Question about Saitek PZ30AU Keyboard
I have saitek eclipse for 6 months and everything worked fine till last days.LED lights for num lock,caps lock and scroll lock dont stop lightning.it used almost a half of power of lightning and when i shut down my pc,LEDS are still turned on,whats going on? srry for my rude englih
Disconnect it from your PC and then plug it into another USB port.  Either this will resolve the issue, or it won't.  If it doesn't, plug it into another PC.  This will determine whether or not the keyboard is the culprit, or a voltage irregularity coming from the PC's USB ports.  If it works on the other PC, it's the computer, not the keyboard that has a problem.  If it doesn't work on another PC, then it is the keyboard.  As keyboards are inexpensive (even the PZ30AU), I'd recommend you purchase another.  The amount of money you'd pour into either fixing your PC or this keyboard would probably be close to if not more than what you paid for the keyboard in the first place.
Posted on Jul 05, 2009
Scroll pad wont work!!!
Click on the Scroll Lock or Num Lock buttons
Dec 13, 2013 | Gateway NE56R10u Laptop Intel Celeron...
My led indicators for caps lock num lock etc not workinh in my lenovo G570 laptop
Hi, If you are using a keyboard that is wireless im sure you just have to change the battery on the keyboard.
However if the keyboard is connected to your CPU, then depending on your keyboard model, you may have to turn F LOCK (F Lock Light on) to access system key commands if they are labeled on the front of the keys, such as num lock , scroll lock and print screen.When you click on the Flock, the lights are either supoosed to click on or off.
view the keyboard status lights by using the On Screen Display (OSD) option, Ensure you download the software ,
from your start menu do a search for your keyboard, on th key tabs setting,
its important to make sure that the correct model number is entered,
double click on the light you wish to change, in the Reassign a Key wizard,
clear the Displays (key name) status on the screen check box to disable the on-screen display, or select it so that a check mark is in the box to enable it, and then click Finish.
HOPE THIS HELPS.
Jan 26, 2013 | Computers & Internet
My laptop screen is black and caps lock and scroll key are flashing
That is a security configuration on HP Laptops, depending on the way they blink is the problem your machine has.
Here is the web page where this info is posted, in case you need more info, hope this helps you to determain.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01443366&lc=en&dlc=en&cc=uk&lang=en&rule=26781&product=3816592
This document pertains to HP Notebook PCs with the HP Unified Extensible Firmware Interface (UEFI) beginning in late-2008. On startup, you may see a blank screen. If the diagnostic utilities detect a specific problem with hardware components, the fan turns on, but the screen remains blank. To help identify the cause of the problem, various LED lights on the keyboard blink a series of codes. The diagnostic utilities use the LEDs near the Num Lock or Caps Lock keys to blink a series of error codes. At the end of the series the blinking stops. The pattern of blinks will occur any time you attempt to start the computer until the error is resolved. Battery power LED blinks The Battery power LED indicates the condition of the power supply. When starting the computer, or when the computer is in operation, use the chart to identify the power condition. Battery Power LED Component Tested Error Condition Battery power LED off, and Caps Lock/Num Lock off Battery or AC Adapter AC adapter not connected or failure
Battery low charge or failure Battery power LED blinking Battery Insufficient charge on the battery When new computer is used for first time, the white LED light for the AC power connector blinks. Battery is still in "Shipping Mode", the light continues to blink even when AC power is connected.
To resolve, turn off notebook, connect AC power and allow battery to charge for at least 30 minutes, then start computer. LEDs near Caps Lock and Number Lock keys blink when starting notebook The LED lights near the Caps Lock and Num Lock keys will blink if an error is detected during the start up process. The LEDs will blink a number of times in a sequence and then stop. The number of blinks in the sequence indicates what component caused an error when it was being tested during start up. If the LEDs stop blinking and the computer does not start, you can press the power button again to repeat the tests. Count the number of blinks, and use the chart to identify the error condition. Knowing the number of blinks is helpful when you contact an HP support agent for technical help. Caps Lock/Num Lock LED Component Tested Error Condition LEDs blink 1 time CPU CPU not functional LEDs blink 2 times BIOS BIOS corruption failure LEDs blink 3 times Memory Module error not functional LEDs blink 4 times Graphics Graphics controller not functional LEDs blink 5 times System board General system board failure LEDs blink 6 times BIOS BIOS authentication failure
Dec 01, 2011 | HP Computers & Internet
Compaq Keyboard -- top right hand corner, the light next to the CAP LOCK is lit. What is this for?
