineer.
Good luck
Was this helpful?
Yes
No
3 people thought this was helpful
Popular Solutions for Copiers
Questions and Unsolved Problems for Copiers
Answer
conica minolta bizhub 35o vs kyocera in same price range
Answer
my brother mfc 210c says it will not clean
Answer
I am trying to scan a document, save it and then send it a an email attachment
Answer
Hi can you tell me what are the setting to use with a computer thanks
Answer
our scanner is not scanning to the share file.error"file storage error"
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Ricoh Copiers:
Top Copier Experts
Rank: Guru Guru
Solutions: 1507
Experience: The Truth is a set of corrected errors. Erwin Schroedinger
Ask Me
Find more Copier Experts
Top Copier & Fax Repair
(877) 434-9747
Full service mobile shredder repair service to...
Pacific Coast Shredder Repair
(800) 816-6855
Over 50 years in the office equipment repair &...
EBS Scantracker
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
