Bosch & Tankless LP Hot Water Heater  Logo
A
Anonymous Posted on Sep 15, 2014
Water heater dia.is 19" what is the curcum. of the water heater. heigh is 4feet.nothing more to add
Nothing more to add. what is the circumfrence
william raats
Level 1:
New Friend:
  • Contributor 4 Answers
  • Posted on Sep 16, 2014
william raats
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
1318
Points
First time heard of a tankless that is round
I need to find the heater elements for a vanguard water heater 240v 36 kw model 6e746a
1) Buy 3600 watt element. Nothing special needed:
Copy following link to identify type of element:
http://waterheatertimer.org/How-to-replace-water-heater-element.html
2) March 2013: Add a comment and describe the water heater and the element.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
1helpful
We have a unit it's only 3 years old and it's now showing problems with the water not passing or coming up
10-19-12
Please add comment, and include model, brand, and type of appliance or water heater so expert can access manual
1helpful
I need a repalcement for a 5-30-20rs960 electric water heater?
Today's water heaters have more insulation and are larger.
Reliance does not have a water heater 20 x 38.
http://www.reliancewaterheaters.com/lit/spec/electric/R606E0312.pdf
I checked several manufacturers.
American Water Heater has 18 x 38-1/2"
Model #E62-30H-045DV
Shipping weight 77 lbs, but I don't know who sells it.
http://www.americanwaterheater.com/products/pdf/NRESS00308.pdf
Whirlpool from Lowes has a 30 gallon
18" x 45"
Roblem with the Bosch 1600H-NG Natural Gas AquaStar AquaStar Natural Gas Tankless Water Heater... Aquastar gwh 1600 h igniter fails clicks does...
Problem could be air supply, gas supply, venting, part failure or combination of listed things.
Best place to start is manual.
http://www.boschhotwater.com/BoschModel1600H/FeaturesandSpecs/tabid/1024/Default.aspx
Typical 1600 manual shows troubleshoot starting page 19
http://www.boschhotwater.com/Portals/7/TechManuals/1600H_English_0606.pdf
Bosch has online tech support form:
http://forms.boschhotwater.com/Home/BoschTechSupportForm/tabid/614/Default.aspx
BOSCH error codes:
http://www.boschhotwater.com/HelpfulResources/TechnicalSupport/BoschAquaStarModels/2400ESTechSupport/Troubleshooting/tabid/1295/Default.aspx
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
1helpful
I have whirpool hot water heater mmodleezf 40RDO45 V six months ago I had to buy and new anode and now the water is stinky again like rotten eggs, am I going to have to buy a new one every six months? ...
The smell is from bacteria.
1) The tank needs a new anode rod, but it also needs a periodic dose of hydrogen peroxide.
Recommend you reconfigure incoming water pipes where you can easily add 2 bottles of hydrogen peroxide and then flush water heater each 6 months. The peroxide kills the bacteria. Peroxide is not harmful to you since it is also used orally. You don't drink a bottle of peroxide, but it will not cause harm in trace amounts left in water heater.
2) There is something else to consider. If yours is a 12-year tank or lifetime tank, then you probably have 2 anode rods. Replacing one anode rod will not solve problem.
3) Another solution is a power anode rod. If your tank has two anode rods, then replace one with powered anode, and then remove the second anode rod.
According to the seller, he's had only one person where the water heater smell came back.
Here are links to information and to the powered anode rod:
http://www.waterheatertimer.org/Replace-anode-rod.html
http://www.waterheaterrescue.com/pages/WHRpages/English/OrderPages/XCart/Power-Anode.html
Manufacturers are starting to add powered anode rods to their top models to assure longer tank life and better customer satisfaction.
Add a comment if you need more help.
I have a Bosch AquaStar AQ-125-BNG tankless water heater. It has worked very well until recently. The problem: The hot water at the tap is turned off, the flame on the main burner keeps burning and...
there is a small dia copper pipe which has a thermal coupling on it the end of it sits in the flame of the pilot light,
if it fails which it does after about 25-15 months,it shuts down the gas burner
I'm looking for room thermostat for Ariston DIA 24 to save some energy and save the world
I haven't one of these type before.Is this a tankless heater or tank heater .
Top Bosch Water Heaters Experts
john h
ZJ Limited
ZJ Limited
Are you a Bosch Water Heater Expert? Answer questions, earn points and help others
