Question about Jenn-Air JCB2059G Bottom Freezer Refrigerator
Our botton freezer keeps freezing up then the refrigerator keeps warm. we have replaced the defrost timer but still having the problem
  • 4,070 Answers
Now check the defrost heater and defrost thermostat. http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Posted on Jul 03, 2009
Refrigerator not defrosting?
you are describing a problem that has 2 causes at the same time;
if your drain tube is freezing up, you usually have a defective drain heater, easy. to replace.
the warming up is due to accumulation of frost on the evaporator.
the defrost system contains 3 components - defrost heater, defrost thermostat and defrost timer. First try to advance the timer into the defrost cycle, if you hear crackling in the freezer and it start to defrost, you have a bad timer (very common problem) if not, you must check the defrost heater and thermostat or just replace both...
good luck
Dec 21, 2014 | Refrigerators
AMANA SIDE BY SIDE refrigerator/freezer . Freezer freezes intermitently, and then stuff thaws. Cleaned the botton coils, didn't help. unplugged and re-booted. didn't help
HI.intermitent faults r allways abit problematic .but run through some basics ok?1-after defrosted freezer works ok?2-how long for.if ok then all u can do is change defrost timer and t/stat one at the time or together.clean condensig unit thoroughly.good luck.ali
Jul 05, 2012 | Amana Refrigerators
Frigidaire side by side model # FRS20ZRGW3 coils freeze up on freezer side, fridge side gets warm
You have a defrost timer behind the front kick plate turn it clockwise slowly until compressor and fans stop. Once this happens the timer should remain off for 30 minutes and the defrost heater should come on during the first 15 minutes. If after 30 minutes the defrost timer part=> 215846602 Defrost Timer Assembly should come out of defrost and the compressor and fans should restart, if not advance the timer clockwise until they start and replace timer. Try that first and tell me what your results are. If that is not the problem then we can narrow this down to the defrost heater=> 218657301 Defrost Heater or 5303917954 Defrost Thermostat How to test the defrost heater is found on same page as the defrost heater. If you have any questions I will be here to help you, Thanks Sea Breeze
Apr 22, 2012 | Frigidaire Refrigerators
Coils in freezer - freezes up and the refrigerator gets warm.. replaced the defrost timer and the coils are still freezing up.
the timer tell it when to defrost but the defrost terminator and heaters must be working . ( you probley need the heater. and if so replace the terminator also .. mm
Jul 03, 2010 | Refrigerators
Ref/Freezer will not defrost. Keeps freezing up inside both unit
one of three components have failed, either the defrost timer, defrost thermostat or the defrost heater. Find the timer and turn it into a defrost, you should hear the heat crackling in the freezer section. This is a problem easily fixed by a technician
Jun 13, 2009 | Refrigerators
My freezer coil keeps freezing up. I replaced the
In the freezer coil is a defrost heater coil, and a defrost thermostat. You have to expose the freezer coil to find them. If your local dealer can't get parts, I get mine from Repairclinic.com.
Apr 29, 2009 | Kenmore Refrigerators
Kenmore fridge side by side keeps freezing up
defrost problem,check,freezer fan,remoce freezer back panel,check heater,find and check defrost timer,most are in the frig.if it is manual put it in defrost then check to see if the heater ib the freezer comes on,if it does then you have a bad defrost timer,if not,the freezer heater or terminater(attached to coils)is bad,chevk with your meter,let me know-mike
Feb 03, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Freezer back panel freezes up
hi thanks for the question the problem you have is with either the defrost termination switch or the timer the defrost termination switch is located in freezer a small disc with 2 wires going to it replace this part thanks the appliance doc
Aug 14, 2008 | Frigidaire FRS23KF7AB Side by Side...
Freezer drain
I thinkyou just need to take a look at replacing the defrost timer. Sounds to me as if the defrost timer is malfunctioning. It's an inexpensive part considering the cost of replacing an burned out unit or even a reapirman bill. Check into that first, let me know if you require more assistance.
Mar 16, 2008 | Sub-Zero Bottom Freezer Refrigerator
Jenn-Air JCB2059G Bottom Freezer Refrigerator Logo
73 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
