Question about GE WBSR3140DW Top Load Washer
Washing machine overflows
Tub continues to fill until overflows does not begin wash cycle
  • 4 more comments
  • monksmomma Apr 02, 2008
    I have the same problem but only on the largest water/load size. it runs on small, md and large but not on super with out over flowing.
    my model is whdsr315dsww
    thanks
  • maxine46 Jun 29, 2008
    washer keeps filling with water and won't stop until the water is turned off.. but it will spin out if you turn it slightly past the spin cycle.
  • coffeeboot Dec 06, 2008
    Do you know of any change in tub design to prevent the pressure hose from becoming clogged and flooding over the overfill tube?
  • Shadizar Feb 10, 2009
    washer fills the basin, but doesn't stop
    even when I turn the machine off
    hot water works fine, but cold water just won't stop
    unless I close the shut off valve on the wall
  • Anonymous Feb 11, 2009
    The washer will not hold water, it just keeps running, what do I do??
  • casperpully Feb 19, 2009
    Washing machine continues to fill even after the machine is full. I have tried the small hose connected to the size switch and there doesn't seem to be anything in it. Could there be anything else I could try?
Sorry in advance for the lack of appropriate terminology. my "solution" comes from a mother with no mechanical experience point of view.
i had the same problem with my washing machine overflowing. I opened up my machine, found the clear hose that went from this little square box on the side of the tub up to the switch for the "load size" knob. i pulled the hose off the square box and saw that there was a piece of paper in it. i pulled it out, scraped the scum out and reconnected it. started the machine. - that didn't work.
so, I got the thinnest pipe cleaner i could find pulled the tube from the little box, and stuck the pipe clearner down the pipe of the little square box. pulled out a bit of scummy lint, then I blew in the tubing. I heard a "click", I thought.. okay maybe that's it. reconnected everything, started my machine.. and now it works :)
This probably wasn't the proper thing to do, but it worked and saved me from the cut throat washing machine mechanics in this area.
Posted on Jun 22, 2008
  • 290 Answers
The first thing to check is the pressure switch hose. It goes from the pressure switch in the control console down to the airdome on the tub.
If it gets pulled loose, gets a hole in it, or gets clogged with lint or soap scum, the pressure switch will never sense the water level and turn the water valve off.
If the hose is ok, then you probably have a failed pressure switch.
Post back with the complete model number from the machine if you have any questions and I will try to help you with checking and repair.
Posted on Nov 10, 2007
  • Michael  Lindley
    Michael Lindley Nov 14, 2007
    Just wanted to follow up on your washer and see what you found out.
    Thanks/Mike
    To am_mark,
    I think you posted the serial number instead of the model number. If you will post your question in another thread we will see what we can do.
  • amford717
    amford717 Mar 24, 2013
    GG908150G
I think your fix by cleaning the square box was the root. I have the same issue and i removed the water level hose from the square box and blew into it heard a good click and NO/NC contacts changed states on ohmmeter.
I then reconnected the hose to the square box and disconnected it from the pressure switch - No water is making it up to the switch even when the tub is overflowing. Some water does trickle out the square box when I take the hose off that end. I think it is obstructing water up to to pressure switch hose. When I look at the square box it looks all corrosive looking through the transluscent plastic. I am now preparing to try and clear out that box, but I think the whole tub has to come out to gain access to it. I would suppose there is at least a filter in there and maybe it is totally plugged up with lint or something.
Posted on Aug 15, 2010
    Problem Solver:
  • 8 Answers
The problem is usually the pressure switch hose being clogged, my question is better how can we prevent this from happening???
Posted on Sep 22, 2011
GW washer dumps water out the bottom of machine, asll hoses are tight with no holes.
Posted on Mar 27, 2008
4 Suggested Answers
huuum
  • 750 Answers
SOURCE: GE Top load washer.
Hello rschneeweis
Welcome,
Sounds like a seal or drain hose is leaking or the clamp on a hose has vibrated loose.
Water leaking out the bottom of the machine when washing machine begins agitation cycle. If the machine is turned off the water stops leaking even with the tub full of water.
Let me know if you found it and how you do.
