Question about Freezers
My freezer trips my house power supply - Freezers
    Sergeant:
  • 340 Answers
Their is a short circuit in your freezer call for service leave it unplugged you can cause your self more problems. Tom
Posted on Jul 03, 2009
I have summit commercial freezer with embraco emi 60her when turn the power on, fan start run then compressor start run about 30 second the trip the compressor. ans i can not see any run or start...
The start relay should be on the side of the compressor and attached to the three prongs that wiring attaches to on the compressor.Is the problem causing the breaker to trip in the circuit breaker box? Sea Breeze
You can have someone match the start relay and the run capacitor at a refrigeration supply store near you or you can contact Summit
HERE
http://summitappliance.com/support
Apr 02, 2013 | Freezers
My freezer keeps overloading our switch board, whats wrong?
The freezer has a compressor which will draw quite a lot of current in the first half-second when it starts.
Either: Your freezer has a electrical problem and needs to be fixed,
Or: there is already too much drawing on the circuit that you are trying to add the freezer to, and the freezer is more than the circuit breaker will allow.
First try powering the freezer from some other socket on a different circuit (use a long cord), or unplug a few things that are nearby (in most houses, there will be several wall sockets on the same wire in each area of the house).
If the freezer runs fine from a different socket, or when you unplug some other stuff, then the problem is you are overloading the circuit you were originally trying to add it to.
If you can't get the freezer to run on any socket without tripping the circuit breaker then probably the freezer has an electrical fault and best you get a real electrician to check it (safety first!).
Oct 02, 2012 | Freezers
My Whirlpool Intergrated Freezer AFB 823/3 trip The Earth Leakage CB on the house Fuse board!!
This one requires more information. If the breaker trips randomly, then I say there is grounding problem between the plug and the freezer itself. I know the UK has a very large plug and it requires a serious connection into the wall. I would check and make sure you have a good ground on the box itself. You may have to removed the back and look at the connections If you have a V-OHM meter you can verify the ground through different parts of the freezer. If this never happen before and you just bought this freezer I would replace the breaker with a new one. The breaker maybe damaged and sensitive to heat from the current draw of the freezer. Also make sure it is the correct ampere required to run the freezer.
Feb 20, 2011 | Whirlpool Freezers
After moving to a new home, the freezer keeps tripping the breaker every few days
My first instinct is to ask you, are you plugging this freezer into a GFI outlet, one which has a breaker switch as part of the outlet? If so, that is the culprit and not the freezer, as refrigerators and freezers will often trip this ground fault indicator because water can on occasion reach ground, which causes the breaker to trip on the outlet.
Test this by plugging the freezer into a non GFI outlet for longer than a few days. Nothing is broken and you dont need refrigerator repair service.
Sep 29, 2010 | Maytag 15 cu. ft. / 425 liter Upright...
Hi There, My freezer is less than 3 years old. (MQU1656BEW) It seems to be tripping the GFI plug in our garage. (It is not plugged into this plug, but is on the same circuit.) I have plugged it into an...
Refrigerators and freezers should not be run on a GFI outlet the it will weaken and start tripping.Most manufacturers now print this in the owners manual.
Aug 17, 2009 | Maytag 15.6 cu. ft. Upright Freezer...
What will cause door heaters to trip breaker.
You have a short some place isolate each component if you disconnect the heater and it does not trip the the breaker replace heater. caseparts.com good luck Tom
Jul 01, 2009 | Victory Freezer Freezer, Reach-In, 2 Door,...
Tripping the breaker
Check the start relay. If it is OK the compressor is bad.
May 12, 2009 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Freezer tripping supply
make sure whoever put in the motor installed the right motor and if they did check to make sure the fan blade wasn't put on backwards ,,,,,,,
Nov 26, 2008 | Freezers
MAIN RCD CIRCUIT TRIPPING OUT
it may not be the freezer. ground fault recept. are known to go bad pretty regular. upplug freezer and see if it still trips. It doesn't take much to trip one, so look for something simple
Aug 18, 2008 | Freezers
Freezers Logo
50 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Freezer Expert? Answer questions, earn points and help others
