Question about Kenmore 96212 / 96214 / 96219 Electric Kitchen Range
Electric Kitchen aid, model kerc607...broil elements
We relaced a broken bake element in our electric oven yesterday and now the broil element is not heating up properly. In the bake mode, the out broil element should come on to help preheat the oven and it doesn't come on at all in bake or broil mode, but the inner broil element does heat when on broil. Anyone have this problem or have any ideas?? Thanks D
  • 3 more comments
  • Anonymous Mar 15, 2014
    oven wont heat igniter does not glow orange when on bake but does for broil
  • Anonymous Mar 18, 2014
    Range works fine. Oven will not heat up. Oven indicator light is on. I am showing 120 vac on both connectors on lower heater element. Same on upper with broil selected. But oven elements will not heat up.
  • Anonymous Mar 20, 2014
    Model KESC307HWW8
  • Anonymous Mar 30, 2014
    My Kitchen Aid oven will not preheat or keep to the desired temp in steam mode or also regular bake mode, BUT will preheat and keep desired temp in "auto steam" mode. Example: in regular steam mode - my selected temp is 400, but it can't get above 325-340 no matter what I dial it up too. Owners manual says the oven max temp on steam mode is 450 but it does not even get close unless in autosteam mode. Top element comes on just fine in "autosteam" and hits the mark. Any other mode will not.
  • Anonymous Mar 31, 2014
    Model Number KGSA906PSS02
  • 473 Answers
What is the complete model # from the sticker on the range? I will need that so I can look into this for you. I will say that I have seen, in several cases, where the oven control gets a surge and fries after an element has broken.
Posted on Nov 10, 2007
The lower element burned in my oven. I replaced the element, but the oven will not work.
unplug range ..remove the back cover plate check all wires all connections ..their must be a burnt /broken /dissconnected wire ..check where the wires connect to the bake an broil element ..and the bake broil switch..if all looks good .then the bake broil switch burnt out when element blew out..plus is the breaker tripped in the box ..it prob. tripped when the element blew out..let me know..good luck
Aug 28, 2010 | Frigidaire FEF366 Electric Kitchen Range
Kitchen aid oven
if you put your volt meter leads across the bake element you should be getting 240 volts when its in the bake cycle.
Its sounds like the control board is bad.i suggest you call a local repairman...
Aug 07, 2008 | KitchenAid Architect Series KEBC107KSS...
Frigidaire Electric Range Model FEF355ESB
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
May 07, 2010 | Frigidaire FEF355 Electric Kitchen Range
Broiler element comes on on Kitchen Aid KDRP407 on all settings
Have you resolved your oven problem ? If so, what was it ?
I have the same exact thing going on....
Brad
Feb 03, 2010 | KitchenAid KDRP407H Dual Fuel (Electric...
The top burners work fine and the oven does not appear to have any problems but the heat elements (bake & broil) suddenly quit working.
Usually a safety thermostat, but it can also be wiring, a control board, or a dlb relay. Call Kitchen Aid warrantee service on this, as some of the electonics have a longer warrantee on them. Good Luck, Appliance Specialists.
Jan 19, 2010 | KitchenAid KERC607 Electric Kitchen Range
Top element wont heat wen oven is on bake
The top element normally operates only when you turn the temperature control all the up to the broil setting as it is the broiling element. If it doesn't work at the broil setting, suspect a bad brioler element or a faulty temperature control.
Aug 11, 2009 | Frigidaire Gallery GLEFM397DS Electric...
Kitchen aid oven not heating up
THERE IS OVENSHUTDOWN THERMAL FUSE IN THE BACK THAT WILL SHUT DOWN THE ELEMENTS. I AM LOOKING FOR THE FUSE.
Jul 20, 2008 | KitchenAid KEBC107 Electric Single Oven
Maytag oven not getting hot enough
When you put the oven into bake it preheats with the bake and broil element both.  The broil element is most likely your only heat source if it took that long to cook the pie.  Need to verify that the bake element is coming on.  If it isn't then the problem is either in the control or the element itself.  Give me the model # off the sticker on the oven and I can help you do the check out.  In the mean time see if the bake element is getting hot.
Oct 26, 2007 | Maytag MER5552BAW / MER5552BAQ /...
Oven slow to heat
In alot of ovens preheat will cause the both the broil and bake element to come on. You are most likely getting heat from the broil element. This means either the bake element is bad or the relay on the oven control is bad. If the element shows resistance with an ohm meter then replace the oven control board.
Sep 30, 2007 | Thermador REF30 Electric Kitchen Range
Kenmore 96212 / 96214 / 96219 Electric Kitchen Range Logo
485 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