Huuum
Please remember to leave a rating
Posted on Oct 04, 2008
SOURCE: GE frontload washer will not wash cycle or spin out
Thanks to Guest #2 our laundry is back in action and we're not waiting for a serviceperson. We took the front panel off, unscrewed the white plug and was sure our plastic drawer was open to catch the water, a load's worth. We found a small screw driver, 8 or so pony holders, some change, drill bits, bark, games pieces, can tops, etc... unbelievable. Thanks SO MUCH for the hint!
Posted on Nov 22, 2007
SOURCE: GE Profile Prodigy filled with water & won't start
If you don't hear a click when you close the lid, replace the lid switch.
Posted on Feb 01, 2008
Roper washing machine does not fill for rinse cycle. Goes directly to rinse agitate without water.
Without Model number I am only guessing but I suspect you have a blocked sensing tube that travels from the Level selector switch to the side of the tub somewhere. It is possible for this plastic tube to become partially clogged and not allow trapped air to vent when tub is drained of water. Usually this problem manifests itself as an overflow of the tub. Check the full length of this clear hose and see if the end nearest the tub looks like it may have debris or dirty detergent clogging it.
This hose is pushed onto a nipple mounted to a reservoir on the side of the tub. Push a thin copper wire 4-5 inches into the those after removing from nipple and also down into the nipple an inch or two before reinstalling the hose to the nipple. You MIGHT even blow into the hose while you have it off and you SHOULD hear a clicking sound coming from the level selector switch body.
Good Luck. Come back with Model number under lid if that doesn't help.
Nov 28, 2015 | Roper Washing Machines
Whirlpool thin twin lt7100xvn0 wont complete the fill cycle
sounds like a bad water pressure switch not to difficult to do and not to costly. if its defective it will continue to fill and overflow never going into wash cycle. ( u can check it by having it set to wash and removing the long clear plastic tube hose from the tub not the switch, and blow into it, or u can use another small tube and insert it into the pressure switch & blow into it. if it starts the wash cycle the diaphram in the switch is ok if it doesnt the switch is bad) and u may want to check ur inlet water valve as u may have a bad water inlet valve. which can also keep water flowing no matter what u do even when unplugged from wall. Have u ever noticed water in the tub for no reason like the next day? these can be checked with a multimeter.
Jan 15, 2015 | Whirlpool Washing Machines
Frigidaire (LTF2940E) Washer starts, stops, starts, stops...
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
May 07, 2009 | Frigidaire GLTF2940ES Front Load Washer
Kenmore 80 Series Overflow
We've now had this happen three times and the exact same thing caused it all three times.
If the water level selector knob hasn't "clicked" into one of the given load levels on the control panel(i.e. the knob is in between levels) it will continue to fill until you discover water everywhere and turn the knob until it "clicks" into a level.
As far as I know, it has nothing to do with loose hoses or bad switches, it's bad design. There seems to be no safety mechanism to turn off the water if you over- or under-shoot the desired water level.
Apr 29, 2009 | Kenmore 24032\24036 Top Load Washer
I have a Whirlpool stacked washer and dryer combination. The water is overflowing on the washer. It happens during the rinse cycle when the water is filling up. It appears that the cycle gets "stuck" in...
check the pressure hose. a kinked clogged or disconnected hose continues to fill. the pressure switch senses the air pressure in the hose.awaiting your further comments. thank you.
Dec 23, 2008 | Whirlpool LTE5243D Top Load Stacked...
Maytag topload washing machine
either you have a bad pressure switch or the latex hose to it or has a hole in it it may have come off either the tub or the switch if it was shaking badly it will be connected to the fill option switch on the control panel go down then hook to tub
Dec 30, 2007 | Washing Machines
Washer fills continuously until it has overflown
I found this answer on Repairclinic.com. Hope it helps...
Water-level switch A defect--or an obstruction--in the water-level switch may mean that it can't tell the water to shut off. So the machine overflows. This switch senses the water level in the clothes tub. It's usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. You can either clear any obstruction in the tube or replace the water-level switch.
Oct 22, 2007 | GE Hotpoint Super 3.2 cu. ft. Washer
Washing machine does not stop filling
Does the machine start working normally after turning the wash cycle manually ?
Feb 15, 2007 | Roper RAS8445KQ Top Load Washer
GE WBSR3140DW Top Load Washer Logo
12,840 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
