Unknowingly I put mini SIM in SIM slot and has gone inside the SIM slot and unable to remove from outside. Any way out to remove the SIM
SOURCE: my phone is frozen with white backgound saying nokia
Cause.
This generally occurs when you switch off your
phone directly(by taking out the battery or holding down the power
button.why? because your phone is trying to read some instructions from
the memory card but is incapable to do so due to your previous activity.
FIX
Fix
is really simple and uptill now you have probably understood what to
do.just take out your memory card and now switch on your phone with
memory card uninserted.the phone will start normally.now insert your
memory card with phone switched on. now you should uninstall any
wnwanted software from your memory card(if there is any) and woohoo,
the problem is solved.
Please vote when you resolve your problem
SOURCE: I HAVE NOKIA 5530 XM. IT CANNOTSEND TEXT MESSAGES.
nice noon...you need go to cellphone repair shop anf try to reprogram or master reset your phone,,i think the problem of your phone is software..good luck....
SOURCE: How do i replace the sim card slot tray in my nokia n8?
Here visit this n8 sim card slot pin replacement - Nokia N8 - iFixit this may help.But if you are a technician remove the sim case by using soldering Iron (Micro pit) , put the new one and solder it in the hole at the end of the connector.But make sure that you should do it slowly to avoid lost of circuit on the motherboard.Good lcuk
SOURCE: recover deleted text message from nokia n8
Yes you can sync the short messages with the help of Nokia Pc Suit/Nokia suite.You need to connect your phone to Pc via USB cable.If you wish to do download this Nokia PC Suite 7.0.8.2 - Free software downloads and software reviews - CNET Download.com and try.But if you have deleted the messages there is no way to help.Good luck.Thanks for visiting fixya
