Question about Casio Exilim EX-S600 Digital Camera
SD card not working on EX-Z1 Exilim cammera?
Whenever I insert the SD card, it's still not letting me take any more pictures than the cameras memory. Am I doing something wrong? Do I need to turn something on so it would be stored on the SD card not on the camera?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Casio Master
  • 102,366 Answers
Are you sure you have an SD card, 2GB or smaller? The S600 will not work with the higher-capacity SDHC cards.
Posted on Jan 16, 2013
  • 641 Answers
SOURCE: Casio Exilim won't turn on when memory card is inserted
It sound like a bent pin issue. Look at the bottom of the memory card slot, you probably bent one or more of the contactor pins. Use a small screwdriver and carefully try to straight the bent pin then carefully put the memory card back in. From now on, use a USB cable for downloading your pictures and don't pull the card out anymore as the pin is probably weaker than before and can break. Good luck !
Posted on Aug 22, 2007
  • 374 Answers
SOURCE: Casio Exilim EX-Z55 - SD card compatibility
A 1 GB card is the highest that you can go with this camera.
Posted on Jul 14, 2008
SOURCE: casio exilim z750 sd card unreadable
I have the same problem, the card when removed works fine on vista laptop, but not on windows xp machine, so it not necessarily the card. still looking for solution.
Posted on Nov 22, 2009
SOURCE: Exilim ES-X3 "System Error"
System Error
Posted on Feb 15, 2010
  • 73 Answers
SOURCE: i have a Casio EXILIM EX-S10 "Memory Full" Error
Firstly, charge your battery fully. This should solve the switching off. It sounds to me like your card isn't in correctly, or is incompatible, and your internal memory is full. (it usually only stores a few photos for emergencies) Have a look at the type of card you have. If it says SDHC, or is 4GB or larger, it is not compatible with your camera and you need to get a 2GB. If not, it may not be inserted correctly. Push it all the way into the slot and it will click when it's in properly. Then try formatting it. Press review (where you look at the photos) and scroll down to setup- then look for 'format' and press okay. This should sort everything out. You can also copy the photos you've taken in the meantime from the memory to the card by pressing copy in the review menu and scrolling to the right. Hope that helps
Posted on Jul 26, 2010
Exilim camera memory full when few pictures taken
Have you fitted a memory card?
The camera will only take a few photos using its own memory.
It takes: SD Memory Card, SDHC Memory Card , SDXC Memory Cards.
If you have fitted a memory card it may be faulty and you will need to buy another.
Jul 27, 2014 | Casio Exilim Ex-h30bk Ex-h30 Black Digital...
I have a casio ex z500. I bought a 8gb sdhc card and it didn't work, so I downloaded the 1.02 version. It takes pictures but now when I insert the card in the memory slot on my computer, the computer is...
The EX-Z500 works with MMC and SD cards. While SDHC cards will fit into the slot, they are electronically incompatible and will not work with this camera.
Feb 26, 2011 | Casio Exilim EX-Z500 Digital Camera
My cammera is locked i dont know how and why i try to take picture it says THE CARD IS LOCKED i turn it on it says the same i pretty much cant do anything, how can i unlock it or fix it????
SD type cards have a little switch on the card that can write protect or "lock" it. Take the card out of the camera and check this switch. To unlock it, it should be moved towards the edge of the card which has the electrical contacts.
There is also a software protection feature on some cameras, but this is used to protect a folder or individual picture from accidental deletion, not the whole memory. You set or release this protection from the camera menus.
If it is not that, then maybe it is having trouble with the size of the memory. Memory cards have grown enormously in capacity in the last couple of years, and even relatively new cameras may not be able to cope with the memory size of the newest cards. Have you tried formatting the card in the camera? This would be one way of making sure that the camera can cope with the card, and it will also erase anything on the card. "SD" cards larger than about 1GB are actually SDHC cards. SD and SDHC cards fit the same slots, but they are slightly different electrically. Many cameras won't work with SDHC (high capacity) cards. SDHC is not backwards compatible.
Jan 08, 2011 | Casio Exilim Zoom EX-Z80 Digital Camera
MY DIGITAL CAMERE MEMORY IS FULL, WHEN I TURN ON MY CAMER IT SAID MEMORY IS FULL. I DON'T HAVE A CARD INSERTED IN BECAUSE WHEN I PUT THE CARD IN IT WON'T COME ON AT ALL. IT ONLY COMES ON WHEN I TAKE OUT OF...
camera's onboard memory is only 8MB, maybe 1 or 2 high resolution photo. delete the photo on the camera to clear error message and use only no more than 2 gig of sd card. It does not work with higher than 2 gig which is SDHC type sd card.
May 20, 2010 | Casio Exilim EX-Z55 Digital Camera
The camera works fine without a card in, but when the memory card is put in it doesnt. i changed the card and no difference. PLEEASE HELP
The cause and solution may include one of the following:
  1. The card may not be certified SD. Please purchase a certified SD memory card. For example: Sandisk, Toshiba, Panasonic, etc.
  2. The card may be corrupt. Reformat the memory card.
    CAUTION: Formatting deletes all pictures and videos, including those that are protected. Removing a card during formatting may damage the card.
  3. The card is not fully inserted in the camera. Turn off the camera, insert a card into the slot, then push to seat it.
Feb 13, 2010 | Casio Exilim EX-S500 Digital Camera
I have pictures on my casio exilim, ex-z80 ans want to transfere them from the camera memory to the sd card memory inside the camera. is that possible?
look intothe manu ...go to one of the picture you want to transfer ...and check all features...if it has something like save on card or so ...or move to... ...that is the one that will do the job ...if not ....just download to pc...and than insert the card on the card reader and upload pictures on the card directly ...
you can do the same job without a card reader ... by looking for the card on my computer after the camera is attached...it will be something like camera ...(folder) or ..removable drive ...or rem. storage device ...it will behave just like a partition ...copy the picks along the others that ya know for sure that are on the card...
Oct 03, 2009 | Casio Exilim Zoom EX-Z80 Digital Camera
Aug 04, 2007 | Casio Exilim EX-Z57 Digital Camera
Camera will not read memory card
Make sure you format your memory card before you try to use it other wise it will save the pics to ur internal memory instead of the mem card.
May 01, 2007 | Casio EXILIM ZOOM EX-Z10 Digital Camera
Casio Exilim EX-S600 Digital Camera Logo
51 people viewed this question
Top Casio Cameras Experts
mohamed salim shaikh
pontelemon
pontelemon
Are you a Casio Camera Expert? Answer questions, earn points and help others