Num Lock ----- Cap Lock ---- Scroll Lock
  • Num Lock --- use numeric keypad
  • Cap Lock --- all capital letters
  • Scroll lock --- stop screen from scrolling ( pause screen )
Feb 23, 2011 | Computers & Internet
On Saitek eclipse II illuminated keyboard: What is function of the 1 (above the f8), the A (aboveF9) and the down arrow between F10 and F11) Also the function of the dey on bottom row between the windows...
The 1, A and down arrow represent the usual Num Lock active, Caps Lock active and Scroll lock on option available on all keyboards out there.
The 'dey' key on the bottom between the Windows Key and the Ctrl acts as a right mouse button, as in opening the menu you would open with the right mouse click.
Hope it helps.
Dec 31, 2010 | Saitek Eclipse II Illuminated Keyboard
Compaq 6735s notebook pc goes to HP screen, but wont boot
First you need to determine how many blinks you are getting when you try to power on the laptop.
Check the blinking codes below and reason behind that for HP Compaq laptops
Blinking battery power LED Battery Insufficient charge on the battery
Blink: 1 - Caps Lock/Num Lock - CPU CPU not functional
Blink: 2 - Caps Lock/Num Lock - BIOS BIOS corruption failure
Blink: 3 - Caps Lock/Num Lock - Memory Module error not functional
Blink: 4 - Caps Lock/Num Lock - Graphics Graphics controller not functional
Blink: 5 - Caps Lock/Num Lock - System board General system board failure
Blink: 6 - Caps Lock/Num Lock - BIOS BIOS authentication failure
Plz get back so I can suggest you the steps to resolve the issue.
Dreamkam
May 24, 2010 | HP Compaq 6735s Notebook
My laptop does no more boot up. As soon as i start , the caps lock and the scroll lock lights keep flashing continuously and the fan even does not run.
Well hellonihar, As far as your issue is concerned it seems to be some hardware issue. LED
Component
Error Condition
Battery
CPU
CPU not functional
BIOS
Memory
Graphics
System board
BIOS
Apr 19, 2010 | HP Pavilion dv5-1000us Notebook PC
Keypad numbers are locked on, how do i unlock??
Boot to your Bios and look in advanced for num lock and disable.
or
go to run in the start menu.
typ: regedit.
Go to: HKEY_USERS\.Default\Control Panel\Keyboard
Then String value- InitialKeyboardIndicators right click click modify then choose a number below.
Explaination numbers.
0= Truns Off, Num Lock, Caps Lock, Scroll Lock
1= Turns On Caps Lock,
2= Turns ON Num Lock,
3= Turns On Caps Lock, and Num Lock
4= Turns ON Scroll Lock
5= Turns on Caps Lock, and Scroll Lock
6= Turns On Num Lock, and Scroll Lock
7= Turns On Caps Lock, Num Lock, and Scroll Lock
Hope this helps.
Feb 07, 2010 | Acer TravelMate 4230-6499 Notebook
Love my new Saitek Keyboard, but I don't what some of the buttons do???
You can download a manual here: http://www.saitek.com/manuals/eclipse_manual.pdf For the 1, A, and Down Arrow: My guess is that these are actually the indicator lights for Num Lock, Caps Lock, and Scroll Lock. For the four silver round buttons: The top right corner of your Eclipse keyboard features a set of controls for changing your computer?s audio volume and the brightness of the Eclipse Keyboard?s backlighting. To reduce audio volume, press button A until the desired volume level is reached. To increase volume, press button B. To mute the audio output, press button C and press it again to cancel mute. Press button D to control the brightness of the backlighting. Press the button to scroll through lights off, lights full brightness and lights half brightness.
Apr 18, 2007 | Saitek PZ30AU Keyboard
Saitek PZ30AU Keyboard Logo
341 people viewed this question
Top Saitek Computers & Internet Experts
micky dee
Ajay Virvan
Ajay Virvan
Are you a Saitek Computer and Internet Expert? Answer questions, earn points and help others
