Question about Specialized Bicycle Components Specialized Mountain Bike 19"
How do I fix my front suspension on my outdoors specialized
  • 112 Answers
On top of the shocks there should be caps that pop off or screw off and there should be bolts in there you can adjust
Posted on Jul 09, 2009
  • Shawn Jul 09, 2009
    on top of the shocks there should be caps that pop off or screw off and there should be bolts in there you can adjust
Which relay controls air suspension on jaguar sovereign lwb 2007 diesel
the usual problem with air suspension on the x350 all alloy car is the air pump or corroded wiring to it, its behind the lh of the front bumper liner if you got a air suspension problem showing you need to get the fault codes out of the system to help sort it out it may be a air leak the, the resovoir is in the boot well.and i think the relays and module is in the boot area/ fusebox cars these days are not all that easy to fix without special tools or franchise dealer help good luck
Jul 09, 2017 | Jaguar Cars & Trucks
The tires are wear out on the inside and dishing on the outside, is this a sign of wore out struts causing the front to be out of line. What is the fix needed replacw struts in front and new tires
Wearing on the inside can be caused by an excessive camber angle or excessive toe out, or both. Either of these can be caused by worn or damaged suspension parts. Camber affects Caster, and Camber and Caster affect Toe. Toe affects the Thrust Angle. (These are the major suspension angles involved in wheel alignment) The "dishing" or "cupping" is caused by what is sometimes called "wheel-hop" this can be caused by worn-out struts or shocks and can also be caused by tires that are seriously out of balance.
The recommended "Fix" would be to inspect the ENTIRE suspension system to check for loose and/or worn and/or damaged parts. Replace any of these parts as necessary. Then replace and balance the tires and head straight over to the alignment shop to have all of your suspension angles set to manufacturer's specifications. (Most tire stores also have an alignment machine)
Apr 10, 2011 | Chevrolet Blazer Cars & Trucks
Hello, I have a 2000 Audi All road Quattro, just looking for some ideas on what to do. My air suspension went out, does anybody know what the dealer cost will be to fix it or what i can do to fix it. Im...
The only way to fix that problem is to replace the actual air bags in the suspension. There is also a repair kit that you will need with them that will have the neccessary hardware and mounting parts. Usually it is best to replace them in pairs, both fronts or both rears. I would recomend having it done at a dealer or a independant shop that specializes in German cars, as there will be computer reprogramming that will need to be done and that requires special codes. If the car is not programmed correctly after install, your suspension height will not set correctly. I think you should be looking at $400 roughly for a pair, and about the same in labor.
Dec 29, 2010 | 2003 Audi allroad
Ball joint is squeaking at 50,000 miles. What are the procedures for replacing it? 2006 lincoln Mark LT
YOU NEED SPECIAL TOOLS TO DO THE JOB. BEST TO LET A GARAGE FIX IT THAT WORKS ON FRONT AND REAR SUSPENSION SYSTEMS.
Aug 23, 2010 | 2006 Lincoln Mark LT
How do you set the timing on a 2001 Kawasaki Bayou 220?
how to get hub off 220 bayou to put a new timing chain, do I have to have a special tool
Apr 07, 2010 | kawasaki Full Suspension Mountain Bike Men
What maintenance is scheduled for 60K
 STEERING/FRONT SUSPENSION: CHECK
• Maintains integrity of steering and suspension components, and
assures proper wear
 REAR SUSPENSION: CHECK FOR WEAR
• Maintains integrity of suspension components, and assures
proper wear
 DRIVESHAFT JOINTS: CHECK FOR WEAR/PLAY
 DRIVESHAFT: CHECK BOOTS
• Assures proper wear and that foreign matter does not contaminate
drive shaft joints
 PROPELLER SHAFT, PILOT BEARING AND
UNIVERSAL JOINTS: CHECK WEAR
AWD models only
• Helps assure proper all wheel drive performance
 EXHAUST SYSTEM: CHECK FOR DAMAGE/LEAKS
• Maintains quiet operation and proper emission control
 SPARK PLUGS: REPLACE
Except engine VIN code 85
• New spark plugs are specially designed and calibrated to provide
optimum engine operation.
• Engine is tested on special Volvo equipment after spark plug installation
Mar 25, 2010 | 2004 Volvo S40
WHAT SHOULD COMPRESSION BE FOR 04 KXF 250
Engine: Four-stroke single cylinder with DOHC, four valves
Displacement: 249cc
Bore x stroke: 77.0 x 53.6
Cooling: Liquid
Carburetion: Keihin FCR37 with hot start circuit
Ignition: Digital AC-CDI
Transmission: Five-speed with wet multi-disc manual clutch
Frame: Perimeter style, high-tensile steel with D-section upper frame rails
Suspension type, front: 48mm inverted, cartridge-type telescopic fork
Suspension adjustments, front: 16-way compression and rebound damping
Suspension type, rear: UNI-TRAK single shock system
Suspension adjustments rear: 16-way compression and rebound damping, spring preload
Wheel travel, front: 11.8 in.
Wheel travel, rear: 12.2 in.
Tire, front: 80/100-21 51M
Tire, rear: 100/90-19 57M
Brakes, front / rear: Single semi-floating 250mm disc, dual-piston / single 240mm disc, single-piston
Compression Ration: 12.6:1 ***********************
Rake/Trail: 26.5 degress/110mm
Overall length: 85.4"
Overall width: 33"
Overall height: 50"
Ground clearance: 13.4"
Seat height: 37.4"
Dry weight: 204 pounds
Wheelbase: 58"
Fuel capacity: 2.0 gal.
Jul 09, 2009 | kawasaki Full Suspension Mountain Bike Men
Adjust front suspension on a Mongoose XR-75
i dont think you can......because these bikes are made for confort at a cheap price..........
higher value bikes can be adjusted....they have special shocks and you can adjust on either soft or stiff ride.....
May 13, 2009 | Mongoose Exile 26 Men's Full-Suspension...
Adjusting front suspension
yes you are going to need a technical manual with the gauged settings of the factory. This will set to default factory and you can then adjust to what the setting adjustments are to fit your confort.
Jan 29, 2009 | 1995 kawasaki KLE 500
Specialized Bicycle Components Specialized Mountain Bike  19" Logo
141 people viewed this question
Top Specialized Bicycle Components Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Specialized Bicycle Components Cycling Expert? Answer questions, earn points and help others
