Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Engine trouble my engine will start with the choke up but as soon as I shut the choke off, the engine dies.
  • 376 Answers
The problem is going is most likely in the carburetor. It needs to be cleaned/repaired. There's a restriction in the gas flow, probably from varnish, rust and/or water build up in the carb. Hope that helps.
Posted on Jul 03, 2009
1985 Ford Ranger 2.3 starts and idles good. But when put in gear dies until it reaches full temp.
Hmm...........
1985..........
Probably carb? Automatic choke not working? Remove air filter and spray carb with cleaner, Make sure all parts move freely. With engine cold, check automatic choke position. Start and check function as it warms up.
Feb 21, 2016 | Ford Cars & Trucks
Automatic choke will not shut off once the engine is running so engine dies. Could it be a spring is missing ?
There is a diaphram that the link connects to the choke. It is between the carb and the gas tank, and runs by the vacuum from the engine. B&S engines have to rev up for the choke to open all the way.
Sep 20, 2014 | Cub Cadet Garden
I have a 92 s10 blazer won't stay running I have replaced plugs wires distributor capcomputer moduleand nothing helped as soon as it warms up just a little bit it will start spitting and then die help...
Check the throttle position sensor. The fuel injector used for the choke is the only thing keeping the engine running. As soon as the engine warms up, the computer shuts off the injector causing the engine to starve.
If you need further help, reach me via phone at https://www.6ya.com/expert/scott_843b43f7ebebd3f5
Jul 18, 2014 | Cars & Trucks
5.5hp honda engine dies when choke is open
There should be a fuel adjustment screw, it's probably getting too much gas.
Dec 18, 2012 | Motorcycles
I have a 1985 honda goldwing gl 1200 aspencade i can start the bike it runs fine as soon as it get warm the oil light in dash comes on and motor shuts off i have change oil and filter and the oil pressure...
Hi Most likely your engine shut off first then the light goes on as soon as the engine oil pressure dropped sounds like you have a carb problem and the motorcycle is running on the choke circuit. then it dies after the choke is turned off.
Oct 24, 2012 | Motorcycles
The engine sputters and dies when it heats up. Is this Vapor lock? On cold start it works great and idles just fine but as it heats, the engine starts choking and soon dies out. If this is vapor lock, how...
sounds like the reason it starts and idles fine at start up is your choke is functioning... as your vehicle warms up.. the choke starts to kick off... Inspect your throttle body and idle control motor.
Aug 05, 2010 | 1986 Ford Bronco II
Lawn mower stays running on jumper cables but once disconnected it shuts down when choke is engaged
if it is already running and you "engage" the choke, you will flood the engine with too much gas and it will sputter and die. the only time you engage the choke is to start the engine when it is cold. if the mower dies when you remove jumper cables, and you leave the choke alone, you need to have someone look at your charging system.
Apr 08, 2010 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Bike wont idle or start
try turning the idle up and when you do it give it a little bit of gas
Aug 16, 2009 | 2003 Yamaha YZ 250 F
Truck losing power and service engine soon light on
Like to other guy said, give it a tuneup. Also try SEAFOAM to clean carb up of slug. Also check to make sure the butter fly for the choke has not come loose, causing it the choke it down. Failed choke pull-off.
Dec 10, 2008 | 1995 GMC Sonoma
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
112 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
