Question about Nelson Sprinkler: Traveling Tractor
Leaks water from housing and moves slow. is their
Leaks water from housing and moves slow. is their a repair kit available and where do you get it
  • 218 Answers
Hi..my name is Keith..and i dont know of a repair kit but you can get parts for your sprinkler ..online...at.....lrnelsoncorp.stores.yahoo.net..i hope this will help..if not write me back
Posted on Jul 08, 2009
My 2001 Cherokee has a slow leak from the driver side around the front left tire, only when it hits normal temp and just a small leak. Could this be a water pump issue?
check it by having a cooling system pressure test done by an accredited radiator shop
there is a drain hole under the housing for the water pump to weep out water from a bad seal and sometimes they only leak when the pump is running but a test will confirm where the leak is from
Jul 15, 2017 | Cars & Trucks
How can I repair water leak?
Good grief, what kind of water leak? In your car radiator? In the house from a copper pipe? Or a toilet, a sink, a faucet? All these leaks require different fixes. Let us know where the leak is from. Then we'll have a better chance of giving you the correct advice.
I will tell you this, if the leak is from a "pin hole" in a copper pipe in your house you need to get a water testing kit to see if you have acidic water eating away your copper pipes. If so you need to replace the copper pipe and then get an acid neutralizer ASAP. If you do not get an acid neutralizer all of your copper pipes will be leaking since the acidic water has been eating away at all your pipes.
Jan 11, 2016 | 2004 Saab 9-3
How to replace water filter Housing?
most of the time when you get a filter it has its own housing and they are and in the water line filter, just unscrew the water line and replace, just make sure the arrow is going in the right direction
Dec 02, 2015 | Samsung RF267AB (25.5 cu. ft.)...
Can the water filter housing be the cause of slow water when the filter is in place?
Even a new filter will reduce the flow some what. I think the pressure to the filter is low or restricted . that will cause a reduction in flow, no it should not leak, check on the seal.
May 27, 2015 | Whirlpool Refrigerators
Water leaking from the housing were the heater eliment is located
the heater core is bad in summer u just route your heater hose's togther where they go thru the fire-wall.put a splice between both hoseses so water wont go into heater-core in winter u need heater u must if u have to use vehicle slow-speed only remove rariator cap pressure then leak wont leak as fast u can use heater until fluid is all leaked out or u can just move heater slide to blue area then water wont be going to heater core it wont leak out as fast or replace heater core
Dec 27, 2011 | Cars & Trucks
Water pump leaks from bottom of housing
You need to replace your water pump assembly. New water pumps are available at your local Honda dealer ( about $135). Get the after market gasket set , it comes with all the gaskets and seals necessary to remove the lower front cover and replace the water pump (K&L makes the kit ($25)). You do have to take off the lower front cover to replace the pump.
Aug 20, 2010 | 1985 Honda GL 1200 Interstate Gold Wing
Silver water softner sounds like water running all the time
It is running to drain. The sealpack (main piston & sealpack are one unit) is bad and needs to be replaced. If you are handy you can do this yourself. There is a retrofit kit to help repair these issues. It is only available at Culligan. It is about $10.
RJ
May 13, 2010 | Culligan 34" Whole House Water Filter...
GE Profile water filter housing leaks
Hi there is a grommet you can replace.
#WR02X10678 it is about $7.00 It can help seal the plug sometimes. Ge does want you to buy the whole filter assembly it is number
#WR17X11618 $51.50 . You may also consider putting a new filter in. It seals better than the plug it is number
#gwf $42.95. I dont know why they dont sell a o-ring kit. I guess they just dont make much money on o-rings. I hope this will help you. Have a nice day.
Michael Anderson
Anderson Appliance Repair
(865)945-3808
Feb 17, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Moved in house Monday & have a radiator leak due to bad rust...what's best temporary repair to hold for a few weeks b4 plumber available? What sort of Boiler is Ariston Genus 24 mffi ?
turn both valves off at each side of radiator and once the pressure balances it will stop leaking, there is no solution to this whilst using this as a radiator to heat the space, but will stop the leak.
Dec 24, 2008 | Water Heaters
Nelson Sprinkler:  Traveling Tractor Logo
270 people viewed this question
Top Nelson Garden Experts
Dennis
Mike Squire
Phil Walker
Phil Walker
Are you a Nelson Garden Expert? Answer questions, earn points and help others
