Question about Dishwashers
Smeg DW1612C 60cm Door won't open
Smeg DW1612C 60cm built-in dishwasher: Came to empty the machine and the door won't open. The dishwasher is built-in and the cupboard front cannot be removed unless the door is opened. Not sure what to do!
  • 121 Answers
SOURCE: Brand New Machine, can't open the door
Threre should be instructions on what you need to remove, but where is this black plastic located, and wher eis the screw positioned?
Posted on Nov 07, 2007
Illeagle
  • 525 Answers
SOURCE: soap dispenser
A wax motor controls the opening of the lid. Also a seal that fits around the latch lever may be deteriorating and obstructing the function of the lever. Follow the link below for images and part numbers with cost.
Item# 1405...$20.30
Item# 1434...$ 3.95
http://www.repairclinic.com/SmartSearch/smartsearch.aspx
Posted on Jun 04, 2008
SOURCE: KitchenAid Dishwasher KUDSO2FRSS
I recently had the same problem. One of the cords that attaches the door to a spring had snapped. I purchased cord replacments at the following URL and completed the repair myself. http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=1059756&PPStack=1
Good Luck, Tim K.
Posted on Jul 07, 2008
  • 415 Answers
SOURCE: mdb7601aws dishwasher door drops down
hi there,
go to www.whirlpoolparts.ca to get the exploded view for your model #. it will be the located under Repair Parts.
Posted on Sep 23, 2008
SOURCE: squeaky noise when open door
petroleum jelly rubbed on the nylon cord and all parts that it touches...it does the trick
Posted on Dec 10, 2008
I have a WD1 12C Smeg washing machine - when I open the door there is an awful smell reminiscent of stagnant water - the machine it self seems to be running OK I've put it on 90degress empty but still...
This will potentially sound odd, but run the 90 degree cycle again with 3 dishwasher tablets in the drum. The smell is bacterial and probably the result of a build up of residue from biological soap powder (Which is simply bacteria that eat your stains). Dishwasher tablets are anti-bacterial and will kill the bugs making the smell
Jul 07, 2011 | Smeg WDI12 Front Load Washer / Dryer
BOSCH DISHWASHER SHV55MO3GB 60CM HOW DO I ADJUST THE DOOR SPRING ON THE MACHINE? AT PRESENT WILL NOT LIE OPEN AND SPRINGS SHUT WHILST TRYING TO UNLOAD.
do you want to adjust the door spring or the door latch?
if the spring is damaged or misplaced you will have to open it and change it
Aug 03, 2008 | Dishwashers
The machine starts, does not heat the water, and just continues to run unless turned off manually. I am thinking either the timer or the heating element has failed. The machine is a model with the control...
hi test the element,the wires in the door can also break,it may be a thermostat/thermistor.if all these test ok it may be the pcb which is known as an intergrated these boards can be very expensive.
Jun 02, 2010 | Smeg 24 in. STX2 Built-in Dishwasher
Water dripping from bottom off door during cycle where can I get a door seal
your overflow is most probably full, from turning off mid cycle and opening door and turning on again. take out of where it is tip up to a 45"angle water will come out, now don't turn off just open door.
Mar 27, 2010 | Smeg 24 in. DWI612 Built-in Dishwasher
SMEG dishwasher - cycle buttons
What is the model of the dishwasher? Open the door and look down the right hand side for a sticker and repost please. As a rule number 3 is a normal wash :D
Mar 23, 2009 | Smeg 18 in. DWI410 Built-in Dishwasher
Smeg Dishwasher SA 620 X-Soap dispenser won't open!
Sounds like the solenoid in the dispenser has failed. Youll need to replace it
Please leave feedback
Thanks
Rob
Feb 12, 2009 | Smeg CSU2001 Built-in Dishwasher
Smeg DI 612 C Domestic Dishwasher
I was told by a SMEG engineer that I needed to replace the detergent dispencer. Just waiting for him to get back with a new one.
Aug 15, 2008 | Smeg 24 in. DWI612 Built-in Dishwasher
Re Smeg 60cm electric oven model SA370 EB/1. I need new door glass and rubber seal for glass door.
I have one for sale I am jus putting it up on ebay buy it and replace yours.
http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&item=110291356746
Jun 23, 2008 | Smeg Kitchen Ranges
Smeg Dishwasher - model unknown
model numbers for dishwashers are generally where you can get to from the front, if they are noit on the front panel then look inside the door rim where the rubber seal is, either a small sticker on the door rim itself (inside) or where the door fits on the main cabinet, open the door fully to look for this sticker, sometimes placed under the front of the lid
Sep 28, 2007 | Smeg CSU2001 Built-in Dishwasher
Apr 21, 2007 | Smeg DWI614 Built-in Dishwasher
Dishwashers Logo
260 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
