The green lines crackle like static then after a while disappears then tv operates until the next time i switch on
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
SOURCE: Green vertical line on Screen
There is nothing more you can do.
I will take it as, that the green line is all the way from top to bottom. In this case the panel needs to be replaced. This is very, very expensive. If tv is out of warranty, it will be better to buy a new tv.
SOURCE: Sudden power failure
my swisstec tv had exactly the same problem this week march 30th and the 12 month warranty expired.....i went to skymediauk online and extended my warranty ..free for 3 months they collected it,fixed it and returned it in 46 hours
SOURCE: Green line 2inch appeared on left hand edge next
look like you panel fail,
but you can get 2nd opinon
SOURCE: When swiched on, the screen displays green vertical bands
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
Hi
Most likely a power supply component has aged and thus changed value and/or
failed. Take it to a reputable repair person.
