Question about GPX HM3817DT Shelf System
The right speaker output jack produces no sound through the speaker. The wires were switched to insure its not the wires. The jack itself is not working. I have used this product for a month and it had worked fine. It has not been moved, it has just stopped working. I cannot find my receipt to return it.
  • 2 more comments
  • integrity1 Nov 10, 2007
    The speaker wires are not what is faulty. What is faulty is where the wire plugs in. Each speaker works in the other in-jacks.. this one jack for the right speaker is the one not working.
  • cardfamily56 Jan 26, 2009
    I am having the exact same speaker problem. However I noticed when I reset the system using the button on the rear both speakers worked until I tried to set the clock then I lost one speaker again.
  • Anonymous Mar 29, 2009
    The right speaker jack worked for several months and now only a hum comes from any speaker plugged into it.
  • darriandeetu
    darriandeetu Aug 23, 2012
    what button
    Scholar:
  • 31 Answers
Hi There, 11.11.2007
There are several things that could have caused this to happen.
But first there is a simple test you can do as follows.
Take a small battery out of one of your torch's, a small AAA or AA type they are usually 1.5 volts.
Disconnect the faulty speaker wires from the rear of the amplifier system and by tapping the speaker wires to the terminals on the small battery you should hear small clicks coming from the speaker...If this happens OK then you know the speaker and the wires are all OK and the fault must be inside the Amplifier system. But if you dont hear any small clicks then the wires to the speaker or the speaker itself is faulty...you can try this on the good speaker and see what the clicks sound like!!!
Clicks means its all OK,
No Clicks there must be a faulty cable or a blown speaker...
The next thing to consider is were you playing the music at full volume when the speaker went faulty???
There is usually protection devices within the amplifier to protect the speakers from overloading, and its possible that this device has tripped on the faulty channel.
Sometimes there are fuses which are accessible from outside the amplifier case which you may be able locate then replace.
But if there are no fuses then the amplifier will need to go to a service person for attention. I dont recommend that you take the amplifier apart yourself as there are dangerous voltages inside that can cause you serious injury, and a service person is trained to look inside safely......
Cheers for now... yubeut.
Posted on Nov 10, 2007
No sound except through headphones
The fact that the device produces audio output through the headphones indicates that the audio system is operable up to the headphone jack. Therefore, the fault must lie in the internal speaker, the wiring between the jack and the speaker, or the jack itself. Most likely, the internal speaker has gone belly-up and needs to be replaced...
Mar 26, 2016 | Tablets & eReaders
Our turntable is not producing any sound even though we have changed the speakers
Be sure the audio-out leads are connected properly to the receiver. They usually will work ok connected to the aux. plugs. Be sure the selector on the front of receiver is set to aux as well. Check the cartridge output wires to insure they are connected to the cartridge ok. If you have the receiver powered up and have the proper settings on the front of the receiver, you should get a little static sound when plugging the audio output leads into their respective input jacks on the receiver.
Feb 21, 2015 | Audio Players & Recorders
No output
There are some possibilities. One, your speaker may be blown or disconnected. Make sure the wiring is still connected to the speaker and if you have one, try measuring the resistance(impedance) of the speaker with a volt ohm meter.Do this unplugged from current and disconnect one of the wires from the speaker or you will get a reading from the output stage. Two if there is a heaphone or line out jack it may have become faulty. If you have sound with the headphones plugged in your amp is still producing sound. Some jacks are designed to interrupt the signal to the speakers allowing you to practice without bothering anyone. If your amp has that feature and you still have sound with the headphones and your speaker tests OK then your problem is the jack. Hope this helps.
Jul 20, 2009 | Marshall Mg100dfx 100-Watt Combo Guitar...
No output from right side speaker jack
audio board located inside the mainboard console to the right trace your speakers wire to bd, disconnect the three leads, 3 phillips screws, and examine bd for burns. If yes, ebay the board id for a replacement.
Apr 24, 2009 | Dell W4201C 42 in. Plasma HDTV
Crackling sound on speakers when output line is moved
Absolutely you can fix this problem.
What you do is goto your local radio shack and they will have the correct connectors and wire that you need.
If you want you can even bring one with you to radio shack and show them what you want to do.
The fix should only take maybe 10 minutes tops they have alot of do it yourself items.
Dec 23, 2008 | Audio Players & Recorders
Brookstone Wireless Outdoor Speaker with Bose 123 System Problem
AUX usually refers to an INPUT, such as a CD player, etc. No signal comes out of a standard AUX jack, unless it specifically says "Aux speaker output". Instead, look for another speaker output jack, such as remote speaker, B speakers, etc. You may only have one set of speaker output jacks, in which case you would need to connect your wireless speaker to the speaker output jacks along with your main speakers, or buy a little speaker selector switch box to switch between main and wireless speakers. There's usually no harm in connecting more than one speaker set to the same outputs, though it is technically not recommended. In the real world, just don't crank it too loud and you'll be fine. The wireless speaker MIGHT run off of a standard line output also, if the wireless speaker has its own power amplifier.
Dec 15, 2008 | RCA WSP150 Main / Stereo Speaker
Right speaker doesnt have sound
1ST.-The right jack could be damaged!!
Usually, there is a [+} posaitve & [-] negative input\output to speaker connections. Not all [-]neg. is ground.Sometimes the [+] pos. is grounded. [The exception to the rule is that u SEE the black wire going to ground] the reason I am letting u know this is that u can test the INSIDES of the sound system.
If u can get inside of the unit. Cut the left speaker output [+] posative from both outputs. criss\cross wires.Place left speaker output to right speaker jack[ that does not work!!] & visa versa.If the [LEFT Output] stops working after u plug in the speakers,the internal RIGHT output is damaged. NEEDS TO BE TESTED
If nothing nothing changes.The left still works & the right still does not work, then it is the jack (shorted ?, opened internally ?)
Jun 11, 2008 | Logitech Z-2300 Computer Speakers
TEAC - CD-X9 - No sound in left speaker
the speaker wire itself could be grounding out. look for small knicks in the wire and make sure the plug is not faulty. RCA plugs can go bad which would account for intermitent troubles some times
Dec 28, 2007 | Teac CD-X9 Shelf System
Right speaker output jack does not work
you must plug it in to the right slot,
Nov 04, 2007 | GPX HM3817DT Shelf System
Speaker jack not working
Sounds like your right front output transistors/IC may have a problem, not the jacks. Time for a trip to the shop I fear.
Jan 13, 2007 | Onkyo TX-SR502 Receiver
GPX HM3817DT Shelf System Logo
407 people viewed this question
Top GPX Audio Players & Recorders Experts
Sandy Moore
Sandy Moore
Are you a GPX Audio Player and Recorder Expert? Answer questions, earn points and help others
