Question about Compaq Presario X1000 Notebook
"On" button The ON button broke and is pushed down into the unit. How do I get into the box to repair this problem?
  • 1,601 Answers
Re: "On" button
Is it cocked to one side?
You may be able to get it freed. Just leave it unpowered till you do. If is not cocked to one side it will have to be taken apart and fixed.
Here is the service manual, Good Luck.
Posted on Nov 10, 2007
0 characters
3 Points
Control Volume button pushed into unit Kaidaer Mini Speaker
you must try if you have some instr. manual try to download from. However you must test the button with DVOM tester for open or continuity and repair or replace. Maybe some loose wires or cold solder.
God bless you
Mar 01, 2013 | PC Laptops
Black screen?
Try a "Cold-Start",Remove all media, DVD, CD,
USB..etc., Remove AC plug, Remove Battery,
Hold down on/off button for 10 seconds,
Replace battery, Plug into AC outlet,Push
on/off button and Start normally.
Nov 05, 2012 | PC Laptops
All the lights come on as they should when you push the start button but I get a black screen with nothing on it.all the lights go out for a sec and come back on about every 17 sec. and it keeps do'n that...
you could try to restart laptop and press the F8 key at the same time holding down for a few seconds
hopefully this will bring up a repair options box
then you could try maybe
clicking on
last known good configuration
or repair my computer
you may be lucky
Mar 12, 2011 | PC Laptops
Setting us need uk
For Windows Vista, 7 and 2008
Click "Windows Start" button
Click "Control Panel"
Click "Region and language"
Now click on "Keyboards and languages" tab
Click "Change Keyboards" button
In General tab, click "Add" button
a window called "Add Input Language" will come
Scroll down till you get "English (United Kingdom)"
Expand "English (United Kingdom)"
Expand "keyboard"
Tick "United Kingdom"
Click "OK" button
Now in "Text setrvices and Input languages" windows
click the drop down button
you will fine "English United kindom"
Select that and click "Apply" and then "OK"
For Windows XP, 2000 and 2003
Click "Region and language options"
In "Regional option" tab
click the drop down button near the customise button
select "English (united kingdom)"
in the location box too, select "United Kingdom"
Now , in the language tab, clikc "Details" button
in the Installed service box, click "Add" button
in Input language, select english(United Kingdom)
keyboard layout will be selected automatically to united kingdom.
click "OK"
Now, in Default input language. click the drop down button and select "English (United Kingdom).
Click "Apply" and "OK"
Again click "Apply" and "OK"
That''s it.
Jan 18, 2010 | PC Laptops
My headphone jack broke inside of laptop how to
Unfortunately this can only be repaired by a shop.
Oct 30, 2009 | Acer Aspire 3050-1733 Notebook
How to repair the left click button on HP Pavilion ZT1135
I had the same problem. It is pretty easy to fix. You have one of two options to follow.
1) Push down moderately hard on the left mouse button. After 2 mins or so, and the cap should back on to the button on the bottom
2) if number 1 doesn't work get a needle or pin and lift the left mouse button off. Then just apply very little, not even a drop, maybe half of a drop to the button and apply the cap back on and push down.
Sep 25, 2009 | HP Pavilion zt1135 Notebook
Blank display screen after system restore, i restored my acer 1660 travelmate and i now have a blank screen and the key board will not work.
while it is powered up, push and hold the fn key, then hit the f5 key. if that does not help,push and HOLD the power button down for 60 seconds this should reset the unit.also how did you find out keyboard is not functional? i know alot about the 5100 series,have 2 that broke after warranty was up. and had 2 repair them myself.i hope this helps you, ask i you need more help.good luck.
Mar 03, 2009 | Acer Aspire 5100 Notebook
On button problem
This situation is not one that a novice should attempt. For a pro it should be an easy enough job. My advice is to take it to a shop.
Dec 28, 2008 | Toshiba A75-S125 Satellite Notebook
On off button broke
Why not send it in to the manufacturer for repair?
Feb 08, 2008 | NEC Versa LXi Notebook
Lap top will not power on
repair shop job- button replacement if possible.
May 15, 2007 | HP Pavilion ze5185 Notebook
Compaq Presario X1000 Notebook Logo
79 people viewed this question
Top Compaq PC Laptops Experts
John mullen
 Mike M
Mike M
Are you a Compaq PC Laptop Expert? Answer questions, earn points and help others
