Question about Nikonos SB-105 UW TTL Speedlight Set 11202 Imported Flash
Sb 105 fires when I advance the film, not when I
My Nikon SB 105 fires when I advance the film, not when I press the shutter release. The camera (nikonos V) seems to be working fine. I put fresh batteries in both the strobe and the camera. I ran a roll of film through it last night, will have it developed today to make sure.
Thanks in advance.
  • 685 Answers
Which slave-unit to use for firing my Nikonos SB 103 underwater flash
Another SB103 they work together you have to set one to slave
The other in command mode
Apr 17, 2014 | Nikonos SB-105 UW TTL Speedlight Set 11202...
Can I use Nikon SB-22s speed light with my Nikon digital SLR D5000? Is that compatible? I bought SB-22s for my previous Nikon film camera. Thank you.
You should be able to use your SB-22 with your D5000, however you can only use it in the manual mode since it is not a TTL speed light. That means you will need to manually set both the camera and the flash unit. I have done that successfully with an SB-25 on both my D800 and D90 in a pinch, but you should consider investing in either an SB-700 or SB-910. They are allot more versatile.
Oct 26, 2013 | Nikon Speedlight SB-22S TTL Flash
I couldn't get the Nikon ML-L3 Remote Control to work on my Nikon D40x when I was using the external flash (SB-900). When I took it off, it worked fine. Is there a way to get it to work with the external...
Set the camera's release mode to one of the two remote modes. Quick-response remote mode fires the shutter when you press the button on the remote. Delayed remote mode gives you two seconds to hide the remote behind your back before firing the shutter.
To set the camera's release mode, press the button to bring up the information display. Press the button to put the cursor into the information display. Use the cursor keys to highlight the release mode (fifth item from the top along the right edge) and press OK. Use the cursor keys to highlight the desired mode and press OK.
Full details are in the manual in the "Release Mode" section (page 53 in my copy).
Oct 04, 2010 | Nikon ML-L3 Remote Control
Speedlight SB-22S TTL Flash: i have a Nikon Speedlight SB 22 that was used on m...
sorry ,you will have to get a flash for digital.nikon dx type.film flash not compatible with digital.
May 17, 2010 | Nikon Speedlight SB-22S TTL Flash
Sb800 firing without pressing shutter release
sounds like a short in one of the circuit boards, most likely one or seveal of the ribbons and boards will need to be replaced to correct the problem. Send in for repair expect to pay up to $200 for a Nikon factory overhaul
Feb 21, 2010 | Nikon Speedlight SB-800 TTL Flash
Nikon F100 does not advance film to start of roll,
Jim, it really sounds like one of threethings. Either will require a repair shop.
1. the film sensor is not recognizing film in the film chamber, or film across the back, therefore not telling the advance motor to advance film...
2. The film advance motor itself needs replaced.
3. The rear door latch switch needs replaced.
Since everything else seems to do OK, I doubt the main computer board is bad.
Feb 03, 2010 | Nikon F100 35mm SLR Camera
My sb 600 fires with the camera but it seems not illuminate
Definately a settings problem. The camera will only syncronize on one specific speed. Youe best bet is to use auto. For manual, you'll have to set the shutter speed at the sync speed.
Flash Sync Speed
  • up to 1/250 X-Sync Speed
  • up to 1/8000 FP High Speed Sync
  • Red-eye reduction
    Red-eye reduction with slow sync
    Rear-curtain sync
    Slow sync
    Front-curtain sync (normal) Flash Sync Modes
  • 1) i-TTL: TTL flash control by 1,005-pixel RGB sensor, built-in flash, SB-800, SB-600, SB-400: i-TTL balanced fill-flash and standard i-TTL flash
    2) AA (Auto Aperture-type) flash: Available with SB-800 used with CPU lens
    3) Non-TTL Auto: Available with Speedlights such as SB-800, 28, 27, and 22S
    4) Range-priority manual flash; available with SB-800 Flash Control
  • Mar 13, 2009 | Nikon Speedlight SB-600 TTL Flash
    I use a fuji s5 pro the problem is the sb 800 nikon flash for some unknown reason the flash fires once and then wont fire when shutter is pressed again
    I think the flash is not grounded to the hot shoe or Hot foot .
    Please note it needs to be cleaned and make good contact.
    If you want me to tkae crae of your problem contact .
    BERRIE SMITH CAMERA REPAIR
    bbmw@bellsouth.net
    770-312-0719
    Dec 27, 2008 | Nikon Speedlight SB-800 TTL Flash
    Cameras Logo
    128 people viewed this question
    Top Nikon Cameras Experts
    Steve
    Jeff Marcus
    Are you a Nikon Camera Expert? Answer questions, earn points and help others
