Singer Deluxe Knitting Machine Logo
A
Anonymous Posted on Sep 15, 2014
How to do the stitch M1P please show me by video
How to do the stitch, M1p pick up loop between last and next stitch and purl into back of it
Roberta Kelley
Level 1:
New Friend:
  • Contributor 4 Answers
  • Posted on Sep 17, 2014
Roberta Kelley
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
532
Points
7
If you are speaking of a flat bed knitting machine, if you have enough needles, all you do is move the end stitch over 1 needle and then either pick up a purl stitch from one of the stitches next to it and put on the empty needle or just leave it there (the latter will make an eyelet), that is one way to increase with the hand knit version of M1. If you search Knitting Machine Increasing, you will find many, some are mine where there are others that show the same thing. hope this helps.
Noro 123,, Pleated Cowl
buy legitimate game golds, game cdkeys and game items on https://www.m8x.com, enjoy your game now
1helpful
I'm knitting the Irish moss stitch in the round and I can't figure out how to decrease the stitches while keeping the pattern.
Probaly have thrown the knittig away by now, but for future reference. If the decreasesare at the end of a row, you will be able to keep th sequence on the next row, if it's in the middle of a row, it's a bit more tricky, you just have to concentrate and match the pattern. I know you will be able to see the decrease, but this is unavoidable if t's in the middle of a row, but at the end of a row or round just follow the pattern, as you would, being careful to match stitches. It's difficult to tell, rather than show. Have you tried to Google it? There may be a video. Good luck. :-)
I am knitting a pink dress inbook pbn k 346 and it asks you to( k1, p1) twice into next stitch, (when countingstscount this as 1 st only) I dont understand how to do 4 stitches in 1st?
When you knit/purl two stitches in one, you are increasing the stitch count by one. This is generally how you increase stitches. If you knit/purl two stitches together, you are decreasing stitch count.
How should the first stich in each row be knitted. I.e opposite of what the pattern calls for or pulled off Thank you.
The first stitch of the row is usually the chain that you ended in the last row. The chain essentially builds the height of the pattern to the next row so the stitches are even height from beginning to end. After you have made the chain, then begin with the first stitch in the next row pattern.
So, if the pattern says to knit 3 (or purl 3), that 3 stitches allows the height for the next row.
What do yon and yfrn mean in a knitting pattern?
yon is usually Yarn On (or over) Needle. This is a yarn over between a purl and a knit stitch. (After the purl stitch, keep the working yarn in front of the needle. Then place the right needle into the next stitch so that the right needle is behind the left needle in the stitch. Wind the yarn around the needle and pull the loop through.)
yfrn is a Yarn foward and round the needle. This is a similar yarn over to the yon but is a little larger. The difference is that the yarn over is done after a knit stitch and before a purl stitch. After the knit stitch, bring the yarn in front of the needle. Wrap the yarn anti-clockwise around the right needle so that the yarn is again at the front of the work. Place the right needle in the front of the next stitch on the left needle. Then do a normal purl stitch.
You can see some videos and still photos here: http://www.stitcharena.com/library/hand-knitting/yfwd-yfrn-yrn-and-yon/ .
I hope this helps.
Lil tots yarn making baby blanket what is m1p? Seems like make one it asks for 14 times.
You need better book or read the one you have. Its Make one purlwise, You make 14 increases purlwise. You can find example on youtube or in a better knitting book.
How to change the trines on powerbase M1P-ZP-300D scarifier
im not sure what you got there but my search of that model number comes back as a power rake made in china , if thats what your after id say the first problem is to find a importer of parts for this, unless your up for a lil trip to china ? that is?
May 18, 2014 • Garden
1helpful
Where can you get spares for PB Lawnraker M1P-ZP-300D?
I had the same problem - could not find anything.
Look up MIP-ZP etc that is the second character is an I not a 1 and things get easier
Top Singer Toys Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you a Singer Toy Expert? Answer questions, earn points and help others
